Question about Sony Ericsson C510 - Pay Monthly Cell Phone
Charging point on phone has corroded so wont charge
  • 64 Answers
Try and scrape away the corrosion with a needle or pair of tweezers.
hope this helps.
Posted on Oct 21, 2009
My phone wont turn on or charge
If it's not charging to the point where it drain the battery, then you could have a damage port in the iPhone. With that said, your device needs to be taken apart to replace the charge port. The part looks something like this image. 94f565a2-1793-4597-9cb5-3ef99270148b.jpg
This one is for an iPhone 3gs, but you get the idea. Best of luck.
Mar 15, 2014 | Apple iPhone Cell Phones
My PSP wont charge
Continuous charging of a battery will cause a battery to loose its zero point.
Also battery's do not react well in the mouths of little boys this will also cause a battery to corrode as well as loose its zero point.
You may need a new battery
Dec 11, 2013 | Sony PlayStation Portable (PSP) Console
My 1998 chevy lumina wont charge new alternator and battery all been test but still wont charge drive about 1 hour and battery light come on any idea
the heavy lead from the back of the alternator goes to the battery. this lead charges the battery and is probably loose or corroded at one end or the other.
Oct 13, 2013 | 1998 Chevrolet Lumina
Battery wont stay charge
several possibilities here... always try easiest/cheapest first.. A. loose or corroded battery terminals. B.check water level in battery , add if low then try a charge..C. could be bad cell in battery have load tested, and finally D. alternator may be putting out inadequate charge, have checked
Sep 27, 2012 | 2003 Kia Optima
Nokia e63 phone wont hold a charge
is the phone new? as it could be a problem with the battery, maybe it got wet or the copper on the battery corroded.
Jun 08, 2011 | Nokia Cell Phones
I think my battery was low but my iphone has gone off and wont charge or turn on, any help appreciated
Bad Charging port, did you get your phone wet at some point? check for corrosion in your charging port.
Nov 11, 2009 | Apple iPhone Smartphone
Razr v3 wont charge
Dear jayhawk9977,
Since the AC is fine (tested) then the phone is probably faulty at the Mini-USB connector. Please check if there is play at this point as a broken (damaged that is) connector will not perform any function. (Test is as well with your handsfree if any) If there is no audio at this point 99% is the connector.
Surely the pins that are used are not the same for charging/handsfree but you can get an idea if the problem is bigger than thought initially.
Problematic batteries can also lead to non charging. 3.6-3.7V (+0.3V) is nominal voltage that the battery works. (if you have a multimeter please test it as well)
Many regards
Please rate this solution if you found it useful.
Apr 02, 2008 | Motorola Mobility RAZR V3
Sony ericcson w810i
Brother it seems your phone's software problem. Such problem can be occured due to removal of battery in it's active mode or use the phone in less charged battery. Solution is to reflash it with new files...Any good technician with understandign of sony-erric's CID security and nice tools like Universal Box, SE TOOL can do this for you but he will charge you for that. It is not possible to do anything without tools, tools and rather costly.
Jan 11, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Phone charging
if you have a correct charger then the problem might be in your phone. i request you to give your phone to an authorised dealer. because the charging point in your might have broken or bent.
Jan 06, 2007 | Sony Jabra Earbud Headset - Ericsson T610...
Sony Ericsson C510 - Pay Monthly Cell Phone Logo
104 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
