Question about Symantec LiveState Recovery Standard Server 3.0 for PC
Error message trying to back up Drive to USB external hard drive
My hard drive has 3 partitions with Norton Ghost 9
Error message is OxEBAB001A
From the Norton Ghost manual how do I check disk management for missing or old volumes?
I have previously backed up drives C and D to the external hard drive with no problem using Ghost
Am only a very amateur amateur!
John from Devon
  • 729 Answers
Norton has a very good chat session and e-mail respond. I have the same problem with Ghost, It will not back up my pre-installed partition. :O(
You can also try to contact your computer support Team ( now I do not know which computer you have), If you give me the model and name i can provide the link to you.
Hope that helps
Have a nice day over there
IF NOT then return here
Please rate my answer
Posted on Oct 07, 2009
Not able to detect the disk
We're going to need more information to troubleshoot, but if it's a new drive that's never been set up follow the instructions below. If these instructions aren't helpful, then please post back with more info and I'll help you further.
Your external hard drive likely has no partitions so Windows has no drive to mount. Follow these steps to create and format a partition for your external hard drive.
1. Press Win+R to open the Run command.
2. Type "Control" into the dialog box.
3. Double-click "Administrative Tools."
4. Double-click "Computer Management."
5. Select "Disk Management" under Storage.
6. Find the 250 GB External Hard drive in the right pane.
7. Right click on the drive and select "Create new partition".
8. After the partition is created you will need to format the partition.
9. Format the partition as NTFS unless you plan on booting off the hard drive, in which case format the partition as FAT32. You can also create multiple partitions if you want.
10. Enter My Computer and you will now see your external hard drive.
Good luck and thanks for using FixYa.
Apr 04, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Error code: 0x10090
That means that you have a disk error caused by a bad cluster which in turn may cause you to have bad disk partition.
I would try to use a Disk repair software such as Norton Disk Doctor or if you have nothing too vital on it, I would consider reformatting your external drive (after making a backup if at all possible).
Dec 25, 2009 | Western Digital Passport 320GB External...
Error Copying old c: drive w/Ghost 9
Do a disk defrag on the source drive. If that doesn't work, you may have a virus on your source drive and norton ghost is catching before getting on your destination drive.
Nov 24, 2009 | Symantec Norton Ghost 9.0 for PC
Got message 10008 replace hard disk.
Your computer's motherboard has queried the disk-drive in your computer as to the "health" of the disk-drive, and the disk-drive is detecting that it is about to FAIL. So, ASAP, copy all your files to an external disk-drive, before the disk-drive DOES fail.
Buy a new disk-drive, attach it, and use something like NORTON GHOST or SYMANTEC PARTITION MAGIC to "clone" your old disk to the new disk-drive.
Then, disconnect and remove the old hard-drive.
Oct 29, 2009 | Computers & Internet
Is it possible to make a backup of everything on your hard drive to an external drive
Yes it is possible you can create image of your all partition in external drive with "Norton ghost" software.
Then you can easily restore image to harddisk again when you need.
You can download it from below link.
click here
Let me know if you need more assistance.
Thanks.
Oct 02, 2009 | Microsoft Windows XP Professional
WD 500 GB resized by Norton Ghost Restore to 120 GB and can not get it to original size.
You should partition your new drive first to say 160Gb (you lose a bit after formatting) for 1st partition and the remaining capacity for the 2nd partition. Because your Ghost image is 120Gb it can only restore to a partition of 120Gb, that is why it shows 120Gb on a 500Gb on a single partition.
You may be able to fix this problem without starting again by using Disk Manager (from Control Panel - Admoinistrative Tools) to create a 2nd partition on the hard drive and format this partition.
Apr 28, 2009 | Dell XPS M1210 Notebook
Cross platform backup drive format/partition
Fat 32 is the only system that would work on all 3 os's direcly.
You could use NTFS if you only write those big files on windows, you could read it on both linux and mac.
NTFS 250 (or ext2)
HFS 120
If you need to use the last partition on of the operating systems the fat 32 would work here, but as you know the problem with that. Looking at the wikipedia page ext2 would also work.
Jan 26, 2009 | LaCie d2 Quadra Hard Drive
Drives - size
Resizing partitions is easy with the right tools, and near impossible without them. You will want to first
get a good hard disk imaging program along with an external hard drive (some drives come with imaging software bundled with the drive) a few examples would be Norton Ghost, Acronis True Image, Dantz Retrospect, Powerquest Drive Image and so on. There are even some good freeware and Open Source alternatives. By imaging your c: drive to a USB external drive you can safely edit your hard drive partition tables and then put everything back with no reinstalling Windows or losing any data. You will need to have a bootable recovery CD on hand when it comes time to restore the image from the USB drive to your system drive. I would suggest that you first copy all files you want to keep from the d: e: and f: partitions to the c: partition, then image the c: partition by itself to external drive. Take note of the c: partition type I.E. FAT32 or NTFS. Make a bootable utility disk (Ultimate boot CD available from Filehippo.com for free) is one, an emergency boot floppy from Windows 98, ME, NT will work also. Boot with it and run FDISK to delete extended drive letters D E F and then their partitions and then delete the C: partition and finally create the C: partition with all available space and make it active. Replace the utility boot disk with the recovery boot cd, restart the computer and run the image recovery to restore everything back to your now 80gig system drive.
Jan 07, 2009 | Biostar NF325-A7 Motherboard
My OS treats simple drive as a ghost
try to use norton ghost and look for the image file
Jan 01, 2009 | SimpleTech SimpleDrive Portable USB 2.0...
How to format c:drive as it contain vista operating system . i only have a vista recovery disc which only install back vista to its factory level. please suggest me the procedure to format c:drive so...
hi,
yea you may, but make sure that you have already created a *Ghost* image of your current setup.
All you need is a bootable CD with some utilities which will help you out.
Try "hiren's Magic Disk 9.5" : it is bootable disk with proper menus and lots of utilities to make you king of your system.
This disk is usually used by System professionals (including me) :)
Instructions:
1. Boot your system with this magic disk
2. Goto Clone Disk option (Ghost disk)
3. Choose Best compression version
4. utility will start Symantec Ghost which will ask you for the source partition and destination partition for making images.
5. proceed with proper answers.
6. once the ghost imaging is complete, store this ghost image in your external storage drive
7. again boot your system with this magic disk
8. goto Partition utilties
9. Select Acronis Partition manager
10. You'll love to use this software for hard disk maintanence.
Regards,
kuldeep
Nov 14, 2008 | Computers & Internet
Symantec LiveState Recovery Standard Server 3.0 for PC Logo
78 people viewed this question
Top Symantec Computers & Internet Experts
Tony
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
