Question about Whirlpool Duet GHW9150P Front Load Washer
F 35 on the display - Whirlpool Duet GHW9150P Front Load Washer
    President:
  • 1,776 Answers
.This typically indicates slow drain condition. Check for any clogs or kinks in the drain line. Also check that the pump is not clogged and that no pump impeller blades are missing/broken and that the impeller moves freely. Any broken/missing blades or if the impeller won't turn freely will indicate a faulty pump. Hard objects can sometimes make it to the pump and cause damage. Hope this helped and best wishes.
Posted on Oct 07, 2009
E 35 diplay on electrolux e30ec70fss cook top
Hey Syl20 Bel, thank you for your post!
Based off the information you have provided your Electrolux cooktop is displaying an error code of "E 35". The error code means that the cooking zones could have a low voltage. This could be an issue within the filter board or power supply. You may want to seek help from a professional technician to help verify which component that would need to be replaced. A technician will have the appropriate tools needed to test each component as well as the knowledge to properly disassemble the cooktop. I hope this information is helpful to you. -Matt
Mar 07, 2016 | Electrolux E30EC70FSS Cooking Products :...
I have a toshiba studio 35 copier that displayes call for service, how do i reset it?
Press CLEAR+8 to check the error message.
If Cxx, perform 08-400, reset any value to "0"...
Feb 20, 2012 | Toshiba e-Studio 35 Copier
I have a gwl15 Fisher Paykel Smart Drive and it will not get past the rinse cycle, water will not drain out! I found the diagnostic mode sheet and the number I come up with is none of the fault...
Hi - it would seem the washer pump may actually be blocked for some reason... If you had followed the method as per the diagnostics then if you reckon you got 35 then its a communications error beween the console & display. Furthermore you would be able to mannually start the pump in diagnostic mode to see if its working fine.. But under normal cond..... the machine would come up with a pump error & code 37 - so perhaps it is ok.
Remedy - check the harness wire connections between the display & the controller unit is good - clean - otherwise replace the display unit to correct.
On the error codes - there is a Code 35 - just that its not available to the public - it was only ever issued on a DVD sent to the service agents - have never actually seen it on the secure service site.
See how you go....
Jul 11, 2011 | Fisher Paykel EcoSmart GWL15
I sthere a way to calibrate my oven temperature? It is off by about 35 degrees. Temperature is lower than display.
Sorry to read about your problem, I hope this helps you out.
To Adjust the Oven Temperature (do not use Bake or Broil while adjusting the oven temperature): note: Your oven control was factory set in the (Fahrenheit) °F Temperature Display Mode. To change for (Celsius) °C, see page 15.
1. Press & hold the BAKE key pad and release after the display shows the factory temperature setting of 00. note: If the oven temperature has been previously adjusted from the factory setting, the current temperature adjusted value will appear in the display instead.
2. You may increase the oven temperature in 5°F (1°C) increments with each press of the uP arroW pad to a maximum oven adjustment of +35°F (+18°C). You may also adjust the oven temperature downward in 5°F (1°C) increments with each press of the doWn arroW pad (total range of -35°F to +35°F (-18°C to +18°C).
3. If you do not want to keep the display adjustment, press the clear oFF pad before the oven control beeps. This will cancel the temperature adjustment procedure. To start this procedure over again begin with step 1 above OR;
4. If you want to keep the adjustment, wait until the oven control beeps once.
5. The oven temperature adjustment has be accepted by the oven control and the display will return to the time of day.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Frigidaire FEB24S2AB Single Oven
My check engine is on and the codes that I get are 35 & 55 - what do these codes mean
code 35 is a problemin the cooling fan relay it is either open or shorted code 55 means end of code output,or to say there are no more codes. Ray
Nov 09, 2009 | 1995 Dodge Intrepid
F 35 light on Kenmore Washing Machine
am sorry but F-35 is not in the record.
If this is a different F# please e-mail us back
I will be more then happy to assist you
"Was this helpful?"
Apr 02, 2009 | Kenmore HE2 Plus Front Load Washer
Display / Clock display not working
SONY MHC-EX50
Het is al een paar weken verder, maar ik ben eruit: C161 en C162 (100uF/35V) in de voeding zijn slecht.
wel 105 graden elco's gebruiken en hoger dan 35 volt, liefst 100v
et gaat dus om een VFD (Vacuum Fluorescent Display) die geen gloeispanning krijgt. Het vervangen van C161 en C162 lost het probleem helemaal op.
Radio: ST-EX100
Amp: TA-EX50
Symptome=Tuner-Display zeigt nichts an, sonst Tuner OK.
Defekt=C161 und C162 (100µF,35 V) auf der Tunerplatine ersetzen.
Wenn bei dem Sony-Tuner RDS EON ST-EX100 (z.B. zu der Anlage Sony MHC-EX5, aber auch MHC-EX 70) pünktlich eine Woche nach Ende der Garantiezeit die Beleuchtung im Display wegfällt und man deshalb leider keine Sender mehr programmieren kann, dann handelt es sich vermutlich um eine fiese Soll-Bruchstelle.
Auf der Platine des Tuners sind zwei Kondensatoren zu schwach ausgelegt und gehen zwangsweise früher oder später kaputt. Die Reparatur ist ganz einfach. Man kauft zwei neue Kondensatoren (100µF,35 V) - kosten nur ein paar Cent! - und besorgt sich einen Lötkolben. Dann schraubt man den Tuner auf, entfernt auf der Platine die Kondensatoren C161 und C162 (die sind namentlich gekennzeichnet) und ersetzt sie durch die neuen.
Nov 12, 2008 | Sony ICF-2010 AM/FM/SW Radio
Toshiba studio 35
switch off...hold down 0 + 8 keys,
switch on holding keys for 5-10 secs then let go.
service mode...
punch in 251 then print key should show pm set figure,punch in say / add 20,000 on to figure then press set in the display.
switch off then on should have cancelled prevent maintenance.
Jul 16, 2008 | Office Equipment & Supplies
Whirlpool Duet GHW9150P Front Load Washer Logo
70 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
