Question about GE GSS22JF Side by Side Refrigerator
Loud noise from GE Side by Side
I don't know if it is the motor or the self-defrost. Maybe it is a fan. Anyhow, when the refrigerator is through running whatever cycle it is there is a loud noise for a second and then it goes away. It never made the loud noise before. It sounds like something is shutting off when the cycle has ended. Can you tell me what the cause is? How can I remedy this?
  • 4,059 Answers
That's usually mounts inside the compressor. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
Posted on Oct 07, 2009
Right Door is making loud popping noise
HI,
Noise can come from these areas:
The inside of the freezer
The outside back of the refrigerator
The bottom of the refrigerator
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting).
  • The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
  • If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.
  • The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Aug 22, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My LG ice maker fan is making a really loud noise right after the water stops going in
Hello, Self-defrosting refrigerators use a circulating fan to move air through the freezer and refrigerator compartment. This fan runs when ever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall,near the top or bottom, in the center of the freezer.
  • If the freezer is on the left, the fan is on the back wall, half way up or near the top.
Overtime the fan may become noisy, usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise,just open the freezer door and push in any fan/light switches, if the noise is louder when the door is open, the evaporator fan motor is the cause. You can lubricate or repair this motor. You must replace it.
There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor(if self-defrosting), or the defrost timer (if self-defrosting).
Thanks
Jun 17, 2010 | LG LSC26905TT Side by Side Refrigerator
It's making a loud running noise
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows: If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer. If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer. If the freezer is on the left, the fan is on the back wall, halfway up or near the top. Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead. To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
Mar 31, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refridgerator make a noise every 3 minutes
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
Mar 29, 2010 | Kenmore 56539 / 56532 / 5653 / 656534 Side...
GE Refrigerator GSS201EPWW is making a loud noise
This is the fan motor making noise but the fan motor is probably ok. The main board supplies voltage to the motor and can cause it to make strange noises.
Feb 27, 2010 | GE GSS20IEP Side by Side Refrigerator
Water is coming out in the refrigerator
You need to investigate properly.Let me provide with How you need to look forward. This is an interesting article i took from internet for you :-
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows: If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer. If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer. If the freezer is on the left, the fan is on the back wall, halfway up or near the top. Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead. To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it. The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem. The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Let me know, if need any assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer fan noise
Remove the freezer panel to access the fan motor. Look for any obstruction around the fan or blade. Ice, misplaced wire etc.
Check the fan blade. Sometimes they slip down the shaft too far.
If you find none of these issues, replace the fan motor.
May 25, 2009 | GE GSH25JFR Side by Side Refrigerator
GE side by side Refrigerator makes LOUD SQUEAK when running
Mar 24, 2009 | GE Refrigerators
Ge eterna refrigerator loud humming
suspect you have a problem with the defrost system and hence the noise with the fan. take back panel off inside the freezer and if i'm right, melt ice off with a hairdryer. get back to me to say the results if you want
Aug 23, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE GSS22JF Side by Side Refrigerator Logo
195 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
