Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Icemaker leaking ge profile refrigerator icemaker leaking into freezer compartment
    Scholar:
  • 103 Answers
Check two things.
1: see if you have ice buildup in the water inlet tube above ice maker, if you do chance are the water valve is bad, if not,
2: see if you have icicles hanging from bottom of ice maker, if you do you have a bad ice maker.
Either way, will need full model number and serial number both to get you the right part numbers for parts.
Posted on Oct 10, 2009
Icemaker leaking despite replacement
is the ice maker actually leaking or do you have a crack in the ice bin allowing it to leak from cubes?
Aug 27, 2015 | Refrigerators
The icemaker in my GE Profile Side by Side refrigerator overflows. The water freezes up the sensor arm and makes a glacier in the back of the ice compartment. Is there any way to regulate the water flow to...
Sounds like the dual water control valve is sticking open while off allowing water to slip by the valve an into freezer compartment. Best to turn water off at source untill the=> WR57X10051 Water Valve - Dual Outlet
can be replaced, Thanks, Sea Breeze
Sep 24, 2011 | GE Profile PSW26P Stainless Steel Side by...
I have a GE Profile refrigerator, Model PFSS6PKWBSS, with icemaker on door. Water is collecting under Deli-draw and leaking down freezer door onto floor. How do I fix leak?
Hi
Try and access the ice dispenser assembly and check from where the water is leaking. You would need to disassemble the ice dispenser and ice maker to check this. The ice dispenser is located in the upper portion of the freezer compartment. This assembly stores ice made by the icemaker and dispenses ice on demand from the door dispenser target switch.
1. Remove the upper ice bucket tray.
2. Slide out the ice dispenser assembly.
3. Remove the ice cube solenoid linkage Phillips head screw and slide the linkage back.
4. Remove the ice crusher cover Phillips head screws (2) and remove the cover.
5. With a pair of pliers, twist off the backing plate tabs located on either side of the crusher.
6. With 2 small flat-blade screwdrivers, unlock the ice crusher locking tabs located at either side of the ice crusher.
7. Lift the ice crusher out of the bucket.
8. Remove the ice crusher back cover.
9. Remove the locking ring from the ice crusher auger.
10. Remove the plastic nut with a pair of pliers by turning it clockwise.
11. Remove the spacers and blades. The blades are numbered for reassembly.
Icemaker--
The icemaker is located in the upper rear of the freezer compartment and supplies ice to the dispenser tub.
1. Disconnect the icemaker cable connector.
2. Remove 1/4-in. icemaker mounting screws and slide out the icemaker.
This refrigerator is equipped with an Electronic Icemaker.
Hope this helps... Please post back if you need more information.
Daniel
May 01, 2011 | Refrigerators
Ge profile evaporation fan installation. Where is it located?
It's located in the freezer compartment . May have to remove all panels , including the icemaker , to install it . If the fan isn't working though , the problem is probably the main control board , located behind an 8 " X 10" panel , on the back of the refrig . Usually , a resistor burns out and the freezer fan stops working .
Sep 19, 2009 | GE Refrigerators
Ge profile artica side by side flooded my kitchen floor,seemed to come from freezer. Help please.
It's most likely a leak in the line feeding the icemaker -- or it may just be loose. Could be the valve, but less likely. It'll have to be removed to find out.
May 12, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Icemaker noises on almost new GE Profile refrigerator
I have not heard of this issue but if it is coming from the icemaker, then it will have to be replaced. You are still under warranty so call to have them replace it now, otherwise the new icemaker will cost you about $125.
Feb 25, 2009 | GE PDS22SIS Bottom Freezer Refrigerator
Our ge profile is leaking water above the icemaker, help
Sounds like the inlet water valve for the icemaker is not shutting off 100%. That would result in either A.) a block of ice plugging the tube where the water passes through from the outside of the freezer into the freezer compartment, or B.) an ice waterfall in the freezer into the ice bin and/or down the back wall of the freezer compartment.
Solution to either: replace water valve and remove ice with the aid of a hair blower.
Sep 01, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
346 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
