Question about Xerox DOCUMATE 510 Flatbed Scanner
One touch doesn't work Xerox 515 on Vista Home Premium
Same scanner works fine on XP. One touch event works immediately after driver reinstalled, quits working after reboot. Tried updated 64 bit driver. Tried temporary disabling Esset NOD firewall/antivirus (not running Windows firewall). Tried complete uninstall including Xerox software cleanup utilities (hidden devices, temp and inf files) and reinstall using Xerox/Visioneer KB articles.
Thanks
SOURCE: xerox scanner
You can downlaod them here - click on Windows Vista and youre done!
Posted on Mar 27, 2008
SOURCE: c pen 20
I found a solution before asking help from c-pen support.
1. Uninstall C-Pen software
2. Remove C Technologies entries from registry. They appear in HKEY_CURRENT_USER\Software and HKEY_LOCAL_MACHINE\Software
3. Reinstall C-Pen software (remove the pen from USB before reinstalling)
This worked in my system(Vista 32-bit).
Posted on Jun 27, 2008
SOURCE: Can`t open driver file...
Hello sir,
i am format the c: drive and also instal to windowprofessione2. Then after to local drivers are not open properly. thet means(D:,E:,f:) the drivers are change to file. Then ask to supporting programs.
Posted on Aug 14, 2008
michael_grey
  • 365 Answers
SOURCE: Xerox 4800 one touch flatbed scanner
Uninstall drivers and remove usb cable.
re-install drivers without usb attached.
Reboot and attach usb cable
Posted on Sep 17, 2009
Testimonial: "You are majic.........this time it works, thank you so much Regards Symbo"
bbl242003
  • 1637 Answers
SOURCE: I could not find the icon for the One Touch
  • Welcome [ What's in the Box ~ The Xerox DocuMate 510 Scanner ~ What You Need ~ Documentation ]
  • Installation [ Before You Begin ~ Step 1: Assemble the Scanner ~ Step 2: Install the Software ~ Step 3: Connect the Power Supply ~ Step 4: Connect the USB Cable and Turn on the Power ~ Additional Applications Available with Your Scanner ~ View the User Guides ~ Register Your Scanner and Check for Updates ]
  • Scanning [ Loading Documents to Scan ~ Load a Stack of Documents ~ Load a Single Page ~ Scan from the One Touch Button Panel ~ Check the Scan Settings Before Scanning ~ Using the One Touch Panel ~ About the One Touch Button Panel's Names and Icons ~ The Default One Touch Settings for Your Scanner ~ Configuring the One Touch Buttons ~ About the One Touch Properties Window ~ Selecting New Settings for a Button ~ Setting Destination Application Properties ~ Selecting Document and Page Format Options ~ Scanning with Optical Character Recognition (OCR) ~ Renaming a One Touch Button ~ Selecting Options for a Button ~ Creating a New Scan Configuration ~ Editing or Deleting Scan Configurations ~ Configure Before Scan ~ Scan and Burn to a CD ~ Scanning with Event Forwarding ~ Creating an HTML Web Page from Your Scanned Documents ~ Transferring Scanned Documents to Storage ~ Checking the Hardware and Setting the Lamp Power Saving ]
  • Scanning with the TWAIN Interface from PaperPort [ Accessing the TWAIN Interface from PaperPort ~ The Two TWAIN Interface Options ~ Scanning from the TWAIN Basic Interface ~ Scanning from the TWAIN Advanced Interface ~ Adjusting the Image with the Advanced Interface ~ Adjusting the Resolution ~ Adjusting the Brightness and Contrast ~ Adjusting Gamma, Saturation, and Color Hue ~ Adjusting Input Size ~ Creating a New Advanced Interface Profile ~ Display the Device Configuration ~ Setting Up PaperPort to Work with Your Scanner ]
  • Scanning with the WIA Interface [ Fine Tuning Your Scans ]
  • Maintenance [ Clearing Paper Jams ~ Care and Maintenance ~ Cleaning the Scanner Glass ~ Cleaning the Automatic Document Feeder ~ Replacing the ADF Pad Assembly ~ Replacing the Roller Assembly ~ Troubleshooting ~ Error Light Troubleshooting Codes ~ Uninstalling Your Scanner ~ Uninstalling the Scanner and One Touch Software ~ Uninstalling the PaperPort Software ~ To Install Another Driver ~ Xerox DocuMate 510 Scanner Specifications ~ Xerox DocuMate 510 Parts List ]
PLEASE SEE THE COMMENTS ON INSTRUCTIONS TO REINSTALL
Posted on Jan 25, 2011
How can I stop my Zerox Documate 515 scanner from trying to update one touch links every 10-seconds?
