Question about Apple AirPort Express (M9470Z/A) 802.11g/b (M9470ZA) Wireless Access Point
Trying to connect pc laptop to existing passworded Airport Express. Wants a "network key" - what is that, the Airport p/w doesn't work.
  • 2,260 Answers
HI,
You will need to find the network key on the wireless router.
Click Here to know how to find the network Key ?
Posted on Oct 07, 2009
  • Prashant M
    Prashant M Dec 05, 2009
    Click Here for Easy Set up Guide for step by step instructions.
    It will guide you with simple steps to resolve the problem in your network.
I'm trying to get a dynex DX-E402 to join my airport express
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Jul 01, 2010 | Dynex DX-E402 Router
Attempting to connect new Acer netbook to existing Mac network
Had the same problem. What i did was in the Airport Configuration program goto "Airport" then to "Wireless" and then to "Wirelesee options" In this menu deselect "Use wide channels". Also i decreased the power of the 5.0 Ghz transmission, because i don't use it yet. But i think the "Wide channels" is the reason of the problem. It is a bit weird thoug, on my Airports Guest acount with no password and incryption, the Acer One loged on perfectly, but on my private network with WPA2 it did not. Aparantly the Guest network does not use "Wide Channels" Hope this helps, but take care, maybe the menu's are called differendly because i had to translate them from Dutch. Good luck.
Aug 11, 2009 | Apple AirPort Extreme Base Station
I can't connect apple airport expresses with a siemens 587 route
Login to your airport express using Apple's airport utilities (either in it's current configuration or after resetting it).
Using the airport utility do not choose manual setup, just select continue.
Adjust (as required) the airport express station name and password and select continue.
Select "I have a wireless network and I want to add AirPort Express or replace an existing device on my network and select continue.
Select I want Airport Express to wireless join my current network and select continue.
Choose if you want to extent the rance of your network or just join the network and select continue.
Choose the network you wish to join... etc etc etc....
You should be fine.
Jan 31, 2009 | Apple AirPort Extreme Base Station
Need to find the network key
Open up your airport utility software.
Connect to the base station.
Under the main menus look for network equivalent password.
Nov 28, 2008 | Apple AirPort Extreme Base Station
Apple Airport Express not working
You need to use the AirPort utility, which will walk through the setup and configuration of it. You were already on the right track to get it going. If it mentions there is an update available for it, though, do the update first.
Jul 28, 2008 | Apple AirPort Express with AirTunes...
Networking a Printer on a wireless network
Deanna, if the mfc is not that old, take it back to the dealer and ask for changing it to a wireless printer (extension: CW). Do you really need the fax function? If not, try this printer: DCP 750CW. If yes, get the MFC 845 CW. The CN printer have to be connected directly to router or pc/laptop.
Sep 27, 2007 | Brother MultiFunction Center MFC-440CN...
New wireless network - now my airport express and airtunes does not work
Hi I was searching this site for a solution to a problem I am having and came across your post. I had the same issue and what I did was reset my airport express to factory settings (detailed in manual) - this enabled the Airport extreme to find/pair with it.
Sep 02, 2007 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Vista compatibility
Vista has very little drivers for equipment sad but true. However in your case you can use Airport Extream. However here is what an apple tech had to say: If you are a Vista user and you don't have access to a Mac, you will not be able to get this working. Apple hasn't yet stirred itself to release a version of Airport Express Assistant that works with Windows Vista - you can't set it up via Windows' own networking software and nor does the Airport Admin Utility work under Vista. It installs and you can run it, but it returns error messages if you try and connect to the Airport Express. I had to use a Mac to get it working, though once it's set up as a client to your existing wireless network, you can stream from iTunes on a Vista PC to the Airport Express. The documentation is very poor, too, with this: I had to do extensive Googling first to track down the fact that I couldn't set it up with Vista and second to identify the device's IP address and default password. Having said that, it is a breeze to set up via a Mac and works like a dream witih Vista once it's up and running. But don't bother if you have Vista until Apple updates the software. Was this review helpful to you?
Aug 23, 2007 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Apple AirPort Express (M9470Z/A) 802.11g/b (M9470ZA) Wireless Access Point Logo
354 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
