Question about Canon PIXMA MP160 All-In-One InkJet Printer
Error E27 when you put the printer on it shows E27
    President:
  • 1,653 Answers
Removing & Cleaning the Absorbent pads.
The printer has 2 ink absorber pads that are located under the ink cartridges.
With power off the head assembly / cartridges can be moved into the middle for access.
Each of the 2 ink absorber pads are seated in a rubber retainer. The pads can be easily removed cleaned or replaced.
Carefully remove the pads using long nose pliers or tweezers.
Clean the using with running warm water, or use an isopropyl alcohol bath, or an isopropyl alcohol based aerosol if they are really dirty. DO NOT USE ANY SURGICAL SPIRIT OR ANY OIL BASED CLEANERS. At a push you can use a warm water mild washing up liquid bath but be sure to thoroughly rinse out the solution after cleaning. The pads should be white when they are clean.
Dry the pads – it may take some time and placing them in a warm environment or near a warm radiator will speed this up.
Clean away any ink on the retaining rubbers using a cotton bud or clean and soft lint free cloth.
Replace the DRY pads in the rubber retainers.
Replace the Ink cartridges.
Power on the printer and print a test page and clean and realign the heads as required.
If the E27 error message reappears then you will need to reset this.
Clearing procedures for E27 or Error 27 Code.
Power on the printer by pressing the Power button while pressing and holding the Stop/ Reset button.
When the Power led is green press the Stop/Reset button two times while pressing and holding the Power button.
When releasing the Power and the Stop / Reset buttons the printer will move into a service mode and will be Waiting for a menu selection.
When the Power led is green, press the Stop/Reset button 4 times for waste ink counter reset.
Posted on Oct 07, 2009
    Sergeant:
    Champion:
  • 310 Answers
There are a couple of links that could help you on this ..
http://slayo.com/resetting-error-e27-waste-ink-absorber-full-canon-pixma-mp150mp160.html
www.youtube.com/watch?v=KcSyC7lKbGQ
Thanks
Ranjit
SOURCE: Error code E27
I've tried the solution recommend and it took me to do the process 4 times than only the error code disappeard.
Posted on Jul 16, 2008
thebrain1
SOURCE: how can i solv E27
Is this a tech thread or a post the obvious thread? It's obvious that the counter needs to be reset , but how do you reset it?
Posted on Nov 22, 2008
Metawatch
  • 96 Answers
SOURCE: error E27
Chek this link
Defines the problem and solution
http://www.coldreset.com/modules.php?name=News&file=article&sid=1078&mode=thread&order=0&thold=0
Posted on Feb 09, 2008
SOURCE: my printer MP140 shows error E27
How to clear E27 canon PM140
Posted on Dec 04, 2009
  • 4 Answers
SOURCE: My printer MP140 Shows error E27
How to clear E27 Waste ink absorber full
1.With the printer powered off but connected to a power source,
press the Power button while pressing and holding the Stop/ Reset button.
2.When the Power is lit, press the Stop/Reset button two times
3.When releasing the Power button and the Stop / Reset button (regardless of order),
the printer will move into a service mode. (Waiting for menu selection)
4.When the on/off lights in green, press the Stop/Reset button the
specified number of time(s) according to the function listed in the table below.
(Each time the Stop/Reset button is pressed, the LED lights alternately in orange
and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print (auto teste)
2 times Green EEPROM print (dados da EEPROM)
3 times Orange EEPROM reset (EEPROM reset)
4 times Green Waste ink counter reset (Absorvente reset)
5.Turn off the printer.( it must be turn off) then turn it on again.
Hi, my printer mp145 show error E15 after I reset the error E27. I hope you can help me. Thanks.
This maybe will help
http://electronics-repairguide.blogspot.com/2011/07/error-e27-on-canon-mp198mp258-ink.html
Mar 04, 2014 | Canon Office Equipment & Supplies
Tip
Use this method with your own risk!! E2-2 = No paper (ASF) E3-3 = Paper jam E4 =...
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Reset E27 Waste ink absorber full or platen waste ink absorber full for Mp140
turn off printer.
- put your finger and hold on/off with reset/stop button together
- turn on printer power switch
- release on/off button but in the same time still hold stop/reset button and then press on/off button again and hold.
- wait at the moment
- relese stop/reset button 2X.( your will see alarm led blinking for 2X)
- relese on/off button.
wait until your printer digital screen shows number 0.
- after printer panel screen shows number 0.
- press reset button 4x
- press on/off button 1x
wait until your hear printer roller is moving
after your hear roller moving, wait until your dont hear anything from your printer :)
then turn off and turn on your printer again and your will see your printer back to normal.
hopefully this can helped to solve your problems.
Thanks.
please leave your evaluation....
Extra download =====> Fix_ip1000_InkOverflow
on Jul 29, 2010 | Computers & Internet
Tip
True guide to reset ink tank absober full on canon mp140
E3-3 = Paper jam
E4 = No ink
Direct Printing
E22 Carriage error
E29 EEPROM error
turn off printer.
Ok world...Good luck
Thanks.
Extra download ====> Fix_IP1000InkOverFlow
on Jul 16, 2010 | Office Equipment & Supplies
Canon printer show error e27
what does the manual say about the error? there might be something physically blocking the printer or it might be a software error brother ink cartridges
Nov 07, 2011 | Canon PIXMA MP160 All-In-One InkJet...
How di I reset my Pixma printer MP150 from
E3-3 = Paper jam
E4 = No ink
Direct Printing
E22 Carriage error
E29 EEPROM error
First way
turn off printer.
- relese stop/reset button 2X.( your will see alarm led blingking for 2X)
Second Way
turn off printer.
Good Luck
Jul 18, 2010 | Canon Office Equipment & Supplies
I have canon mp 258 with error e27 how would i resolve it?
Canon error e27 ink absorber full/reset process
printer powered off but connected on power source , you must:
1. Press & hold stop/reset button, and then press & hold [ON/OFF] button.
2. When Green power lit, leave stop/reset button & press twice stop/reset (see orange indicator).
3. Leave On/Off button. Printer in actually service mode.
4. Press stop/reset 4 times (see orange indicator) if not blink restart above process from top.
5. After press stop/reset 4 times successful press On/Off button 3 times. printer will off.
6. Press On/Off button.
Jul 10, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
GETTING ERROR CODE E27, INK ABSORBER FULL
May 13, 2010 | Canon PIXMA MP160 All-In-One InkJet...
My printer mp190 problem E27 How do reset the error.plase help me.
E27 means waste ink absorbed is full need to clear out but you still can't print. ...1. Press MENU COPY SCAN COPY COPY
2. This will take you to TEST MODE
3. Use the + key to take you through to PRINTER TEST (option 8)(if you go past, either keep keying the +, or you can use the - to take you back)
4. Ensure that it shows 8-3 on the screen. This is EEPROM CLEAR
5. Press OK
6. It will show 0 INK COUNT
7. Press OK
8. Press the STOP/RESET button
9. Press the ON/OFF button
10. The printer won't turn off, but will "reset" itsel
Mar 20, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
437 people viewed this question
old marine
old marine
