Question about Philips 55PP9401 55" Rear Projection Television
COLORS ON BOTTOM LEFT SIDE
STARTED SMALL NOW IT'S A LOT LARGE.
  • 8,596 Answers
You probably have a problem with your convergence board. Try resetting the convergence manually on your TV - go to Philips website for instructions on doing this if you have lost the Quick Start Guide. If the manual convergence fails, then your convergence board needs to repaired or replaced.
Posted on Feb 19, 2008
Need to know how to wire the compressor contactor on a rheem rpmc-024jaz
Normally all your colors should be together, black wires on right, red wires on left. But without knowing what wire belongs where you could damage a compressor over a $20 part. Your common wire to comp goes on 1 side of line. There should be 3 wires leading to comp. The 2 large wires go to contactor and small wire to herm side of capacitor. The fan motor should have 3-4 wires. The black and white go to contactor. Black wires on the same side of line/contactor. These colors may be different depending on what you have. The line voltage wire feeding the units power will be on the entering side and all others will be on the leaving side of contactor. The control wires will go to the coil of contactor. This is a simple process for an experienced tech and shouldn't cost a lot to call someone out. Always better to be safe! Hope this helps
Mar 03, 2017 | Heating & Cooling
Need emachines t3306 motherboard connection diagram
The eMachines T3306 desktop computer, uses the FIC K8M-800M motherboard.
First International Computer, (Inc)
http://www.fic.com.tw/product/motherboard/amd/ficimages/k8m-800m.jpg
http://www.fic.com.tw/product/motherboard/amd/k8m-800m.aspx
Here's the download page for the motherboard manual,
http://www.elhvb.com/mboards/OEM/eMachines/manuals/index.html
Column in middle, 3rd file from bottom.
This is a Zip file. A Zip file is a Compressed file. Used to send large amount of information more easily.
Has to be decompressed, or 'unzipped'.
After you click on the blue -> FIC K8M-800M file name, a small window will come up-
Opening K8M-800M_manual.zip
Make SURE there is a Green dot in the small circle, to the left of Save File.
IF not; click in the empty circle to the left of Save File.
No go below in the small window, and click on OK.
A small download window will come up.
Allow the file to fully download all the way, then DOUBLE-click right on the file name.
(Yellow folder icon with a zipper on it. K8M-800M_manual.zip is to the right)
In the next small window go to the far Left, and click on -
Extract all files.
At the bottom of the next 3 small windows click on Next, Next, and Finish.
In the last small window DOUBLE-click right on the file name ->
K8M-800M_manual
(Next to the red Adobe PDF icon)
There is your motherboard manual in PDF file form.
For an example;
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to; is the Front Panel header.
Motherboard installed in computer case, the Front Panel header is at the Bottom/Right.
The Front Panel header is Orange in color. (Page 20)
Two rows of contact pins.
5 pins across the Top row.
4 pins across the Bottom row.
The Top row is numbered ODD.
The Bottom row is numbered EVEN.
Starting on the RIGHT side going across to the Left; Top row,
Pins 1, 3, 5, 7, and 9.
Starting on the RIGHT side going across to the Left; Bottom row,
Pins 2, 4, 6, and 8.
A) Pins 1 and 3 are for the HarDDrive activity LED light.
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the Harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected.
Reserved for factory use. Probably a 5 Volt test point.
D) Pins 2 and 4 are for a Power On LED light.
These two pins are used for a Single color, Power On LED light.
Two wire LED light.
Pin 2 is for the Positive ( + ) wire.
If the PWR LED is dim when the computer is on, switch the wires around.
There is ALSO a jumper used for this LED light. More on it at the end.
E) Pins 6 and 8 are for a Power On switch.
To the Right of the Orange Front Panel header, (F_PNL), is the PW_LED header.
[Page 20 to right of Front Panel header. -> PW_LED
(Power LED, 2/3 Pins) ]
3-pin Black header. Sits Vertically.
(The Orange - Front Panel header, sits Horizontally)
This is used for a 3-wire Power On LED light.
Used for a Dual Color - Power On LED light.
One example is if the computer has Turbo Mode, and Normal Mode.
Green color usually for the Turbo Mode, Yellow color of the LED for the Normal Mode.
Starting from the BOTTOM going UP;
Pins 1, 2, and 3. (3 at the Top)
A) Pin 1 is for the Positive ( + ) wire. [Signal]
B) Pins 2 and 3 are for the Ground wires.
Jumper block for the 2-wire Power On LED light, and 3-wire Power On LED light; Page 13 - Set System Jumpers
(Actually it starts on Page 12)
6-pin header to right, of 3-wire Power On LED header.
