Model 6461 water won't shut off at intake- suspect that inlet valve is stuck open.
  • 770 Answers
You suspect correct. It is either a valve malfunction or the float that controls the valve.
Posted on Oct 07, 2009
Testimonial: "Thanks for confirming our suspicions now if we can only get ASKPO extended warranty to act."
Samsung vrt washer water wont stop running
Sounds as if the internal water valve may be stuck in the open position, try replacing the valve
Aug 25, 2014 | Samsung WF419AAU 4.3 cu. ft. Front Load...
Water dont shut off
If you unplug washer and the water is still running you need a new fill valve.
Jun 11, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore coldspot 106
It can be a defective=> W10408180 Water Inlet Valve
or the problem can be a defective=> 2162361 Micro Switch
2162361 Micro Switch Can you unplug the wires going to the W10408180 Water Inlet Valve? I am here to help you solve this problem if you like. If the wires going to the W10408180 Water Inlet Valve are disconnected and the water continues to flow the problem is most likely the W10408180 Water Inlet Valve being mechanically stuck open The 2162361 Micro Switch can be tested after we prove that the=> W10408180 Water Inlet Valve is not stuck open. I am here if you need me, Thanks Sea Breeze
John Tripp
Dec 02, 2013 | Refrigerators
Ariston AVXL 129 4H lit up and not starting
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line.
May 02, 2013 | Washing Machines
My Kenmore model 417 won't start, after doing one load successfully
It ispossible that the machine does not start off the cycle because there are errorsdue to feedback from the inputs. For the program to start up the main programcontroller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting fromthe flow of water into the drum as also the drain valve to open to exit thewater at the point of the program cycle. If this does not happen then thevoltage at the valve/motor/pump must be checked or the fault relates to novoltage from the controller. This meansthe controller is a suspect.If thewater flows though the inlet then the flow pressure should be good, if not theinlet valve is bad or there is dirt in the filter. Also check the flow at theinlet of the water line. Once the water comes into the system the WATER LEVELSENSOR - normally a pressure switch- must activate at the preset/chosen levelto give the signal to the program controller to switch on the motor. What ismost important for the motor to start functioning is that the door switch mustbe ON when the door is shut or this will be an error for starting the motor forrinse and wash.Check thislink to replace the inlet valve:http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Jul 29, 2012 | Kenmore Washing Machines
Water flows constantly during the spin cycle
Servicing Water Inlet ValvesIf the washer won't fill or fills very slowly, if it overfills, or if the water is the wrong temperature, the water inlet valves could be faulty. These components are easy to locate and very easy to replace, at little cost. When you suspect an inlet valve is faulty, first check to make sure the water faucets are fully turned on and properly connected to the hot and cold inlets of the valves. Then check the screens in the valves; if they're clogged, clean or replace them. If water doesn't enter the tub, set the temperature control to the HOT setting. If there is no water, set the control to the WARM setting. If all that comes out is cold water, the hot-water inlet valve is faulty. Reverse the procedure to test the cold-water valve, setting the control first on COLD and then on WARM. If the tub overfills, unplug the washer. If water still flows into the tub, the valve is stuck open. In any of these cases, the valves should probably be replaced.
Dec 08, 2011 | GE WBVH6240F Front Load Washer
The machine is off and the water keeps running
When this happens, that means the water inlet valve is not shutting off. EIther the valve is stuck or there is still power going to the valve keepng it open allowing water flow.
Nov 10, 2010 | Kenmore HE2 Plus Front Load Washer
Water inlet is just a trickle and have made sure that there is no kink in the line or any leaks. I suspect that what I believe to be an impeller or pump is bad?
I would turn the water off to the house, unhook the inlet hose from the shut off valve under the sink, and open the inlet valve and try cleaning it out with a pipe cleaner or remove the valve completely and soak it in CLR. If this doesnt correct the problem then you may need to replace the inlet valve on the dishwasher but its almost always a gunked up shut off valve.
Let me know if this helps _MJ_
Feb 07, 2010 | Dishwashers
Tub completed cycle and wouldn't shut off the water
Is your machine a FAV6800A or FAV9800A? Can you confirm the Model Number and the first two digits Serial Number?
Does water flow into the machine with the 120VAC power plug pulled from the machine?
If it does you have a stuck water valve. If it doesn’t you could have a stuck pressure switch and I can walk you thru how to check in diag mode for that condition.
I know you are frustrated but with some basic troubleshooting we can determine if the issue is a stuck open Water Inlet Valve or a defective Pressure Switch. Because this board doesn’t ask for the Model Number or Serial Number we need to start there.
Here is where the Model and Serial number info is located on the back of your machine.
Jan 24, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have a fridigidaire washer machine model fwf235rf5 The problem is water is running all the time.
INLET VALVE STUCK. REPLACE INLET VALVE. CONFIRM BY SHUTTING WATER VALVE OFF TO MACHINE, IF NO WATER ENTERS TUB WHEN OFF AT THE SUPPLY THEN INLET VALVE IS STUCK OPEN.
Jan 28, 2009 | Washing Machines
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
