Question about Sony PlayStation Portable (PSP) Console
A connection error has occured. (80410209)
I can't connect
how to do this steps?? how to reset and unplug?
-1. Try reseting your modem (unplug for about 2-3 minutes, then plug back in), then reset your router (reset button on back). Then try again....
-2. Register your psp with the new router
DarkNeogen
  • 109 Answers
SOURCE: cant upgrade psp
Here's what you can do:
1. Connect your PSP to your PC.
2. Check if the proper folders are on it's Memory Stick. There is
a folder called PSP which had the following folders
underneath.
GAME
VIDEO
SYSTEM
3. The folder you need is GAME. Go in there and create a subfolder called UPDATE.
4. Go to www.playstation.com
5. Look for your local site.
6. Look in the PSP section for firmware updates. Here's the link for the most recent firmware update for the USA.
[PSP Firmware 3.80]
* If you need other regional firmware you'll need to look for it yourself or tell me where you from.
7. Download the file in the above link to a convenient place such as your desktop. Then copy it to the recently created UPDATE folder.
8. Safely disconnect your PSP.
9. Start up your PSP and go to the Game section of it, select Memory Stick. You should now see the file.
10. Open the file by pressing X. The update procedure starts. Be sure to follow the on screen instructions.
If you want to read these steps over again, click this link:
[Updating PSP via PC]
Warning: do not use firmware other then placed on Sony PlayStation's official site. For it might damage your system and it will never boot again. Also make sure the battery is fully charged (a charge of 50% will not do, the update utilty won't allow the update). Since it can take an few minutes you best connect it to it's power supply.
NEVER interupt an update by shutting your unit down, removing battery, removing stick, removing power. The damage done is not covered by Sony's warranty.
About the issue for the connection with your PS3 unit. It's true, you need one of the most recent firmwares.
I hope this helped you out, please rate my solution.
Greetings,
DarkNeogen
Posted on Jan 25, 2008
SOURCE: psp wlan connection
fukin stupid asses
Posted on Mar 28, 2008
SOURCE: Psp wifi internal error 80410a0b
I'd love to tell ya that there is an easy solution, but there is not. The error code simply states that the WiFi card is not working; you probably already figured that out! There are three possibilities: The WiFi card itself (most common), a resistor on the main motherboard (manufacturing issue, warranty), or the switch has gone bad (in which case you might be able to "short it out", but search on opening the PSP and you will see that this is straightforward for the very patient). The most expedient route is to (a) send to service or (b) get another PSP and test the WiFi before you leave the store. (And sell the faulty unit on eBay ??)
Posted on Jun 20, 2008
theregoesben
  • 34 Answers
SOURCE: my psp keeps showing error
This error means that either the internet signal you are trying to connect to is very weak or not there at all. If you have wifi internet around you it could be that there is a firewall blocking you from using it if it is someone elses wifi and if it is yours your router or modem could be blocking incomming wireless connections. If the second is the problem try restarting your modem or resetting the router to the default setting
Posted on Oct 29, 2008
PuerkoNess
  • 275 Answers
SOURCE: PSP
Well it look like you might not have a WiFi network connection set up yet on your PSP. So This is what you want to do if you have DSL at home and a WiFi router. When you search for a new network connection and you find the one from your home, you will still need the WEP key wich is the most inportant in order to allow you PSP to use that WiFi connection. That must be why you are getting this error messege
Posted on Dec 09, 2008
I just reset my dell computer back to factory setting. How do I now reset up for internet connection. My provider is verizon and I am using internet explorer
You want to reset your internet connection???
If yes then follow the given steps....
Step 1
Turn the modem so that the back of it is facing you. Locate the power supply cord connected to the back of the device.
Step 2
Gently unplug the power supply cord and leave it unplugged for about 10 seconds. If you also have a router connected to the modem, disconnect the power cord of the router as well.
Step 3
After about 10 seconds reconnect the DSL modem power cord. Wait for the status lights on the front of the unit to come on. They may blink at first before turning solid green, or they may first illuminate as orange, then turn green, depending on the modem model. The "Internet" and "Incoming" lights may continue to flicker, this is normal operation for modems.
Step 4
After the modem is reset, reconnect the router power supply if you have a router. Wait a few minutes before resuming normal Internet use.
If you need any kind of technical assistance you can contact support cell
Jan 19, 2013 | Computers & Internet
RCA DCM425 modem ethernet connection won't work
The setting for the Computer 1, use the network connection wizard to automatically configure the modem to work as a server station. Next, set the IP number manually and the DNS at automatic or is given by your ISP. Now the Computer 2 (workstation) should be connected to a Hub/Switch. The same, go to network connection wizard and select the appropriate connection setting, there are view samples for the connection types so explore them. After the setup, try loading your internet browser.... When done, it should work fine. Keep me posted for any problems.
