Question about Canon PIXMA MX310 All-In-One Printer
Canon iP1880 absorber is full. How do i rectify the problem?
  • Canon Master
  • 525 Answers
Follow this procedure:
1. Enter Service Mode: Hold Power button and plug a power cord, then push Resume button twice and release all buttons.
2. Free Download from Internet: GeneralTools for Canon Pixma IP1880
3. Starting GeneralTools
4. CHANGE USB PORT change into PORT of your printer
5. click lock release
6. click ip1800
7. click device id
8. clear waste ink counter by clicking MAIN & PLATEN
9. Check EEPROM Box
10. Click EEPROM Dump
Power off printer and all done. Work again!
Posted on Jan 15, 2015
  • 117 Answers
When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
Posted on Oct 07, 2009
    Guru:
  • 389 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} http://files.mail.ru/X7E0JQ
Unset of the mistake "Overflow to capacities for collection of the perfected ink"
1. Switch off the printer and disconnect the wire of the feeding.
2. Press kn. ON. NOT releasing it, connect the wire of the feeding.
3. Still not releasing kn. ON. 2 times press kn. The Summary.
4. Release both buttons.
5. Hereon indication of the mistake must stop.
6. Take out of all files of the program attribute Rid Onli (if he there is)
7. Start program (file GeneralTool.exe)
8. Choose the port of the printer in window USB Port 9. Press kn. DEVICE ID, be certified that program it is correct has defined the model of the printer.
10. to press kn. EEPROM INFORMATION, be certified that counter отработки Dx really is or more 100,0
11. In window CLEAR WASTE INK COUNTER to press the buttons MAIN and PLATEN. When striking on button printer indicator must мигнуть.
12. Check in EEPROM INFORMATION importance Dx, it must be is "0" or several units.
Come out of program. Switch off the printer. Disconnect the wire of the feeding. Press kn. ON and keep her(it) while indicator not погаснет (completely run down the capacitors in BP) Include the printer. It Be Certified that indication of the error is absent.
THE NOTE. Kn. LOCK RELEASE will release the buttons a function SET DESTINATION and ENDURANCE MODE. If You no need to change the model of the printer or test the printer under "load", no need its press.
Good luck.
4 Suggested Answers
SOURCE: canon pixma ip1880 ink absorber is full
installation
Posted on Mar 02, 2009
SOURCE: IP1880 Canon PIXMA showing Ink absorber full
Pixma ip 1880 is full(solution)
1. first unplug power cable and usb cable
2. hold power for 1-2 minutes
3. turn on power
4. your printer should back to normal printing
Posted on Mar 21, 2009
  • 8 Answers
SOURCE: how to remove ink in th full ink absorber?
waste ink absorber error message can sometimes be solved by resetting the printer itself. i havent yet tried in ip1880 but in ip1200, th e resetting method is this: (it might also work on other models)
1. unplug the power cord and the data cable(printer to pc) 2. while press-holding the (printer) power button plug the power cable (do not release printer power button until step 3) 3. press 'resumet' ( the button below the power button of the printer) button twice... 4. release the power button 5. connect the usb cable of the printer to the pc... - a new canon printer shall be found in the list of printers. use it as default printer
Posted on Aug 19, 2009
Why is my canon ip1800 printer still not printing after cleaning the ink absorber, I still get the message ink absorber is full
Shelly, Did you reset printer after cleaning absorber.
Press and hold the "Power" button and reconnect the power cord. When the printer comes on, release the button. Wait five seconds and push the "Power" button again. This resets the printer's internal memory and overrides the "ink absorber full" error code.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
The ink absorber is full Canon Pixma IP1980 IP1880
How to Clean Canon Ink Absorber
iP1800 ink absorber
Apr 07, 2016 | Canon Office Equipment & Supplies
My canon ip1880 's ink absorber is full
Ink absorber is a part of the printer that absorbs the excess ink while printing. There is a way to reset it but its not recommended, as the ink will eventually leak into the printer. I suggest that you get a replacement ink absorber pad from canon and replace the one in your set.
Nov 10, 2010 | Canon Office Equipment & Supplies
I need software for canon Pixma iP1880
Click here Click on above link then select your os and download driver then install. Let me know if you need further assistance. Thanks for using FixYa.
Oct 10, 2010 | Canon Office Equipment & Supplies
Pixma ip1880 ink absorber is full pls tell how to fix
Turn off the printer and take some soft absorbent tissues and fold it into a pad.
Lift the cover to expose the ink cartridges and place this pad over the ink absorber on the LHS of the printer so the pad soaks up the wet ink.
Repeat until the absorber is nearly dry.
Nov 24, 2009 | Canon PIXMA MX310 All-In-One Printer
How to remove ink in th full ink absorber?
Aug 07, 2009 | Canon PIXMA iP1800 Printer
Canon ip1800 printer won't print.
My Canon PIXMA iP1880 cannot print...and shows a message "ink absorber is full" can u help me this problem..
Mar 11, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
3. turn on power
Mar 07, 2008 | Canon I990 InkJet Photo Printer
Canon PIXMA MX310 All-In-One Printer Logo
389 people viewed this question
old marine
old marine