Has Blue jumper caps on it. Two of them.
(PL_LED1)
http://www.ebay.com/itm/NEW-FIC-uATX-Skt-754-AMD-Desktop-Motherboard-VIA-K8M800-AGP-4x-8x-DDR400-800FSB-/280923928691?pt=Motherboards&hash=item41685ef873
Two rows of 3 pins.
The bottom row is numbered EVEN.
Starting on the RIGHT side going towards the Left; Top row,
Pins 1, 3, and 5.
Starting on the RIGHT side going towards the Left; Bottom row,
Pins 2, 4, and 6.
A) With the jumper caps on Pins 3 and 5; plus 4 and 6; the Power On LED light works as a Single color LED.
B) With the jumper caps on Pins 1 and 3; plus 2 and 4; the Power On LED light works as a Dual color LED.
For additional questions please post in a Comment
Regards,
joecoolvette
Mar 07, 2013 | Computers & Internet
Wiring MSI ms-7641
http://www.msi.com/product/mb/760GM-P34--FX-.html
http://www.msi.com/product/mb/760GM-P34--FX-.html#/?div=Manual
Under the Download subheading click on the blue -
M7641v4.0.zip
Click on the 'country' name nearest yours.
(U.S. is a country, the others Europe and Asia are continents)
A small window will come up -
Opening M7641v4.0.zip
IF not; click in the small empty circle to the left of Save File.
Go below in the window, and click on - OK.
Allow the file to download all the way, then DOUBLE-click right on the file name.
(Yellow folder icon with zipper on it, and M7641v4.0.zip next to it)
In the next small window go to the far left, and click on -
Extract all files.
At the bottom of the next 3 small windows, click on Next, Next, and Finish.
7641v4.0(G52-76411X9)(760GM-P34_760GM-P24_760GM-P2...)
(Zip file.
A Zip file is used to send large amounts of information more easily.
It is a Compressed file.
You need to 'unzip' it, or decompress it )
(Adobe Reader uses PDF files)
The Adobe Reader page number box is at the Top, to the right of the Down Arrow.
When I refer to a page it is for that page number box.
Clicking on the Zoom In icon at the Top ( + ) Increases the view size.
Clicking on the Zoom Out icon ( - ) Decreases the view size.
The area of contact pins on the motherboard, that the Main wires go to, is the Front Panel header.
Example; Front Panel header pinout:
The Front Panel header is two headers on this motherboard.
Go to Page 11.
Here at the Bottom/Right of the motherboard you see the 6 SATA connectors; all of them Black in color.
To the immediate Left of them, and situated Horizontally; is JFP2.
Junction Front Panel 2.
Two rows of pins.
To the immediate left of JFP2 is JFP1.
It is also situated Horizontally.
Two rows of pins.
JFP1 has two rows of contact pins. 4 across the Top, 5 across the Bottom.
The Top row is numbered EVEN. The Bottom row is numbered ODD.
Starting on the LEFT side, going towards the Right, Top row;
Pins 2, 4, 6, and 8. There is NO Pin 10.
Starting on the LEFT side, going towards the Right, Bottom row;
Pin 1 is for the Positive wire.
C) Pin 9 is N/C. Not Connected. This is reserved for the factory. Probably a 5 Volt (DC) test point.
D) Pins 2 and 4 are for a Power On LED light, and TWO wire.
E) Pins 6 and 8 are for the Power On switch.
F) There is NO Pin 10.
Junction Front Panel 2. (JFP2)
The Top row has 4 pins, and they are numbered EVEN.
The Bottom row has 3 pins, and they are numbered ODD.
Pins 1, 3, and 5. There is NO Pin 7.
A) Pins 1, 3, and 5 are for a THREE wire Power ON LED light.
This type of LED light is a dual color LED.
In the past, and one example; it may have been used for computers that had Turbo Mode, and Normal Mode.
Turbo being Green, Normal being Yellow.
(Which was a bunch of hooey.
Turbo Mode was the Normal mode, and Normal Mode was a slowed down version)
Pin 1 is for the Negative ( - ) wire. Also can be said as the Ground wire.
Pins 2 and 3 are for the power wires, (Positive + ), and each color.
(Example:
Pin 2 for the Yellow side of the dual color LED, and Pin 3 for the Green side of the LED.
Light Emitting Diode. So stating LED -> light is kind of redundant)
B) Pins 2, 4, 6, and 8 are for an internal speaker.
Used to hear BIOS Beep Codes.
If there is something you do not understand, that you need for connecting cables, and peripherals; post back in a Comment.
