Question about Apple iPhone Smartphone
The bottom part of my i phone (its hacked) doesn't work ,though "slide to open " works so i think its a software problem i tried to reset a lot of times still doenst work please help
  • 165 Answers
Please giv your phone to a authorised i phone service centre
Posted on Oct 07, 2009
Every doors power windows will not work, I am thinking its a fuse or a relay because I do not understand how every door just stopped working. My wipers still work though as I read in a post how the fuse is...
The power windows do not use a fuse rather its hooked to a automatic reset circuit breaker, this is so it would reset after a fault, the first place to look which is the most common reason for all windows to stop working at once, open the driver door and look in the center of the door in the location of the hinges, you will see a rubber type boot that contains the wiring for the drivers door controls. you will need to slide boot back and check each wire, you will find a broken wire or two. this happens from opening and closing of the door and is common. good day.
May 27, 2011 | 2002 Mercury Sable
Dregdrawer Full
I read somewhere that there is a counter in the machine that when a certain amount of shots are done, the counter will reach its limit and tell you to empty the drawer, even if it's not full.
When I get the message I open the door, remove the drawer and it goes away once you replace it. Don't know why the machine would stop working though?
Apr 28, 2010 | Gaggia Titanium Espresso Machine
My Iphone hangs
Check if you have lots of softwares installed on the phone, Try unistalling the latest app which was installed on the phone.
If nothing works, do a reset on the phone which will get the phone back to the normal shape.
Dec 28, 2009 | Apple iPhone Smartphone
I noticed my nokia N70 main camera doesn't work, the front camera works fine. Does anyone have any idea what could be wrong with it or how to solve it ?
hey
May be there is some problem wth your mobile software plz chek this website http://www.nokia.co.in/get-support-and-software/download-software/phone-software-update?N70=# and download Nokia Software Updater in your pc
after installing this software connect your phone with your pc or laptop and run the Nokia Software Updater
after doing this your phones takes 5 to 10 minutes to update in between this process dont touch your phone , one more thing plzzz check the battery of your phone is charged
Dec 16, 2009 | Nokia N70 Cellular Phone
Iphone 2g stuck at slide to unlock screen
Seems like the digitizer(which sense the touches) is not working. Replace with a new one and you'll be good to go
Jun 18, 2017 | BoxWave Corporation Apple iPhone 2G...
HTC touch HD is completley frozen
If you have all your items saved to your computer with Active Sync, then do a master reset:
HTC Touch hard reset 14 January 2008
  • Power on.
  • Press and hold buttons marked 1.
  • Press and release 2 with stylus.
  • Release buttons marked 1 when menu comes up.
  • Press directly down on center dpad, marked 3.
You can also get tips & tricks from www.htcwiki.com
It has the latest and great updates, software, even known issues if you ever come across this. HTC does recommend that you do a master/hard reset once a quarter to keep it moving smoothly. Also, ensure you don't have a lot of open running programs. Perhaps once a day, clean the cashe and history. Do a soft reset (aka battery pull) once or twice a week. All depends on how hard you play with this lovely PDA device!
Feb 02, 2009 | HTC Touch HD Smartphone
Cect i9 slide to unlock will not open
THIS WORKED FOR US: Hold down the power button until you see the "CANCEL" icon; tap around the screen until the "CANCEL" button turns blue - this will take you back to the slide feature. MAKE NOTE OF WHERE THIS SPOT IS ON THE SCREEN. Repeat the "cancel-screentap" process to find a 2nd spot in another area of the screen. While on the "slide" screen, draw a line between the 2 spots; when you return again to the "slide" screen, the "slide" should work.
ONCE YOU HAVE OPENED THE PHONE do 2 things:
  1. RECALIBRATE the screen
  2. LENGTHEN the screen saver time-out to something other than the shortest time available.
Hope this works for you - GOOD LUCK!
PS - dunderground posted the following solution in Apr 2009:
"The fastest way is to be on the slide-lock screen & hold the side volume button in the Up position until "Press volume down key to check" comes up onscreen. This may or may not work on all firmware versions on the current i9, but works on most. Make sure to hold the button firmly in the Up position. You will first see the normal volume speaker icon show onscreen and the volume rise, but just keep holding it Up, and eventually you should see the pop-up box noted earlier. The moment you see that pop up onscreen, immediately press the side volume button in the down position. A white calibration screen should now show & you can calibrate the touch screen using the stylus."
Jan 20, 2009 | Dual Electronics CECT P168 Cellular Phone
Sony Ericsson w580i LCD replacement issue
ok. The most probable problem is that the display is loose. heres what u should do. First, slide the phone open and open the top cover of the phone by first removing the top right corner first. Now, carefully remove the display by lifting the bottom of the display first and pulling it out. now, using sticky tape, stick the end of the circuit comin out of the display to the socket in the phone. Be sure to match it properly. now, carefully insert the display back by sliding the top part in and then clickin the bottom into place. Replace the cover and turn the phone on;. If this doesnt work then u hav to dhange ur display.
Sep 26, 2008 | Sony Ericsson w580i Cellular Phone
Apple iPhone Smartphone Logo
61 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
