Question about OKI C9500dxn Led Printer
C5300 error 380: Paper jam
My C5300 has an error 380: paper jam. I checked everywhere and can't find any paper jam.What can I do to solve this problem?
Please help. Thank you in advance.
  • 624 Answers
SOURCE: OKI C5100 printer repeated jams. Usually flashing the code of "380: paper jam" as the message.
You probably have already looked this up by just in case here is Okidatas instructions for clearing this jam: http://my.okidata.com/PP-C5100n.nsf?opendatabase. If you have already looked here and done this then I would suggest: -Open and close the rear cover. -Pull out and replace each of the toner cartridges. -Pull out the duplexer, ensure it is clear of jams and replace. -Pull out each of the paper trays (including the manual tray), ensure paper is installed correctly and replace. -Close the top cover. Per Okidata this has to be done last or else you will continue to see a jam error. -Try unplugging the printer and letting it set for a few minutes and retry. If that fails you might try purchasing a can of air from the computer store (about $3) and blow out the paper path to clear any paper or dust that may be blocking an optical sensor.
Posted on Dec 03, 2006
ctf1800
  • 4402 Answers
SOURCE: HP OJ 6310 All in One Paper Jam
check for a small piece logged inside, remove the toner cart and check that, take paper out and check under that
Posted on Jan 10, 2008
SOURCE: HP Officejet 6210 Printer; Paper Jam
Jfasher got it spot on !
The clear wheel on mine was freewheeling and a gentle push of this wheel on to the white cog behind seemed to engage it and its working again
Many thanks.
Hamish
Posted on Feb 18, 2008
Mix-it-up
  • 832 Answers
SOURCE: paper jam, open back cover, then remove paper jam
Ther is some tiny little paper piece left in the machine! You will find it at the left hand side near the gear wheels ;-)
Posted on Jun 15, 2008
  • 138 Answers
SOURCE: hp 5550 laserjet paper jam
Thhis error is usually due to a dirty photcell (sensor) in the tray 2 paper feed assembly or a broken sensor flag in the same assembly. Start be removing all cartridges and the transfer belt. Look in the bottom of the printer below the lowest cartridge slot for a removeable cover. That's the area your problem is probably in. I have incuded a link to a free PDF of complete service manual below. Good luck.
http://www.feedroller.com/Store/Service%20Manual/Color%20LaserJet%205500-5550.pdf
Posted on Aug 03, 2008
Paper jam 2 on Samsug ML-3051N
There is a door around the very back of the printer, if your printer is slightly encased in as mine is you can't see it. That is where the Paper jam 2 is
Jan 04, 2010 | Samsung ML-3051N Laser Printer
Error Code #380
check in back side of printer there should be small paper jam check it.
Jul 13, 2009 | OKI C5100n Laser Printer
Canon MP470 printer jam error
hi...open the printer then clean..i think theirs a lot of DUST that's why printer said paper jam
Jun 17, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Oki 5250 380 paper jam
Sometimes you will find debris has fallen into the printer. Take off back to clean it out. Something as small as a staple can create this problem.
Apr 09, 2009 | OKI C5250n Printer
Canon MX300 Paper Jam
I have the same problem - every time I turn on my printer now, the alarm signal shows up with "Paper jam" but when I check for jammed paper, there is none. So I think there's something faulty with the printer. Is there any way to reset it? I've looked everywhere but can't find it.
Jan 16, 2009 | Canon MX300 Office All-In-One Printer
380 Paper Jam
There could be a small bit of paper stock in sensor
near the bypass tray.
Jun 23, 2008 | Xante CL30 HSE Laser Printer
E3 error
if u have had a paper jam previously u may have damaged the paper sensor when u removed the paper
Jan 24, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Jan 10, 2008 | HP Officejet 6310 All-In-One InkJet...
I too kept getting the front cover paper jam despite followings Oki's paper jam removal instructions and blowing out the printer with compressed air.
In my case, the paper drawer was the problem.  When you pull out the drawer there is a spring loaded piece of white plastic at the very front of the drawer.  In the center of that is a gray rubber strip.  That strip had come loose in the center and bowed out, preventing paper from exiting the paper drawer.  I manually removed the strip, clipped off a little piece from one end so that it fit back in the recessed cavity on the white plastic piece and glued it back down.
This should be applicable to all Oki c5xxx color LED printers.
Dec 03, 2006 | OKI C5100n Laser Printer
Error Code:380
Try to force a sheet into the feeder in order to clean and possible remove any piece of sheet. I had the same problem error 380: paper jam in oki 5300, but this time it said to open the front cover...
Jun 22, 2006 | OKI C9500dxn Led Printer
OKI C9500dxn Led Printer Logo
355 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
