Question about Oreck Cordless Speed JP8100CA Iron
My iron is filled with water but won't steam - why?
The opening the water goes thru to the heat plate inside the iron may be clogged with hard water deposits or the switch may not be working properly.
Posted on Feb 11, 2010
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 72 Answers
No heat ! It's probably an electrical problem. If the electrical cord is connected to the iron properly, then it's probably one of the swithes to the iron.
Posted on Oct 07, 2009
satscoop
  • 59 Answers
SOURCE: Brown spots coming from steam iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
Posted on Nov 15, 2007
snakehead
  • 1074 Answers
SOURCE: My Tefal Steam Generater Iron will not steam
check the little tube that regulates the water to the holes it needs to be changed.good luck.
Posted on Apr 18, 2007
oscarn
  • 110 Answers
SOURCE: Water drips out of steam holes
I suspect that by placing it on its heel rest the water from the tank is not allowed to enter into the steam chamber and when you go into ironing mode there is a rush of water that is cooling down the sole plate to below steaming temperature. Try keeping it in the horizontal position on a heat proof pad and press the steam button just before going into ironing mode.
Posted on Sep 21, 2007
DiYerTech
  • 70 Answers
SOURCE: no steam comes out of iron
Hi, there is probably a something broken in the moulded plastic trigger assembly (there is a plastic broken finger that actuates a micro-switch under the rubber handle cover). If you are so inclined, use an orange stick and gently pry up the rubber handle cover on either side from the front to the rear cord end to access, inspect and troubleshoot. I am in SoCal and use the California Electric website to obtain parts or go to the Rowenta home website to locate useful manual information, PDF reader and dealer near you.
Posted on Jul 21, 2008
geokohler
  • 304 Answers
Fill with 50/50 water vinegar solution. Get it good and hot and let it sit for two hours. Rinse and repeat if necessary. Buy a gallon of water from the market and use that from now on. This will fix your problem. The Iron is concentrating the iron in you water and this is what is causing the brown spots. Hope you find this helpful. If you do please take the time to rate it fixya and maybe I will keep helping people for free.
George
Posted on Jul 24, 2008
Steam not working on iron then lots of water pouring out of holes
fill water chamber with vinegar and let it sit for 24 hours.
empty vinegar - fill with distilled water - turn on and press the steam button to clean the holes in the plate of mineral deposits which accumulate from using tap water. after a few shots of steam all should be clear - empty and refill with distilled water and it should be good to go.
May 08, 2012 | Tefal Pro Express GV 8120 Iron
Clean iron?
Hello tcant....
  • 1 Fill the iron's steam receptacle with white vinegar or CLR, a product used to clean coffee pots. CLR is available in department stores.
  • 2 Plug in and set the iron to its steam setting.
  • 3 Operate as usual. When the vinegar or CLR begins to steam, operate the iron as you would normally. Press it over an old, clean towel as the vinegar or CLR loosens sediment and dirt from the appliance.
  • 4 Continue ironing until all of the cleaning solution has steamed out. Repeat the cleaning process if necessary until the iron no longer oozes discolored liquid and the ironing surface is clean.
  • 5 Fill the iron steamer receptacle with distilled water and set the appliance to steam.
  • 6 Continue steaming until the smell of vinegar or CLR is gone.
  • 7 Prevent future mineral buildup by using distilled water for steam in your iron, rather than tap water. Joe. Thanks for choosing Fixya!
  • Jan 12, 2011 | Black & Decker ICR250 Iron with Auto...
    How can I demineralize my rowenta iron? I use carbon filtered water in it. The last time I used it white stuff came out of the steam ports and it sounded like there was sediment inside when I moved the...
    Fill the resevoir with a 25% vinegar to water solution & turn on the iron until it steams. Allow to cool and empty resevoir then rinse with clean water. Fill up resevoir and & turn on the iron until it steams again. Cool, empty & rinse again. DONE!
    Only use distilled or reverse osmosis water in your iron. This will reduce mineral build up.
    Nov 13, 2010 | Rowenta Irons
    Simac Stirelli 9000 steam iron spews rusty steam and smells like burnt apples
    Your steam iron has been filled with 'tap' water that may have been contaminated (thus the smell). Rust develops more rapidely in Steam Iron chambers when distilled water is not used: to clean the 'enclosure' of the steam iron from rust and smell, over a sink or outdoor, fill 'cold iron' with a 50/50 water/vinegar and a teaspoon of bicarb, let it stand for about 10 mins, then turn the iron on and let it steam the mixture out while shaking the iron gently (DO NOT BURN YOURSELF! STEAM IS HOTER THAN BOILED WATER!). Refill and Steam flush again with Clean water (distilled preferred). Repeat the steps until the rust has been completely dissolved (check by steam ironing on clean pieces of disposible kitchen paper towel. Use the Power steam or Flush function of the Iron if available. Hope it helps!
    Dec 17, 2009 | Irons
    Iron spits out rusty water. The iron is a Rowenta
    Fill it with a mix of 50% white vinegar and 50% water. Let it set for 30 minutes and steam it out for about 2 minutes. Unplug it and dump it. After it cools colpletely, fill it with water and steam it out. The rust is coming from your water supply, not the iron.
    Oct 06, 2009 | Rowenta Irons
    How to put water in the Tefal pro 2500
    This type of iron is called a steam station iron.
    The box is the water tank and it is this that you need to fill with water. You should be able to find a small spout on the water tank in order to fill it. These irons produce a huge amount of steam and should make the ironing a breeze once you get used to it.
    Feb 07, 2009 | Tefal Irons
    Water in iron box
    Yes... you can use it dry...
    Cleaning a Steam Iron White Scale and Brown Water
    http://www.fixya.com/support/r5300985-cleaning_steam_iron_white_scale_brown
    heatman101
    Aug 15, 2008 | Panasonic Cordless Steam Iron - White/Aqua
    Mold
    First with the iron cold fill the reservoir with white vinegar.  I would let this sit for a few hours and then pour the vinegar out of the iron. I would do this a couple of times until you see the mold is removed from reservoir. Next fill again with vinegar and run the iron on the steam setting, steaming a clean rag or towel until all of the vinegar is steamed out of the reservoir.  The vinegar will also remove any mineral deposits built up in the iron.
    Next rinse the reservoir by filling it with water and emptying it completely a few times.  Follow this by filling it completely with water again and setting the iron to steam setting.  Use another clean rag or towel and steam it until all of the water has been steamed out of the reservoir.
    In the future make sure to completely empty your iron after every use to prevent mineral build up and mold growth
    Aug 04, 2008 | Rowenta Perfect Iron
    How to use steam iron
    Fill the iron with equal parts white vinegar and distilled water. Place an oven rack over your sink and position the iron on top, with the steam vents facing down. Plug in the iron and turn it to the steam setting. Run it until the steam stops.
    Feb 23, 2008 | Micro Pro 7599 Iron
    Rowenta DA75 - Won't Steam
    Can you remove the steam button if you can fill with water heat to maximum and holding over sink remove steam button rod this will clean the steam traks but be careful this gets very hot.
    Thanks J
    Feb 10, 2008 | Rowenta Steam 'n Press DA75 Iron
    Oreck Cordless Speed JP8100CA Iron Logo
    1,514 people viewed this question
    Top Oreck Irons Experts
    Andrew Taylor
    Andrew Taylor
    Tom Chichester
    Are you an Oreck Iron Expert? Answer questions, earn points and help others
