Question about Cameras
My premier dc-6370 will only switch on for a few seconds then goes off again why and how do i get it to work
  • stephencarlt Oct 17, 2009
    Problem solved . I was using cheap batteries
Why does my aqua drive 1100 auto reset pool pump work in intervals of a few seconds.it goes on for a few seconds then stops and after a few minutes it goes on again
Check for restrictions causing the pump motor to be overworked.
Motor is overheating, the the Thermal Overload Switch senses that and will trip. Once the motor cools, it will restart.
Mar 11, 2015 | Aqua Pool & Spa
Dv4000 screen is on for a few seconds then goes black. Replaced screen balast and worked for 10 minutes, then went black again as before replacement. Should I replace the lcd screen?
No. The bulb is good. It could be the DC/DC invertor - that little curcuit board just beneath the in the LCD - or the video off the notebooks motherboard. - personal experiance points to that invertor
Feb 25, 2011 | HP Pavilion dv4000 Notebook
Viewsonic VX1932wm goes black after a few seconds of being on. I need to turn it off and back on to get a few more seconds, then it goes black again.
It probably has dying power supply due to bad DC filter caps, see pictures of fails VIEWSONIC due to bad caps at my Photobucket.com.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Nov 05, 2010 | ViewSonic Computers & Internet
I have a Norcold 2 way fridge. The propane will
It is possible that the switch is giving you fits. Easiest way to check is to find where the DC voltage goes to the circuit board. Put a meter across the connections and read the DC voltage.
A poor ground can also cause this as well, and is quite common. Remove the DC connections, and make sure that they are bright and shiny. Also make sure that the connections are tight, both in the wire, as well as any crimp connectors. Check for corrosion on crimp connectors in the sleeves, if possible.
Your 10second problem can also be attributed to another cause as well. The thermocouple electrode assembly is very sensitive to placement in the flame, as well as spacing of each "prong".
If you have a multimeter, also check the "AC" voltage as found on the DC supply. You should not have more than a few hundred millivolts of ripple (noise?) present. Very much more can cause erratic operation as well.
Aug 03, 2009 | Thetford Norcold Compact Refrigerator 1.7...
Hi my friend i have premier camera dc-505 i need software thank you
Are you looking for the driver for the camera? You can find that here.
http://cameras-and-mp3-player.free-driver-download.com/Premiere/48410/Premiere-Digital-Camera-DC-505-Windows-Driver.html
Thanks for coming to FixYa. Let me know if you need any further assistance. And don't forget to rate my answer a FixYa.
Rob
Feb 23, 2009 | Labtec DC-505 Digital Camera
Monitor comes on for a few seconds then goes blank.
Your looking at profesional repair. It could be DC/DC convertor, Monitor unit or PC/IF unit. (last two are expensive)
Jan 22, 2009 | Sharp LC-M3700P 37 in. HDTV-Ready LCD...
Denon AVR-1508 Receiver problems - cuts off and goes into protect mode
Usually when the unit runs for a while before shutting down there are two possibilities:
1) There is a small amount of DC current present that effectively heats up the speaker coils enough to cause a temporary short circuit that kicks in the protect circuit.
2) The output transistors or bias transistors are sensitive to heat and breaking down again causing the protect circuit to kick in.
A few experiments to try:
1) Does the time to shutdown change depending upon the volume level?
2) Is there any background noise coming from the speakers? Listen to a blank tape for example. Is there a hum or any other noise that you would not normally expect?
3) If you have a DC voltmeter, check for any voltage between the speaker lines.
Update this and we'll try to narrow this down.
Dan
Aug 18, 2008 | Audio Players & Recorders
Advent camera battery charger
Here's a list of cameras that use the same battery.
ADVENT:
ADV1172E
BENQ: BENQ:
DC C500, DC E43, DC E53, DC E63+, DC E720 DC C500, DC E43, E53 DC, DC E63 +, DC E720
KONICA MINOLTA: KONICA MINOLTA:
DiMAGE E40, DiMAGE E50 DiMAGE E40, E50 DiMAGE
PREMIER: PREMIER:
DS-4331, DS-4346, DS-5330, DS-5341, DS-6330, SL-6, SL-63 DS-4331, the DS-4346, the DS-5330, the DS-5341, the DS-6330, SL-6, SL-63
ROLLEI: ROLLEI:
Prego DP4200, Prego DP5200, Prego DP6200 Prego DP4200, Prego DP5200, Prego DP6200
Hopefully this will broaden your options when searching for a compatable charger.
Mar 23, 2008 | Cameras
Indoor Shots
try to adjust the mode in which you are taking the snaps....like NORMAL,DYNAMIC,USER,ETC
thanks
Feb 12, 2008 | Premier Electronics DC4311 Digital Camera
Cameras Logo
21 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
