Hello Terri
Let's see if we can get you sorted out.
Make sure that you first of all have an aerial cable plugged into the TV.
Secondly make sure that you have it on a DTV (freeview channel) once you are at this stage press the MENU button on the remote. then go down to CHANNEL then across to Auto store and then follow the on screen messages.
That should be you all sorted out. If not then you may not be getting a strong enough signal from you aerial.
Moved it to bedroom today - 3 years good service in living room.- plugged it and switched it on and...
(More)
Moved it to bedroom today - 3 years good service in living room.- plugged it and switched it on and volume goes to max and stays there and tv is stuck on 1 channel. Remote fails to address vol problem or change channels.
The internal freeview on my Samsumg LE40A556 has just stopped working. I can fun freeview through it...
(More)
The internal freeview on my Samsumg LE40A556 has just stopped working. I can fun freeview through it using a set top box however.
It just says no signal and the signal setting in the menu is greyed out.
I can use the aerial through another Tv so I know that the aerial socket is fine.
Every afternoon around 4:30pm digital picture and sound on Channels 3 and 4 start to break up; today...
(More)
Every afternoon around 4:30pm digital picture and sound on Channels 3 and 4 start to break up; today especially bad: Ch2 Bit Error = 0-1, Signal strength = 26-30, Ch3 Bit Error = 9, Signal strength - 20-29. So bad today picture is unrecognisable had to switch back to analogue. Last software download was T.GREEPEUO_1056 and that had to be sorted by local TV repair shop as update of new channels would not work via automatic update at home. Any idea what is causing problem? Before 4:30pm picture is great! After 7pm picture is usually OK too.
Hi, I'm assisting some elderly friends retune their SamsungLE19R85BD TV as they've now lost channel...
(More)
Hi, I'm assisting some elderly friends retune their SamsungLE19R85BD TV as they've now lost channel 5. For some reason it won't allow access to the retuning page in the menu when in DTV mode (ok in analoge mode) The icon in the list is grayed out. Any ideas?