explore one touch setting or uninstall any other programs related to scan process mean that (use only one touch with scanner driver)
May 13, 2014 | Xerox DocuMate 515 Scanner
Xerox 4800 one touch flatbed scanner My new computer has Widows 7 and the scanner will not work with it. Do I need another drive
Hello.
I am a Support Engineer with Xerox Scanners.
The Xerox 4800 do not have a supported Windows 7 driver. The scanner only supports Vista, XP, 2000, ME, and 98. I recommend trading the Xerox 4800 for a supported windows 7 scanner.
Please feel free to contact us by calling 800-648-0410.
Regards,
Xerox Scanners Support
Nov 21, 2012 | Xerox One Touch 4800TA Flatbed Scanner
VAIO VGN-AR630E Drivers for Vista Ultimate
Vista Home premium drivers will work perfectly with Windows Vista Ultimate. When installing Vaio event service and Vaio Control center make sure that you run setup file as administrator. Right-click the setup file and select option "run as administrator". By reinstalling utilities this way they will work perfectly well
May 17, 2009 | Sony VAIO VGN-AR630E Notebook
Issue installing xerox documate 510 scanner using windows vista
Have a Documate 510 Scanner and keep getting the following error message: "out of memory, not enough memory for scanning device". How can i fix this?
Apr 07, 2009 | ScanSoft PaperPort Deluxe 9...
I hae a memorex 6142u w/ no vista drivers???
Go to site http://support.visioneer.com/products/home/EOL/Memorex/
Download/save application file 6142. Check file properties, under compatibility select "run this program..." and choose Windows XP(Service Pack 2). if u do not have a vista option
Then run the program.
Good Luck
Jan 26, 2009 | Memorex MEM48U Flatbed Scanner
Xerox scanner
Mar 27, 2008 | Xerox One Touch 2400 Flatbed Scanner
Hello sir,
Mar 03, 2008 | Xerox One Touch 2400 Flatbed Scanner
Xerox 2400 Driver
you are using the right software or the operatuing system is not compatible with the software
Mar 02, 2008 | Xerox One Touch 2400 Flatbed Scanner
8100 Visioner conflicts with Vista
Verified to work with Vista Home Premium x64 (should work for x32 as well):
1. Make sure your 8100 is unplugged.
2. Go to Visioneer's website and download drivers for the OneTouch 9420 scanner:
http://support.visioneer.com/products/home/9420/downloads_1.asp
3. Install the drivers. Nothing will work... yet, don't worry.
4. Now plug in your 8100. You'll get a message saying that Vista wants to find drivers. Select "Ask Me Later" or just cancel.
5. Next, open up Control Panel and then Device Manager. Find your 8100 in there (probably listed as "Unknown Device") and then right click on it and say "Update Driver Software". Now click "Browse My Computer For Driver Software" then "Let Me Pick From A List Of Device Drivers On My Computer".
6. Scroll down to "IMAGING DEVICES" then find Visioneer, then you should see the "Visioneer 9420" driver. Select it. You'll get a warning from Vista, but continue anyways. That's it... everything should work.
Feb 12, 2008 | Visioneer OneTouch 8100 Flatbed Scanner
Xerox One Touch 2400 Flatbed scanner drivers
http://www.xeroxscanners.com/en/uk/products/OT2400/drivers.asp
will get you drivers and manuals in pdf fomat. I had same problem and works fine now. Good luck.
Dec 15, 2007 | Xerox One Touch 2400 Flatbed Scanner
Xerox DOCUMATE 510 Flatbed Scanner Logo
153 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
