Question about Nvidia Geforce FX 5200 Graphic Card
Intermittent stalling in 3D games
Any games that utilize my 3D hardware will stall every few seconds, then continue normally for another few seconds before briefly stalling again. I've googled and googled, and I've found a handful of reports of the same exact problem with a variety of video cards, leading me to believe that it's not a hardware problem.
Attempts to solve the problem:
--uninstalled and reinstalled the card with the original drivers
--updated to the newest drivers from nvidia.com
--disabled the sound card to resolve potential conflicts
System specs:
Windows XP Home Edition, SP2
Intel Pentium 4 1.49 GHz
896MB RAM
NVIDIA GeForce FX 5200 -- 128MB (PCI)
SB Live! Value
    Scholar:
  • 75 Answers
Sounds like yo had the same Problems that I had with my 5200 geforce The install did not go well. what was happening was the direct x was binding to the old mother board graphics system and not the new card . to make it rebind just change the refresh rate in the nvidia icon in your task bar . disable the display adapter from device manager for the motherboard graphics .put the card in the slot change the monitor cord boot up check you direct x by typing in run dxdiag and test directx to be sure it is running with your card you can also see that from the about nvidia you must have the driver for the card installed to do all this.. hope I helped install the driver first then disable download latest drivers here http://www.nvidia.com/Download/index5.aspx?lang=en-us
Posted on Apr 19, 2010
Engine stops while travelling for no apparent reason , temp normal , restarts after a few minutes
6 common reasons are, bad battery,fuel pump,moisture in the gas, bad wiring,low fuel pressure,distributor cap. all the links below give more detail. press the helpful button
Fix Your Engine Stalling While Driving Like Pro Pictures
Solving Intermittent Stalling Problems
Diagnose Engine Stalling Problem
Jan 29, 2016 | Cars & Trucks
Stalling for a few seconds when leaving a stop sign. This is an intermittent problem. Seems to happen most of the time when turning left when leaving a stop sign. Stalling also happens when rolling slow at...
Is the brake fluid reservoir low? The master brake cylinder may be leaking, the fluid getting sucked into the brakes power booster and then into the vacuum of the intake manifold. Check the vaccuum hose to the brakes power booster to see if it is wet inside with brake fluid.
Mar 14, 2015 | 2014 Hyundai Santa Fe
Stalls after start up, Stalls when braking, then runs fine after a few minutes
Check the ECU engine temperature sensor. If it thinks the engine is hot, it will struggle to run when cold.
Mar 06, 2014 | Volkswagen Beetle Cars & Trucks
Have a 2006 Holden Viva Equipe 1.8 Manual. Every once in a while (intermittent and random), the car is unable to idle - it just stalls. Normally this is on starting the car cold. It then continues to stall...
The first thing to do is have the fault codes read to determine which sensor/s are playing up. Check the condition of the cat converter as it may be broken and blocking up the exhaust system
Oct 14, 2013 | Cars & Trucks
Lexus SC430 Stalling Problem
Check the EVAP system canister purge valve, usually located on or near the canister itself which should be near the fuel tank. If the valve is clogged or stuck, it will cause excessive backpressure in the vapor return system, which sounds like what is happening here. Good luck, hope this helps.
Jul 15, 2013 | Cars & Trucks
Its a 115000 btu multi fuel.it starts up,runs a few seconds,then shuts off.it doesnt smoke or anything wierd,it just shuts off.
It can be low fuel pressure issue or clogged fuel pump. Or its engine related issues,---------------
Check the help link mentioned below to troubleshoot the problem: ------
Engine stalls when gas is given?
http://technoanswers.blogspot.in/2012/01/engine-stalls-when-gas-is-given.html
Car stalls when MAF sensor is connected?
http://technoanswers.blogspot.in/2012/01/car-stalls-when-maf-sensor-is-connected.html
Car Engine Stalls While Driving?
http://schematicsdiagram.blogspot.com/2011/12/car-engine-stalls-while-driving.html
Car stalls and throws white smoke from exhaust?
http://repairhelpcenter.blogspot.com/2012/01/car-stalls-and-throws-white-smoke-from.html
Stalls And Dies At Stop Sign?
http://www.howtobyme.blogspot.com/2012/07/stalls-and-dies-at-stop-sign.html
GMC Sonoma Stalls and idles low
http://technoanswers.blogspot.com/2012/10/gmc-sonoma-stalls-and-idles-low.html
Nissan Pathfinder stalls and bucks on Acceleration?
