Question about Dryers
Need a diagram for tumbler belt placement on the motor pulleys
  • 770 Answers
Mot sure which dryer you own, however it typically goes like this. Belt around drum, position in the tracks where the old one was, (usually some visable rubber residue), then around the motor pully, lastly, compress the tensioning device and route belt onto the cradle then release the tension.
Posted on Oct 07, 2009
Put new belt on Part# 137292700 and it won, t turn the drum
one possibility is the belt isn't on tension pulley pulley,the proper placement is the belt goes on the top of pulley aand the pulley is pulled slighty by hand and the belt fits on the under side of the motor pulley watch this video for proper confugeration of belt on tension(idler pulley) and motor pulley pause vidoe at the 1:18 mark for a real good picture of proper alignment
http://www.youtube.com/watch?v=-PdL6cI8aPU
Aug 08, 2011 | Frigidaire FEX831CS Top Load Stacked...
Tip
The motor is running, but the drum isn't spinning.problem with dryer.
Nine times out of ten it's a broken belt, but there are other factors that can cause this problem. <br /> <ul> <li>Broken belt -- Replace with an identical belt. Line up the new belt with the markings on the drum from the old one. Wind it around both the motor pulley and the idler pulley.</li> <li> Roller could be bad -- Underneath the tumbler is a roller that the tumbler sits on. It may have become too worn to work properly and may need replacing. Replacing it is simple - just remove the tumbler to gain access and then remove the retaining clip on the roller and slide it off. Reverse the process to install a new one.</li> <li> Motor or idler pulley could be bad -- Check the pulleys to ensure they're still in working order.</li></ul>
on Dec 24, 2010 | Dryers
The belt keeps coming off the tumbler
you did not say what type here are some common type(kenmore is whirlpool etc) find the diagram that fits your motor and idler pulley and route it that way. Good Luck Tim:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
May 29, 2011 | Dryers
I bought it in 2003 neptune dryer and the 3 bar inside the dryer broke and the dryer is not working right . we have to dry them 3 time before they are all dry
Instructions
Things You'll Need:
* Phillips-head screwdriver
* Replacement belt
1. Disconnect the power cord of the Maytag Neptune dryer from the dryer electrical outlet.
2. Open the dryer door, and locate the four screws on the inside lip of the door opening. Use a Phillips-head screwdriver to remove the four screws. This will disconnect the front panel from the shroud assembly.
3. Grab the front panel on each side with your hands. Lift up on the front panel to unhook it from the retaining tabs on the side panels. Remove the front panel, and set it out of your way.
4. Use a Phillips-head screwdriver to remove the four outside perimeter screws that secure the shroud and tumbler front to the dryer cabinet. Pull the shroud and tumbler front away from the tumbler while lifting the top panel partially up.
5. Reach both of your hands underneath each side of the tumbler. Use your left hand to grasp the idler pulley, and pull it to the left while using your right hand to slip the belt off the motor pulley. Pulling the idler pulley to the left releases tension on the belt. You can now slip the belt off the back of the tumbler.
6. Take the old belt with you along with the model number of your dryer to purchase a new belt. Most appliance repair shops will have replacement belts in stock. Make sure that the new belt matches the old one by comparing the two.
7. Slide the new belt over the rear of the tumbler with the ribbed side pointed to the inside. Using both hands under the tumbler, route the belt around the motor pulley and idler pulley. Pull the idler pulley to the left while routing the belt, and carefully allow the idler pulley back to the right to apply tension.
8. Reattach the tumbler front and shroud to the front of the cabinet using the retaining screws. Place the front panel over the side retaining tabs, and push it down to lock it in place.
9. Open the dryer door, and secure the front panel to the shroud using the retaining screws. Close the dryer door, and plug the power cord back into the dryer electrical outlet.
Feb 28, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Replacing dryer belt and want diagram to be sure it correct
Put the bel around the tumbler first, then around the motor pulley, and finally put the farthest part of the belt at the pulley around the tensioner. Good luck.
Jul 01, 2009 | Dryers
Put belt on dryerg
While I don't know about your specific dryer, most dryers are set up the same. I just replaced the belt on my Maytag LDE8404ACE. It was easy. The hard part was cleaning out 14 years worth of lint and fuzz that coated everything inside. Here's the instructions:
1. Unplug the dryer or disconnect power.
2. Remove the front panel. There are two screws, each is about 4 inches up from the bottom of the front panel. Unscrew them. Then hold the front panel along the bottom edge and pull it away from the dryer. Once it's away enough, the clamps along the top will pop and disengage from the dryer. Be sure to note the wires connected to the door switch are connected to the dryer. Disconnect them if you need to move the panel away from the dryer.
3. With the front panel off, you should be able to reach inside the dryer to remove the old, broken belt.
4. Remove the tumbler from the dryer. It's held in place by the tumbler front which is secured by 4 screws, 2 on each side. That piece will pull straight out toward you. With the tumbler front out of the way, the tumbler itself will come straight out as well. I recommend taking it out and cleaning the inside of your dryer while it's open. A vacuum hose works great. Also, check the pulley and the back two wheels that the tumbler rests on to make sure they turn easily. If not, you may want to grease them. Also, it's normal for the idler pulley to appear to be loose and wiggle in place. Once a new belt is installed, it's under tension from the spring so any play that exists shouldn't be a problem.
5. put the new belt around the tumbler with the smooth side of the belt against the tumbler. Use the old belt marks on the tumbler to align the new belt. It's easier to hook the belt to the idler pulley and motor pulley from the back. So we'll get to that part in a minute. Just let the belt hang loose for now.
6. Reinstall the tumbler front and secure with the 4 screws you removed earlier.
7. Reconnect the wires to the door switch, if you removed them earlier.
8. Reinstall the front panel, reversing the steps you took to remove it in #2 above.
9. Go to the back of the dryer and remove the access panel along the bottom right hand side.
10. From there, reach in pull the dryer belt around the idler pulley. Then take the belt on the left side of the pulley and move both the belt and the idler pulley to the right, until you can get the grooved side of the belt onto the motor pulley. I've attached a diagram with instructions.
11. Once connected, manually turn the tumbler so that the belt will align and make sure the tumbler turns as easily as it did when you first removed it.
12. If the belt looks good and you've manually turned the tumbler at least one full revolution (to ensure the belt didn't get twisted), then plug the dryer in and turn it on to make sure it works correctly. If so, then re-attach the access panel on the back of the dryer. You're done!
Nov 16, 2008 | Whirlpool LER5636P Electric Dryer
Frigidaire Dryer
If Dryer does not tumble , check the following:
" It won't tumble If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it."Source Repaiclinic
Sep 08, 2008 | Frigidaire GLER642A Electric Dryer
Drum problem
Aug 28, 2008 | Kenmore 73952 Gas Dryer
Broken belt that turns the drum
12. If the belt looks good and you've manually turned the tumbler at least one full revolution (to ensure the belt didn't get twisted), then plug the dryer in and turn it on to make sure it works correctly. If so, then re-attach the access panel on the back of the dryer. You're done!0798e0b.jpg
Aug 17, 2008 | Maytag PYG2300A Gas Dryer
Serpentine belt diagram
Hope this helps
Mike
Jun 08, 2008 | 1994 Saturn Sl
Dryers Logo
91 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
