Question about Karcher K2.26 Electric Power Washer
When i run the washer after 10 minutes it starts to leak oil the motor starts to labour and then gives up iof you ask it to wash it just hums if you leave for half an hour it goes again but then develops the same problem
4 Suggested Answers
  • 56 Answers
SOURCE: Hi.
Sounds like the thermal protection is tripping. If the motor has a problem or is running with to high of Amps it will heat up and cause this problem.
Posted on Jan 14, 2010
caroldon
  • 17130 Answers
SOURCE: Oil leaking from within body of washer after half
This is noticed on the Karcher washer and does not need any attention unless you are having a large spill over or leak. The oil oozes out when the pressure washer works for some time and is a result of a pressure leak when the washer is used for sometime.
I had seen this happen on mine for sometime , checked on all sides for any damage but there was none. So ignored but cleaned off the leak and was not seen then.
Posted on Mar 30, 2011
SOURCE: Our washer had been woring fine earlier this
Can you see my posting: "Karcher - no pressure", also my own comment where I describe my later technical findings - mashed up gearbox. Could it be the same problem as yours, where the motor sounds to be running just fine but there is simply no pressure produced?
If you can't see it add a comment to let me know and I will post you my full article
Philip Goodwin
Posted on Sep 06, 2012
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
GE Washer stuck in wash cycle and not draining.
humming is usually the result of bad motor windings , are u saying it washes for 20 minutes or just stays on that cycle without doing any washing? a non moving drum can be a bad motor coupler or belt if belt driven.
Mar 30, 2015 | GE Washing Machines
Kenmore washer oil leak
That is a transmission issue. Once it starts leaking oil. The gearcase needs to be replace along with the clutch and coupler. The repair should run you about 150-250 dollars in parts. But I do believe it is worth the repair. If you are above average with tools and repair it can be done in about 30-45 mins and will allow you was to last longer than any new washer you can buy.
Apr 30, 2017 | Washing Machines
Hi. I have a Maytag Neptune FAV6800A and it won't go past the first 5 minutes of the cycle. It starts to fill up, then it makes a humming sound for about a minute, then it just stops. It doesn't display...
If you open the lid and spin the wash basket by hand will it rotate CCW with very little effort?
I'm an owner like you and with no error codes this could be a little more difficult to troubleshoot.
Without a known good Control Board and Motor Controller same deal difficult to troubleshoot.
The Washer Motor for the most part is rock solid I have not heard of anyone having to replace it. But there is always a first time and it has a 10 year warranty which may be up.
How deep to you want to get into trouble shooting? Can you tell if the humming is coming from the top of the machine LED Console area or bottom of the machine (left front side) Motor Controller area? You may want to remove the front panel to get a visual of the Motor and Motor Controller.
You can go into Service Mode and step thru the machine Diag codes and that may give you a start point to fault isolation.
Oct 25, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Brown oil is leaking from the bottom of the washer
The only place oil can come from is the transmission. If you do not have a big leak, it may run a long time (read: maybe a year or more) before low oil level in the transmission causes major appliance damage, but it's time to start looking for a new washer. Many washers these days do not even use an oil filled transmission. Current GE machines do not, and the Whirlpool models comming soon don't either. If you can afford it, the front loading LG washers (which are direct drive, thus no transmission or clutch, and have a 10 year motor warranty) are the best, in my opinion.
Jun 05, 2010 | GE Washing Machines
My Simpson Water Shotgun shuts down about a minute into the wash
Have you checked the oil level? Some engines have a sensor that shuts it down if the oil is too low
Jul 16, 2009 | Simpson PS2600 PowerShot Commercial-Duty...
Machine starts but after one minute it just hums
Something is locking down the aggitator. The motor will burn up if you keep trying to run it while it is unable to turn so please un jam it then try it again.
Nov 27, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Error code LE on LG Wm1815cs
The motor sensor has failed and needs to be replaced.  You will need to call a qualified LG technician to repair this problem.
Sep 14, 2008 | LG WM1815CS Front Load Washer
2 problems with speed queen washing machine
The motor is not starting this is the humming noise not a good sound, try it in spin to see if the motor runs in this direction. You may have a motor issue because of the water leaking on the motor?
Now that you have the front panel removed you can look for leaks, you will need a flash lite, start a cycle on the small setting and look for where the water is coming from. If it is coming from the center of the tub above an aluminum case which is the transmission you need a tub seal, if the water is coming from somewhere else it could be a pump, or hose, or ?
Jul 15, 2008 | Washing Machines
Humming and not filling?
had the same problem this morning, turned out the pump on the drain side had frozen, took it apart, and broke free the fan, humming stopped, washer back up and working.  Its two screws to the bottom of the washer, two electrical connection (white and black) two hoses to undo, and three screws on the pump itself, after actually committing to doing it, only took about 10 minutes.
good luck
Oct 13, 2007 | GE WSXH208A Front Load Washer
Karcher K2.26 Electric Power Washer Logo
122 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