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-stalls-and-bucks-on.html
1992 Chevrolet stalls and shutdown?
http://schematicsdiagram.blogspot.in/2012/04/1992-chevrolet-stalls-and-shutdown.html
Stumbling and stalling at idle after engine rebuild?
http://schematicsdiagram.blogspot.in/2012/03/stumbling-and-stalling-at-idle-after.html
1990 mazda 323 stalls and quit running?
http://technoanswers.blogspot.in/2012/02/1990-mazda-323-stalls-and-quit-running.html
2000 Toyota Camry: Idling and Stalling Problem?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-idling-and-stalling.html
1995 Toyota Corolla: Stalls, Sputters and Pops Through Intake Manifold?
http://whatisbyme.blogspot.in/2012/05/1995-toyota-corolla-stalls-sputters-and.html
1999 Toyota Camry: Erratic stalling and high engine RPM at idle?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-camry-erratic-stalling-and.html
Dodge Dakota stalls, stumbles at idle. Has low fuel flow and runs hot?
http://schematicsdiagram.blogspot.in/2012/03/dodge-dakota-stallsstumbles-at-idlehas.html
1994 Toyota 4Runner: Stalls and Stops While Driving?
http://whatisbyme.blogspot.in/2012/05/1994-toyota-4runner-stalls-and-stops.html
1997 Toyota Camry: Erratic Idle and Intermittent engine stalling?
http://technoanswers.blogspot.in/2012/04/1997-toyota-camry-erratic-idle-and.html
Ford Maverick: No Idle and Stalling issues?
http://schematicsdiagram.blogspot.in/2012/04/ford-maverick-no-idle-and-stalling.html
These details will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
1994 chevy pick up c1500 stalled out while I was driving
This stalling is fuel related issue.When the fuel flow becomes low, the engine ask for fuel.But fuel pump does not send required fuel and engine stalls.In some cases, it stall then dies after stalling for few minutes.In some cases, if stalls for few seconds or minutes, then again get required fuel , as you accelerate more and engine starts/runs normally.But once this problem is started and it repeats again n again.This is indication f low fuel pressure.Get the fuel pressure checked and replace fuel pump and fuel filter.-----------
To Order car parts online:--To get heavy discount on car parts .Click this link below:----
http://technoanswers.blogspot.com/2011/05/from-where-to-order-car-parts-online.html ----------
This will help.Thanks.Helpmech.
Jun 14, 2011 | 1994 Chevrolet C1500
2000 Dodge Durango Starting/Stalling Issue
I would start by inspecting and cleaning the battery terminals.
Jul 21, 2009 | 2000 Dodge Durango
Intermittent misfiring and stalling
this sounds like a definate problem with vacuum check valve on your brake booster or the hose going to booster....that should solve your prob! good luck.......ps----------cheap part...quick fix!
May 22, 2009 | 2001 Daewoo Lanos
91 honda civic dx. Starts, runs for a few seconds then stalls
Try pounding on the gas tank with a rubber mallet or similar tool. (careful not to dent the tank) Try starting it. If it runs, replace the fuel pump (it's nfg). I've diagnosed numerous fuel pumps this way. Remember the pump needs to be replaced, if you drive it, you don't know when it'll fail for good. Hope this helps. Please post the results.
Feb 07, 2009 | 1991 Honda Civic
Computers & Internet Logo
120 people viewed this question
Top Nvidia Computers & Internet Experts
Clive Gray
David
David
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
