Question about Sceptre X37sv-Naga 37 in. LCD Television
Blue screen on - audio clear - sceptre lcd tv
Audio works, but can only get a blue screen on my 46 inch sceptre lcd tv. Cable is working in other rooms.
SOURCE: new Sceptre 37" LCD TV does not turn on
I just got a 42" komodo by Sceptre, same problem, except "SCEPTRE" showed on the screen. I was sent a USB key program to insert in the service slot in the back and it reflashes the bios. This is old news for you but maybe new for someone?
Posted on Mar 29, 2007
normally the a-v cables are color coded the white goes with white the red goes with red and yellow goes with the yellow and when putting it in the dvd player if applicable it should be the same way did your tv come with a manual showing you how to hook it up
Posted on Aug 09, 2007
ThaMp3Doctor
  • 8596 Answers
SOURCE: rca 46 inch lcd tv, no sound
Go into the menu and change the HDMI Audio settings - the manual will give you a breakdown on this. HDMI is a little glitchy - if you were using red/gree/blue cables before switching to HDMI, you might want to consider going back to them - just an opinion.
Posted on Jan 03, 2009
  • 267 Answers
SOURCE: Half of the screen turns black after 10 mins 46" Sceptre LCD TV
YOU PROBABLY HAVE DEFECTIVE LCD PANEL THERE IS A SLIGHT CHANCE IT IS THE MAIN BOARD OR THE LVDS CABLE
Posted on Apr 10, 2009
  • 36 Answers
SOURCE: Connecting Compaq Presario CQ40 to LCD tv Toshiba REGZA '32'
Check your resolution output from laptop it maybe set to high for the TV to handle, also go to the Display Properties and ensure that the second monitor out is enable. Good luck!!
Posted on Aug 03, 2009
Sceptre 42" LCD flat screen. I bought this tv brand new in March 2013. I initially began having problems turning the tv on and off with the remote, until it didn't work any more. The other
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Jan 17, 2015 | Sceptre Televison & Video
Bright Spot
A fixed blue area on screen may be a display panel (main screen unit)
Here is a link for the boards etc this set uses--take your pick:
http://www.shopjimmy.com/sceptre-x460bv-f120
May 17, 2012 | Sceptre 46 X460BVF120 LCD TV
My 46-inch Samsung LCD TV screen went black. Audio works.
If you are seeing light then the back light is working. Can you get a menu?Do any of the other video inputs work? If no video but has backlight and no men or any on screen display replace main board.
Sep 13, 2009 | Televison & Video
I have a 32 inch sceptre naga. when i turn on a tv, the blue screen appears for less than a second and then goes blank. the sound is still on. what could be the problem
mine does the same thing, before... it would come on when i turned it on & off. But now it blue screens then blank black. Blue means if it stays blue & i turn on my computer it will show all the computer stuff, i have not used TV yet.. But if you can get it to stay blue you can change things with the cc control, or swap..
If you find how to keep it blue let me know please..
Apr 17, 2009 | Sceptre X32BV-Naga 32 in. LCD TV
Apr 10, 2009 | Sceptre X42GV-Naga 42 in. LCD Television
IBM T60 to D-SUB on HD TV
The laptop has a blue 15 pin D-sub video port, connect a video cable from this port to the 15 pin D-sub on the HDTV.
Power up the TV first and then power up the laptop, the video signal will automatically switch to the external video output.
You can toggle between the LCD and TV or both on together by pressing the blue Fn key + the F7 function key several times.
Apr 09, 2009 | IBM ThinkPad T60 Notebook
Blue screen with HDMI
Check the power supply modular cable connection that is by itself in the upper right corner.  On the one my son-in-law has the double yellow jumper wire that connects to this plug in two locations was loose (not properly inserted) in the modular connector and had worked it way out.
Jun 09, 2007 | Sceptre X37sv-Naga 37 in. LCD Television
New Sceptre 37" LCD TV does not turn on
Aug 28, 2006 | Sceptre X37sv-Naga 37 in. LCD Television
Sceptre X37sv-Naga 37 in. LCD Television Logo
99 people viewed this question
Top Sceptre Televison & Video Experts
Henry  Thomas
Henry Thomas
Jaime Hernandez
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
