Question about Dell SE198WFP LCD Monitor
I need a video card that supports the 1440 x 900 resolution!
    Guru:
  • 355 Answers
Find the video card from simmpronics, zebronics & nvidea
Posted on Oct 07, 2009
Uninstalation of monitor driver HP2509 stopped monitor to display.shows blank screen in vista desktop
The monitor driver only tells the video card which video resolutions are supported by the monitor. The video card is probably set to the wrong resolution. You can boot into safe mode, set the screen resolution to one the monitor supports, and you should be good to go. You don't actually "need" a monitor driver.
Mar 29, 2013 | HP 2509M 25 Widescreen LCD Monitor -...
Is the ati radeon mxm II 512mb card a reasonable graphics card? Thanks
I am not very sure which ATI you meant, but I assume myself as ATI Mobility Radeon HD 3650 MXM II Graphics Card 512MB, which is compatible with MXM II graphics slot Laptops. It's a good graphics card and it supports high Resolution. For your reference, I include the following descriptions about the Interfaces and their respective resolutions:
# Two integrated DisplayPort outputs
* Each supports 24- and 30-bit displays at all resolutions up to 2560x16001
* 1, 2, or 4 lanes per output, with data rate up to 2.7 Gbps per lane
# Two integrated 400 MHz 30-bit RAMDACs
* Each supports analog displays connected by VGA at all resolutions up to 2048x15361
# HDMI output support
* Supports display resolutions up to 1920x10801
* Integrated HD audio controller with up to 2 channel 48 kHz stereo or multi-channel (5.1) AC3 supporting Dolby Digital or DTS, enabling a plug-and-play cable-less audio solution
# Integrated AMD Xilleon™ HDTV encoder
* Provides high quality analog TV output (component/S-video/composite)
* Supports SDTV and HDTV resolutions
* Underscan and overscan compensation
# MPEG-2, MPEG-4, DivX, WMV9, VC-1, and H.264/AVC encoding and transcoding
# Seamless integration of pixel shaders with video in real time
# VGA mode support on all display outputs.
You can also check out the full specifications here (Click Here).
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Dec 30, 2010 | Computers & Internet
I replaced my computer monitor with an AOC e2243Fw 1920 x 1080 LCD, but the display is a little blurry. How do I get the display to be clearer? Do I need to replace the video card? I tried changing the...
Yes, if your video-card does not support the "native" resolution of the monitor, you'll get "fuzzy" pictures, until you replace the video-card.
Since 3/4 of 1920 is 1440, and 3/4 of 1080 is 810, does your video-card support 1440x810 ?
Since 2/3 of 1920 is 1280, and 2/3 of 1080 is 720, does your video-card support 1280x720 ?
You probably would not want 960x540. Correct?
Dec 28, 2010 | AOC Monitor
Can not get the correct resolution for my monitor 1366x768 do I need a new video card
Not all video cards support all resolutions, and as yours is a fairly old PC the onboard Via Unichrome graphics adaptor probably doesn't support WXGA resolutions. Most, if not all, current AGP cards will do what you want.
Apr 17, 2010 | HP Pavilion a800n (PP163AA) PC Desktop
Vga card
high resolution is supported by high resolution monitors or LCD no matter what type of Video card are you using so first check monitor compatibility with the resolution
Oct 05, 2009 | EliteGroup K7SOM Motherboard
I got the problem too, today...
Check the specs for your video card. Just because the monitor can handle that resolution does not mean that your graphics card can. If it cannot then you can either upgrade the graphics card to one that will support the resolution or you'll have to use the highest resolution that your video card can support. Hope this helps.
Jul 08, 2009 | Samsung SyncMaster 920NW Monitor
Grphic problem with lcd
Without the specific model of your motherboard, I can't say for certain, but I would guess that the onboard video does not support that resolution.
If that's true, then your best option would be to purchase and install (or have installed by someone) a new video card. Most new video cards can support higher resolutions.
Feb 08, 2009 | Intel Motherboard
Lg 2242 won t display widescreen full resolution
the FX5200 doesn't support that resolution. You will need to buy a card that supports 1680 x 1050
http://support.dell.com/support/edocs/video/p57010/en/usage.htm#display_modes
Feb 05, 2009 | Star Computers & Internet
Unable to set resolution to 1440 x 900
eric, YOur LCD support upto 1440X900. this could be true if you use higher resolution VGA adapter in you PC.
This matter in the Video Adapter.
may this help,
melnavz
PS:
pls donot rate me if this solution donot satisfy you. However; if this help, pls rate me reasonable rating. thank you.
thanks for using fixya.
Jun 11, 2008 | Balance CP4401 PC Desktop
Resolution problems
Colsult your user manual or online documents, this may be an incompatible resolution for your monitor, whatever it is.
Oct 03, 2007 | Gateway FPD2275W LCD Monitor
Dell SE198WFP LCD Monitor Logo
97 people viewed this question
Alun Cox
