Question about Sharp AR-5316 Advanced Digital Imager Copier
Copies are not clear. there is a dark line going across the page
  • 66 Answers
Call a service eng n tell him to service
Posted on Oct 10, 2009
2 Suggested Answers
SOURCE: I have a dark line across copies
Posted on May 05, 2010
Black lines across the page after several clear copies
if the lines are acroo the page width then measure the spacing.
If its regular then its due to contmination somewhere in the paper feed. Can't help more without knowing the make and model of printer. Is it thermal,.laser, LED or inkjet?
Mar 14, 2015 | Office Equipment & Supplies
Mysterious fluctuation in quality of copies.
fuser drum is bad. photocopier use electricity to transfer the toner to the paper, then it is heat fused to paper. it appears that the problem is occurring around the time that the toner is attracted to the paper.
Mar 07, 2014 | Canon PC-940 Black and White Copier
Copier leaves a black line when printing through the top paper feeder. Ok coping from the flatbed
When copying from the feeder the page is fed across a fixed point at the head of the flatbed. Any dirt etc on the glass at this point can present as a dark line running vertically down the printed page. When copying from the flatbed, the scan head is moved down the page so any dirt on the glass will only appear as specs. Try cleaning the glass, especially at the head of the flatbed where the feeder is loading the page to be copied.
Jan 12, 2014 | Office Equipment & Supplies
Copying very dark lines down page.
hi just clean complet scanner mirrors and charge and transfer crona wires if solved ok if not solve just replace the drumcleaning blade.
thanks
May 14, 2010 | Toshiba 1370 Black and White Copier
Dark horizontal lines appear across copies
This is usually caused by a dirty main charger grid, try cleaning it per the instructions in your operators guide. If you don't have the guide you may be able to download one from the Minolta Website at
http://kmbs.konicaminolta.us/content/support/supporthome.html
Sep 04, 2009 | Minolta Di151 All-In-One Laser Printer
HP Laserjet 3330 printed dark page especially around the middle
Does this happen both when copying and printing?
For printing solution, try another toner cartridge.
If lines continue to appear when copying (primarily through the automatic feeder) then lift the auto feeder, and clean the glass -mainly the narrow piece on the left side.
please rate solution :)
Apr 07, 2009 | HP LaserJet 3330 All-In-One Printer
Whats the make and model of the copier?
One culprit might be the drum.  If you can take a look at the drum from your copier and you see black lines on it.  It could be scratches on the drum or it may need a new cleaning blade to clean the toner off the drum.
Nov 11, 2008 | Office Equipment & Supplies
Transmitted pages are too dark, practically unreadable :
I suspect your scanner unit is going bad or it is extremely dirty.
Making a copy gets same result as when you send.
Nov 01, 2008 | Brother FAX-8360P Plain Paper Laser
Sharp AR-M280N- Printing dark lines
It sounds like you are going to need a new drum and drum cleaning blade. How long has it been acting up? When was the drum last replaced? The image repeatting could also be coming from the UFR??? It really depends on how many copies you have on it and has it been seatting for awhile..... Need some more info... But you most likely will not be able to fix your self..
May 19, 2008 | Sharp AR-M280N Copier
PC940 dark lines across the middle of the page
Either the Fuser/Heating unit is bad, or the optics are dirty.
What you can try to do to narrow it down, is to make a copy but.. STOP the machine in mid process by turning the power off. This will create a paper jam in the machine. If timed properly, your copy should be 1/2 way through the machine with some image on it. (Make sure that you are trying to copy something on the glass). The copy is not FUSED, so the toner will wipe off so be careful not to rub the page against your clothes/sleeve. IF the black line is on the page at this point, the problem is not in the fuser but probably in the fiber optics. If the problem is in the optics and will need to be cleaned. If the black line is NOT on the page at this point, then the fuser unit is bad and needs to be replaced.
Let me know how the copy comes out when you stop the machine in midway and I can see if i can give you any more suggestions.
Good luck.
Mac
Feb 12, 2008 | Canon PC-940 Black and White Copier
Sharp AR-5316 Advanced Digital Imager Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
