Question about Garmin Nuvi 360 Bilingual GPS Navigator and Personal Travel Assistant GPS Receiver
GArmin Nuvi 360 - bluetooth not working right
I have blackberry 8100 (software version 4.2.1.94, with rogers)
and the nuvi 360 with the new update version 4.40
after the update my bluetooth connection with the backberry stoped working. it will connect but for only a second.
short of reseting the nuvi, what can I do ??
thanks for any help.
  • 1 more comment
  • JoeMachine Jan 08, 2008
    I have the same problem with a Nuvi 610 and Blackberry Curve 8310. The two devices pair successfully, but then four times out of five the connection will be dropped after a few seconds. Once this happens I have to disable and re-enable Bluetooth on the Nuvi and try again. Sometimes I have to do this several times before they will stay connected to each other.
    Chris
  • Anonymous Apr 17, 2008
    I just updated my Rogers BB pearl to v4.2.1.109 and it still has issues pairing with my Garmin Nuvi 360 SW version 4.40, Bluetooth SW version 3.00. I'm having the issue where the phone will pair with the GPS once and then it will not be able to reconnect again until a while later. Does anyone know a fix for this?
  • Anonymous Jul 18, 2008
    My nuvi 360 bluetooth was working fine until 2 days ago. The phone does connect but after 20 or 30 seconds it disconnects.
    I also have a 550 which works fine with the same phone.
I had the same issue, prior to downloading the update. So I downloaded the update and when it asks you if you want to check for further updates for this device, select yes. There, you'll find the bluetooth update. After I installed it, the device seemed to work perfectly. My garmin nuvi 360 has yet to disconnect from my phone, and it's been several hours since I updated.
Best of luck to you!
jonathan
Posted on Apr 24, 2008
Wow, as soon as I got my nuvi 360 I turned the Bluetooth off. I then updated to 4.40 and the bluetooth SW version is now 0.00 and i cant even enable the bluetooth again. I think we have the same problem. I wish I could help but I am in the same boat.
Posted on Dec 28, 2007
How to add bluetooth to my garmin nuvi 750
Updated Bluetooth 3.40 available on Garmin Web Updater for Garmin series.750 but remember you have to pair the phone and the Nuvi again after doing the update. Mine was
Changes from version 3.10 to version 3.40:
Made general improvements in hands-free operation.
Improved Bluetooth support for various phones
Aug 10, 2011 | Cell Phones
Downloaded and installed Bluetooth firmware update - Won't Pair
I recommend rerunning the webupdate software available below, which was updated March 30, 2010. Run through the update steps again.
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
After successful webupdating, a hard reset is often helpful at this time, too.
I hope that helps.
_____________________________
Nuvi 265WT Manuals here.
Sep 09, 2009 | Garmin nuvi 265 Car GPS Receiver
Bluetooth Connectivity between Nuvi 710 and Blackberry Bold 9000
get the firmware update from the Garmin Updater. It fixes the connectivity issue with the BB 9000
Apr 06, 2009 | Garmin nuvi 255W GPS Receiver
Garmin bluetooth won't disconnect call
Solution below works for NUVI660 as well; ignore everything after step 6 but DO reboot and delete previously existing connections.
good luck
All,
I was having the same problem with my Curve and Nuvi 680. What has fixed this for me is downgrading the Bluetooth firmware version on the Nuvi itself. I was running version 3.0 (you can check your version by going to Settings -> System -> About on the Nuvi) -- I had success after downgrading to version 2.4.
It's a bit of a convoluted process, but here is the procedure I followed:
1. Download the old Nuvi BT firmware from the Garmin Italy website:
http://www.garmin.it/files/FileBluetooth.zip
2. Connect your Nuvi to your PC.
3. Go into the X:GarminRemoteSW and look for a file called 006B055301.GCD (where X: is your Nuvi drive)
4. Back up that file to your
computer, and delete it from the Nuvi.
5. Extract the file in the zip downloaded in step 1 to the X:GarminRemoteSW directory
6. Disconnect your Nuvi from your computer, and let it
reboot
7. Click on "View Map," then touch the "Speed" in the lower left corner.
8. You should have the "Dashboard" view up. Touch and hold the "Moving Average" box for ~15 seconds until the diagnostic screen appears.
9. Press the "next" button until you arrive at the "Bluetooth Status" screen (5-6 screens in)
10. Click "Updt PR" and then click "Yes"
11. Reboot the Nuvi, delete the existing bluetooth pairing, and attempt to re-pair with your BlackBerry.
Seems to work perfectly now -- please let me know if you have any questions. Good luck!
Feb 11, 2009 | Garmin nuvi 265 Car GPS Receiver
Pairing my garmin nuvi to my blackberry
Nuvi 200 does not have bluetooth capability.
See this link:
https://buy.garmin.com/shop/shop.do?pID=9160#specsTab
- Jim
SHARCNET-USA
Jan 18, 2009 | Garmin Nuvi 660 GPS Receiver
Nuvi 660 + omnia
Hi, version 3.1 is supposed to help with disconnects. Please see this link:
http://www.gpspassion.com/FORUMSEN/topic.asp?TOPIC_ID=109459
However, Garmin released 3.4 which will include the changes in 3.1 and also makes the bluetooth compatible with more phones.
