Question about Toshiba 50H82 50" Rear Projection Television
Shakey Screen My tv picture started to shake about a month ago and has continued to get worse. Today when I turned the tv on the shake never went away. What can I do to fix the problem?
  • 2 more comments
  • HGTC Dec 24, 2007
    My tv picture shakes on cold start. After warming up a bit, the shaking stops. This problem started after I had to move the tv to install new carpeting; the tv was not dropped, shaken, or otherwise mishandled. This has been occuring for about a month; I noticed that it takes much longer now for the shaking to cease after startup. On warm startup, the tv shakes but hardly noticeable. TV has worked beautifully until now.
    I checked all the wiring; all hook-ups are correct.
    I refocused the image with the onboard matrix alignment sequence.
    Cable company repairman verified that service was not the problem.
  • Anonymous Dec 31, 2007
    I have the same problem. It has progressively gotten worse. Is there a way I can adjust V-hold?
  • FitNsFan Jan 12, 2008
    Having the same problem. Shaky screen on cold start and then after 10-20 mins of warmup the shaking stops. Have the 50 inch rear projection HDTV.
  • ftaboyz Mar 01, 2008
    I get severe shaky screen also on my 50H82.How many and how much are the 16v SMD caps (P/N24619040N) ?
    Sergeant:
  • 308 Answers
That problem is caused by defective capacitors on the Hyper Board location UZ01 stamped MVPU14. You will need to have a technican remove the board and replace all the 10 uF @ 16 Volt SMD caps p/n 24619040N found on that board. The Hyper board is no longer available as a part.
Posted on Feb 02, 2008
Two years ago I had the problem of the picture going away and coming back. With no repair that seemed to fix itself. Today after turning the tv on the picture and sound came on within 30 seconds the...
The problem has been there all the time, probably a dry solder joint or a bad chip, thats got worse over time & has now completly failed, its time for either a trip to the tv repair man, or the best option a nice new smart tv, i just bought a 42" for £199 why mess about.
Jul 30, 2017 | Sony KDS55A2000 55" HDTV
Vizio screen went white
Im sorry but did you figure this out yet. my tv just did this today too. it broke now.
Jan 28, 2010 | Televison & Video
The power comes on and then turns off and the front green power light blinks.
There is a small IC in the power supply section,
not the IC regulator that's the problem.
Jan 06, 2010 | Philips 32PT6441/37 32" TV
Toshiba 50H13 blurry picture with white line on right side
replace all the surface mounted electrolytic capacitors on the hyper module. also called the scan converter module. this is a common trouble. what a nasty job. good luck.
Jun 23, 2009 | Toshiba 50H13 50" Rear Projection...
Problem with RCA D52W20 HDTV rear projection television
Go to this site you need a flyback its the only onethey sell for an RCA number 259296 cost less than 50.00 and they provide free tech support so you can do the repair yourself which takes about a half hour. a repair shop will charge abut 400 to replace the flyback. heres the link
http://servicemanuals.vstore.ca/
Apr 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv picture is shakey
Bad capacitors on Hyper module = no longer available, but
can be rebuilt by PTS Corp or a qualified tech...........T.
Feb 13, 2008 | Toshiba 42H81 42" Rear Projection...
Toshiba 50H82 50" Rear Projection Television Logo
646 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