Nov 26, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
Roku error code 011
Roku error code 011
This error occurred during the Roku player setup. If the Roku lost connection from Roku update server, then this error occurs.
Steps To resolve this issue:
Unplug the devices:
• Just unplug the Roku player, wireless router, and modem.
• And then reconnect them in the following order.
• Plug the modem, wireless router and Roku player.
• And then boot up the modem and gateway. Then follow the on-screen instruction.
Still getting the same error, you must reconnect your wireless network.
Reconnect the wireless network:
·Go to settings?Network?your wireless network
Enter the password to your wireless network.
If this not works then reset your device. Otherwise, call our technicians +1-855-804-1313 to resolve your issues and visit us https://www.rokucodelink.com
Dec 10, 2012 | Roku 2 XS
Connecting to matchmaking server error message
Try resetting your internet connection settings:
Turn off PS3 system..
1: Reset your modem by unplugging it from the main power source.
2: After a few minutes, plug modem power back into modem. Allow all connections to configure
3: Turn on PS3 system.
4: Go to "Settings" then scroll all the way down to "Network Settings"
5: Make sure that the "internet connection" (the second menu) is "Enabled"
6: Go to "Internet Connection Settings" and go through the motions again.
Good luck.
Jan 24, 2011 | Sony Playstation 3 (PS3) Console
Hi, I am trying to install D-Link router WBR-1310 but getting the error code 101 IP address not maching. What do you suggest?
Use the PING command to test the communication between the computer and the gateway.
Goto Start > Run and enter COMMAND.
From the Command Prompt, enter PING 192.168.0.1.
The gateway should reply.
Verify that the residential gateway is getting power. With the broadband modem connected to the WAN port on the gateway, you should have a soild WAN link light. You should use the same cable that connected the modem to the PC to connect the modem to the WAN port on the gateway. Any port on the gateway that has a computer connected to it should have the corresponding LAN link light lit. If you do not get the appropriate link lights, try using different cables.
onfigure browser/Internet Options
Step 1 Go to Start > Settings > Control Panel.
Step 2 Double-click the Internet Options icon.
Step 3 On the Security tab click Restore the default security level.
Step 4 Click the Connection tab and set the dial-up option to Never Dial a Connection.
Step 5 Click LAN Settings. Nothing should be checked. If anything is checked, uncheck it. Click OK.
Step 6 Click the Advanced tab and then click Restore these settings to their defaults.
Step 7 Click OK.
Step 1 Turn the Cable/DSL modem off.
Step 2 Turn the D-Link router off.
Step 3 Wait 60 seconds.
Step 4 Turn the cable/DSL modem back on and wait until all the lights are steady.
Step 5 Turn the D-Link router on.
Most routers and modems do not have an on/off switch. Simply unplug the power. Unplugging the power will not reset (reset back to default settings) the unit.
Nov 09, 2010 | D-Link 802.11g Wireless Router WBR-1310...
I connect in lan but lan showing limited connectivity or no connectivity
hi ...
Try with the following steps...
Step 1: Connect modem>>router>>computer
Step 2: Check with the light status
Step 3: Made a hard reset for 10 sec
Step 4: If still working made a network power cycle ie)unplug the power cable both from the modem and also from the router hold it for a min and then replug it
Step 5: Try with different slots
Step : Try with different cable
Thanks ....
With regards....
Priya
Oct 22, 2010 | Computers & Internet
I have a D-link DSL-500T modem, when i connect it to my Acer GX260 pc , i got this error ' Network Cable Unplugged' . I have try changing the cable but i got the same error. Then i try interchange the...
Can you try reset the network card and also reset the modem by pressing into the little hole on it for like 30 seconds? To reset the network adapter card, you can right click on the network connection of your LAN connection and click on diagnose if you are using Windows Vista. Then you will see the reset network adapter card option. Or you can follow the steps on the following link.
http://windows.microsoft.com/en-CA/windows-vista/Troubleshoot-network-adapter-problems
If you are using Windows 7, then the following link will include the steps about troubleshooting your network adapter card.
http://windows.microsoft.com/en-CA/windows7/How-do-I-fix-network-adapter-problems
Aug 18, 2010 | D-Link Computers & Internet
Error code 80410209
ok so yu get this error?? A connection error has occured. (80410209)
Oct 05, 2009 | Sony PlayStation Portable (PSP) Console
There's no output signal on my router when i connect my modem to it and the out is to my PC, it says no network connection
Connect the Cable modem to the router's Internet/WAN port, then connect the PC to any one of the router's ports.
Reset the D-Link router:
D-Link Router reset
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure. The default user name for most D-Link devices is admin and the password is left blank.
When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds. Then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 23, 2009 | D-Link AirPlus DI-524 Wireless Router
My psp keeps showing error 80410209 when connecting to the internet
Oct 27, 2008 | Video Game Consoles & Games
Sony PlayStation Portable (PSP) Console Logo
177 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
