Question about Beyerdynamic Audio Players & Recorders
Where can we buy ear cushions for the DT100 headphones?
SOURCE: Need instructions for replacement of headband and ear cushions.
It should be easy - I just eased mine out by pulling on the top and bottom parts of the headphone cushion/pad.
Hope that helps
Posted on Nov 27, 2008
Grubhead
  • 5056 Answers
SOURCE: beyer dynamic dt 100 headphone 400ohms. There's
It could be that the Earth connection has become detached in the cable or plug somewhere!
Posted on Oct 29, 2009
SOURCE: How can I fix an intermittent sound problem on the
I have the same problem. The first one that I bought last 1 year. I bought another one and the same problem has appeared today. I think this is because they are assembled in China. Cheap and low quality manufacturer that is sold at very high prices.
Posted on Jun 14, 2010
Grubhead
  • 5056 Answers
SOURCE: Sony MDR-V300 Ear Cushions
Yes a firm on E-Bay sells the cushions.
Posted on Jul 11, 2010
  • 3 Answers
SOURCE: koss td-61 headphones
Koss offers a limited lifetime warranty. They may replace them for you. See:
http://koss.com/koss/kossweb.nsf/warrrepair5?openform
I have the same problem with my UR30 which have not been used very much and this is the path I'm going to try. Good luck!
Posted on Nov 26, 2010
How to clean my white solo 2 beats headphones ear cushions?
hi. remove the cushions from the headphone and use a wet cloth with a little liquid soap and water, do not make too wet and do not get water into the headphones. alternatively you can buy replacement cushions for this headphone via the internet cost about 15 dollars us.
I hope this was useful.
Feb 24, 2015 | Audio Players & Recorders
Severe squelch in left ear phone
The design of these headphones includes a microphone on the outside and on the inside of each earcup. The outside microphone detects outside noise. The inside microphone monitors what you are hearing and when it detects that the outside noise is present inside, the active noise-canceling circuits remove that noise. This happens fast enough that you perceive a significant reduction in the outside noise getting to your ears.
The airspace inside the earcup is a tuned chamber defined by the shape of the foam in the ear cushion. This is important because with the inside microphone in close proximity, but at a 90-degree angle to the speaker, the circuit must be designed to eliminate the normal feedback that occurs.
If the foam in the ear cushion has weakened/deteriorated to the point that it no longer has it's original shape, (in particular the lower half of the ear cushion), the size and shape of the air chamber inside of the earcup is directing more of the speaker sound toward the microphone than the design can compensate for causing audio feedback to occur. You are hearing that feedback.
On my QC-3 headphones, I can cause the feedback squeal in both earcups, with the left earcup being more sensitive to the shape change than the right.
It is probably time to replace the ear cushions. If so, they are available from Bose for $35/pair.
QuietComfort 3 Acoustic Noise Cancelling Headphones Bose Product Support
They are also available aftermarket at Amazon.com for $16.99/pair
Replacement Earpad ear pad Cushions For Bose QuietComfort 3 QC3 Headphones...
or $5.69/pair.
Bluecell Pair of Replacement Earpad Ear Pad Cushion for Bose Quietcomfort...
Aug 29, 2013 | Bose QuietComfort 3 Acoustic Noise...
Ear cushion is off the product at time of purchase
You can try returning the headphones to the store for replacement but if that doesn't work the cushion can be reinstalled unless it is damaged
May 31, 2013 | ifrogz EarPollution Plugz Headphones
How to replace ear cushion on bose QC 3 headphone
The ear cushions are held on the earcup with six snap fasteners, three on each side. To remove the ear cushion, simply pull it away from the earcup carefully so that you do not break the plastic snap tabs.
It should not be necessary to pry the ear cushion off with a sharp object, but if you do, be careful. There is also a thin gasket seal between the earcup and the ear cushion, take care not to damage it.
If you need to replace the ear cushions with new ones, they are available from Bose for $35/pair.
or $5.69/pair.
Apr 02, 2013 | Bose QuietComfort 3 Acoustic Noise...
Ear pads falling apart
Please follow the proper instructions below
Ear cushion reattachment
If the ear cushions come off your headphones,
reattach them as follows:
1. Fit the mounting flange inside the rim of the ear cup.
2. Make sure it attaches smoothly and uniformly within the entire ear cup. (Do not remove the ear cup lining material).
Ear cushions may need to be replaced due to normal wear and tear. To order replacement ear cushions, call 1-888-865-2700.
Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 15, 2011 | Bose 41213 Headphones
I have had my headsets for 3 years, they work well, I have just noticed that the left ear pad is detaching from the base. How do I get fixed?
The ear cushions are attached to the earcup with plastic tabs that snap into the plastic in the earcup. The lower snaps may be unfastened. Try pressing the ear cushion firmly to the earcup around the lower edge to refasten the snaps. Do not press in the middle of the ear cushion - you may damage the internal microphone.
If this fails, you will need to remove the ear cushion by pulling it off the earcup and inspect for broken plastic where the tabs are on the ear cushion or where the tabs attach to the earcup. If a tab is broken on the earcup, replacement earcups are available from Bose for $35 per pair.
http://www.bose.com/controller?url=/shop_online/headphones/noise_cancelling_headphones/accessories/qc3_earcushionkit_acc.jsp
If the plastic in the earcup is broken, you can try to repair it or you can contact Bose about getting it repaired or replaced.
Jun 11, 2011 | Bose QuietComfort 3 Acoustic Noise...
Jun 21, 2010 | Sony MDRV300 Professional Headphones
I lost one of the ear cushions of my insignia head phones
hi u can get these ear cushions in all bluetooth  accessories shop...
Feb 09, 2009 | Insignia Bluetooth Wireless Headphones...
Hope that helps
Mar 27, 2008 | Sennheiser HD 600 Consumer Headphones
Top Beyerdynamic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Beyerdynamic Audio Player and Recorder Expert? Answer questions, earn points and help others
