Question about ASUS Extreme AX300SE-X/TD RADEON X300SE, (128 MB) Graphic Card
It displays corrupted image like many number of lines and corrupted like images
    Guru:
  • 355 Answers
Cleane the ram then try other wise changr the grafic card & ram
Posted on Oct 07, 2009
Camera displays this 'image cannot be displayed' have you got a solution?
Two possible solutions -
1) SD card has no more space on it for further images;
2) SD card is corrupt.
Apr 21, 2016 | Pentax K-m / K2000 Kit With Smc Da L...
SIR HOW TO RESET TRANSFER BELT,IMAGING UNIT, FUSER UNIT FOR SAMSUNG CLP 510
You can check the level of each item.
1. In ready mode press the Menu button on the control panel everal times until you see 'Setup 'on the bottom line
of the display.
2 Press the Enter button to access the menu.
3 Press the scroll button until 'Maintenance ' displays on the bottom line.
4 Press the Enter button
5 When 'Check Others ' displays on the bottom line,,press the Enter button .
6 Press the scroll button until the item you want to check displays on the bottom line.
7 Press the Enter button The display shows the percentage of item.
8. Press the scroll button display either 'Image Count' or 'Reset'
9a. Choose 'Reset' and press enter to reset the counter after replacing a consumable item
or
9b Choose Image count to display the counter.
10. Press the Upper Level button to return to step 7 and select a different choice or press it a second time to return to step
6 and choose a different item.
11. To return to the Ready condition press the Upper Level button several times until 'Ready' appears in the display.
Aug 23, 2011 | Samsung CLP-510 Laser Printer
I have replaced the imaging unit and it still asks for a new one how do i reset it
folow the steps please:
Checking replaceables
If you experience frequent paper jams or printing problems, check the
number of pages the machine has printed or scanned. Replace the
corresponding parts, if necessary.
1. Press Menu until System Setup appears on the bottom line of the
display and press OK.
2. Press the left/right arrow until Maintenance appears and press OK.
3. Press the left/right arrow until Supplies Life appears and press OK.
4. Press the left/right arrow until the item you want appears and press OK.
• Supplies Info: Prints the supply information page.
• Total: Displays the total number of pages printed.
• ADF Scan: Displays the number of pages scanned using the ADF.
• Platen Scan: Displays the number of pages scanned using the
scanner glass.
• Imaging Unit, Transfer Belt, Fuser, TransferRoller, Tray1
Roller: displays the number of pages printed each item.
5. If you selected to print a supply information page, press OK to confirm.
6. Press Stop/Clear to return to ready mode.
when you reach the imaging unit reset it then try, it should work then
May 19, 2011 | Samsung CLX-3175FN Printer
WHEN CAMERA IS TURNED ON THE SCREEN WILL SHOW PAST PICTURES FINE BUT WHEN THE SELECTOR SWITCH IS MOVED TO EITHER TAKE A NEW PICTURE OR TO THE MOVIE MODE THE DISPLAY SCREEN IS BLACK WITH LIKE PURPLISH LINES...
From your description, it sounds to me like the image sensor within the camera went bad.
This can happen from a few things:
  • Camera dropped
  • Moisture
  • Rattling around in a bag or suitcase
  • Knocking into things while in the pocket
  • Leaving it powered on in the pocket
  • Prolonged exposure to bright lights
Try taking a picture while the camera is in picture mode even if you can't see what it is of, then either review the pictures to see if what you just took shows up without issues or transfer it to your computer.
If you can see a picture afterwards when reviewing your images, then it sounds like the firmware may have gotten corrupted. In this case, you should update the cameras firmware using this LINK.
If you cannot see the image you just took, or it has those same purple lines, then it is a hardware problem and can only be fixed by replacing the camera or by sending it in for repair.
Even if you cannot see the image you just took, I would suggest going ahead with the firmware update to see if it works.
Mar 01, 2011 | Sony Cyber-Shot DSC-T1 Digital Camera
''Unable to display this image'' error on Pentax Kx
Sounds like some of the spaces on the card are becoming corrupted. How do you download? With the camera and USB cord, card inserted into reader on computer, or card inserted in a separate card reader? When you are finished downloading, do you use the "safely remove hardware" icon at the bottom right of your computer screen or do you just yank out the cord or card thereby causing the corruption?
Feb 11, 2010 | Pentax Kx Body Only Digital Camera
DSC-T1 Digital Camera Display vertical fine lines
Its problem of bad ccd imager is your Sony DSC-T1 camera and this part will be replaced.
Sony will repair this camera for ccd imager problem as per announced scheme.
Please click Sony CCD Imager Support for details.
Apr 01, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Display of my Cannon Power Shot SD 630 Digital ELPH: NO IMAGE
i think you camera,s software is corrupted
go your canon customer center for repair it
Dec 14, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Lines
hi peter,
Video will not be able to display the dark lines becoz its samling rate is low and so it cannot display detailed image.
With your 6 MP camera , the reason for the images having dark lines is that,
The SENSOR present inside your digital camera may have been covered by dirt or it may have some lines over it. so it is obvious for the images to reflect that.
So i suggest you to check the sensor with your service center.
Else you can refer to this website for more support www.samsungcamera.com/customer/faq/cus_faq_list.asp
Hope this works...
Thanx peter.
Sep 20, 2008 | Samsung Digimax S600 Digital Camera
"Unidentified Image"
you need some image recovery software that will fix the files that are corrupted
May 29, 2008 | Canon PowerShot S3 IS Digital Camera
Can't see the image in PC
It sounds like the images are corrupted. On many cameras, a camera-only preview is also stored alongside the image file, so the camera can quickly display the preview without having to spend time decoding the image file. When you try to apply the zoom, the camera is actually trying to decode the image, which fails because it is corrupted. This might be due to low battery (unlikely), or bad memory. You might try replacing your memory card.
Feb 15, 2007 | Samsung Digimax S500 Digital Camera
ASUS Extreme AX300SE-X/TD RADEON X300SE, (128 MB) Graphic Card Logo
98 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
