HP LaserJet 1320 Printer
Problem for HP LaserJet 1320 Printer
Orange triangle is on
By cheer_soc497 on Oct 07, 2009
Was a paper jam but is not resetting - orange triangle will not go away
Solution #1
posted on Oct 07, 2009
Not Rated)
Adi_Taticu
Rank: Guru  HP Expert
Rating: 87%, 23 votes
This state can be reached in the following circumstances:
  • Paper tray is empty
  • Door open
  • Paper jam
  • Misfeed from tray
Action
Verif that the print cartridge is present and that the print-cartridge door is closed correctly.
Verify that media is present in the input tray
Clear any jams and perform paper-path functional checks.
To reset the printer after a jam, press the Go button.
You might need to clear the error manually, and press the Go button or close the top cover.
You already trying this and was not repeared.
You must check the paper sensor manually. Open the input tray and remove it. Check manually the sensor near the pickup roller. (right side) If the led are still orange and not move to the green one (ready state) then is a problem with your sensor position. It must remove the paper pickup roller and put the sensor in corect position, you must see the delimitation for correct position sensor.
I hope this help you.
Was this helpful?
Yes
No
Solution #2
Not Rated)
denz_maveric
Rank: Wiz  HP Expert
Rating: 85%, 135 votes
Was this helpful?
Yes
No
Popular Solutions for HP LaserJet 1320 Printer
Questions and Unsolved Problems for HP LaserJet 1320 Printer
Do you recommend HP LaserJet 1320 Printer?
Answer
Answer
dirty prints especially on heavy paper
Answer
printing from excel hp1320 prints double copies - not any other program - checked copy count in... (More)
Answer
I had a paper jam and now the power light keeps flashing with the amber warning light constantly on... (More)
Answer
Since upgrading to Windows 7 my HP LaserJet 1320 will only print a single copy of a document despite... (More)
Answer
i cant connect my hp laserjet 1320 pcl6 to my dell pc with vista os, i try to add it but it cant... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
in , CA
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