You need to go to www.garmin.com and download their webupdater and run it with your Nuvi connected to the PC with a USB cable. It will check (via the Internet) if you need a firmware upgrade. The latest firmware version for a Nuvi 660 is v4.7. There is a second menu after the main firmware option that allows you to select additional software. Select yes and check the bluetooth 3.4 box and the Chipset "G" box if it's shown.. The Chipset "G" is the upgrade for the receiver in the flip-up antenna. Let it download. When finished, select to safely remove the Nuvi. You can now unplug the USB cable. Your Nuvi will reboot and load in the new changes. Whatever you do, don't turn your nuvi off! Let it go and update. You will see it say "Loader", then "Loading Software" and you'll see a task bar that says "Updating Bluetooth Software" and "Updating GPS Software" (if required). Once you get to the main menu and there are no more texts coming up on the screen. Press the power button and turn your unit off and then back on again. Check the GPS and Bluetooth firmware versions in your Nuvi. It should be 3.0 for the GPS and 3.4 for the Bluetooth. Check the firmware version if you selected v4.7. You will have to re-pair your phone with your Nuvi as the update erases any previous set-up. Let me know how it went for you. If you have trouble with this, let me know. I can do it for you. I have done it many times. Please rate my solution if you found it helpful.
- Jim
SHARCNET-USA
Jan 06, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin nui 360
Please tell me what the version of bluetooth firmware is showing up in your unit. You can access this by pressing the wrench symbol, then the gear symbol, then "about". The latest bluetooth version is v3.4. If it shows up as 0.0, then you need to reflash the bluetooth firmware.
One note: Everytime you update the bluetooth firmware, it erases your pairing information with your phone, so you will have to re-pair your phone with your Nuvi.
Best wishes,
- Jim
SHARCNET-USA
Dec 11, 2008 | Garmin Nuvi 360 Bilingual GPS Navigator...
Dont have cell phone icon anymore on nuvi 360
Have you tried to re-pair it with your phone? What does the bluetooth firmware version show up as on your Nuvi? If it says 0.0, you need to reflash the bluetooth firmware. You can find the firmware version by selecting the wrench icon, then sekect the gear symbol and then select "About". Use Garmin's webupdater and connect your Nuvi to the PC and let the webupdater reflash yoour Nuvi. Garmin just updated the bluetooth firmware on November of 08 to v3.4 so you would want to do it anyway. When you reflash, you have to repair the phone to the Nuvi because the reflash erases your phone setup.
- Jim
Nov 16, 2008 | Garmin Nuvi 360 Bilingual GPS Navigator...
BLUETOOTH
Download and run the Garmin WebUpdater. There is a new version of the firmware availabe for the bluetooth.
Apr 25, 2008 | Garmin Nuvi 660 GPS Receiver
Bluetooth enable
The complete solution - user reset is NOT necessary:
Whenever I purchase a new electronic device, the first thing I do is update the firmware. This has me in a bind in this case.
I updated my Nuvi firmware, then my BT firmware.
A few days later, I got the "Enabling Bluetooth" hang. I followed the advice on this page, but "Bluetooth Firmware Update" would not appear in the webupdate list.
1. Browse here and install the latest version of WebUpdater:
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
2. Turn on your Nuvi, press view map, press speed, press and hold the middle of the speedometer (the circle that says 0.0mph in it). After five seconds (maybe a bit longer), the engineering menu will appear.
3. Press "Next" five times (once for each page). You will arrive at the "Bluetooth Status" page.
4. Press "Clear". Confirm by pressing "yes".
5. Press "Updt PR". Confirm by pressing "yes".
6. This probably did _nothing_ for you, but to be thorough, I've included the steps.
7. Connect the Nuvi to your computer. Run the webupdater and if the latest version is already detected on your Nuvi, simply proceed and browse the list of further updates.
8. If "Bluetooth Firmware Update..." (or similar text) DOES NOT APPEAR skip to step 10 below, otherwise complete your fix with the next step, step 9.
9. If the "Bluetooth Firmware Update..." (or similar text) appears in your list, select this update and agree to term of service, and have the updater load the firmware onto your device. Unplug your device. It should powerup automatically. Power off. Power back on. Your BT should be back in business. Do NOT continue with the next steps. You are done.
10. If "Bluetooth Firmware Update..." (or similar text) DOES NOT APPEAR in the list, then you need to remove the offending update that is making WebUpdater believe that your Nuvi is up-to-date.
11. You can access the Nuvi by clicking on "My Computer" and double clicking the Nuvi link.
12. Click the "Garmin" folder.
13. Click the "RemoteSW" folder.
14. DELETE "006B055301.GCD". This file will be one of two GCD files in the directory: <DRIVE>:\Garmin\RemoteSW. The file without the "Date Modified" is the original firmware. The other file is the new firmware that the Nuvi believes is installed. By deleting the newer of the two files, WebUpdater will see that your Nuvi is out-of-date. Return to step 8 to continue your fix.
This should resolve all permutations of this nasty bug.
Oct 28, 2007 | Garmin Nuvi 660 GPS Receiver
GPS Logo
978 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