(A Harddrive, and Optical Drive, are also Peripherals. Not just the Mouse, Keyboard, Printer, Monitor, etc)
Regards,
joecoolvette
Mar 04, 2013 | MSI Computers & Internet
Hi, I have a Philips 60PP9202/17f 60in. Picture is just fine but the audio went out. Is there any problem shooting I can do at home?
Other than making sure in menu speakers are not switched to OFF no.
As seen from rear of set there are 3 large boards, the large one to far left (rear view) is the small signal board, plugged into that near the rear is a about 4x6 inch small board--small signal MODULE.
The module (SSM) is the most common cause of all sorts of problems---no sound, sound goes out after a while, Remote control may not work----a lot of different things----it controls all sorts of things and a lot of them go bad.
It will have the part number printed on it---a few years ago they were selling for about a hundred dollars---double sided board with surface mounted parts, our shop owns most of them--only easy way is unplug that board (held in socket with metal clips at bottom on either side) and clean the contacts in the socket and on the board.
better than a 95% chance the board is bad----In the years since the set was first made I have had to replace over 3 dozen and most had no sound or the remote would not work.
Dec 17, 2012 | Televison & Video
I have this model and its been giving me probem with the picture coming on and if it came on only half the picture come on
It sounds like the inverter board for that side of set is bad(uses either one large or two small boards--if two small the one for that side is bad OR the main display panel itself is bad.
Seen more than a few of this brand come on with picture on one side and then the other side gets real bright for a few seconds and set shuts down.
Shutdown circuit will detect something is drawing a lot of current and shut set off.
This if the display panel itself is bad will not be worth fixing.
Some Plasma sets have same issue and use names like sustain board etc for the same function--they drive the display panel left side, right side or top and bottom.
Apr 12, 2012 | Philips 47PFL7403D 47 in. LCD TV
It is saving to sm side of the hrad drive ng the lg side
i don't understand what you mean by the large side or small side if your going by the the pie shaped colors thats just showing you how much it has and how much is left to use
Mar 22, 2010 | HP TouchSmart IQ770 PC Desktop
I need a diagram of a 2004 suzuki forenza Serpentine Belt
That's easy, there are some pulleys with ridges to grip the underside of the belt, and some are smooth for the top side of the belt.
I can only assume your belt broke and fell off so you couldn't see how it was on prior. But either way you have limited length, and the last place you would be routing the belt is the tensioner, which you should have located first, so you can have a wrench handy to fit it.
Here's what you have:
Top left= alternator (small ridged)
top right = power steering (large ridged)
Bottom right = AC compressor (large ridged)
Bottom middle = Crank Pulley (large ridged)
In middle next to Power steering = Tensioner (small shiny smooth)
Remove the air cleaner housing (two bolts)
Start on left top side and loop belt (clockwise) across the alternator to the power steering down to AC (also clockwise from right to left) then over to crank pulley (from bottom clockwise around to top of pulley) to tensioner (smooth, belt is backwards on it) which will go back up to the alternator.
At the top middle there should be a sensor protruding from the timing cover that the belt passes under as it connects between the alternator and the power steering. And you won't easily be able to fit anything besides a box-end wrench on the tensioner, so you may need some kind of extension on the wrench to get good torque on it without hurting yourself.
Aug 31, 2009 | 2004 Suzuki Forenza
WHERE IS THE FUSE FOR THE JANOME MEMORY CRAFT 9000? THANK YOU
Remove the top cover by taking the two large screws and the small one under the handle, LHS.
Remove the left side cover. The hidden screw is a 2.5mm allen accessed through the vent.
Lay the machine on its back and remove the four large phillips screws on the bottom and the small screw for the side, paying extreme caution with respect to the embroidery arm.
CAREFULLY move the bottom to the left and out of the way.
Inside the body of the machine you will see a black box held in place by three or torx/slotted screws. Remove the screws and, as you slowly pull the box out MAKE NOTE OF WHICH WIRES PLUG IN WHERE.
Jul 11, 2009 | Janome Memory Craft 9000 Computerized...
Arc or hump on bottom left of tv and color is faded bad.
Your convergence Ic's have gone bad. Most likely a few small resistors with them. It's really not a job you should try and takle if you haven't done it before. Not a major deal for a svc co.
Feb 05, 2009 | Philips 60PP9202 60" Rear Projection...
Hp color laserjet 2820. Low on something. Icon next to toner colo
If you are talking about the icons under the little display first four are the toners the one on the far right is the drum unit it has a small solid circle with a large bar going through it rounded at the bottom & has like a fish tail on the top goes top left to bottom right.
Dec 31, 2008 | HP LaserJet 2820 Printer
Philips 55PP9401 55" Rear Projection Television Logo
56 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
