9-SOCKET_DATA . LOOKUP(S) = = O CAPTURELSPNOISPWSP_PATCHES.CPP:1313 IEXPLORE.EXE ASSERT IN LSP tHIS...
(More)
9-SOCKET_DATA . LOOKUP(S) = = O CAPTURELSPNOISPWSP_PATCHES.CPP:1313 IEXPLORE.EXE ASSERT IN LSP tHIS IS A READING i GET, WHEN MY MONITOR, MESS'S UP. IT SEEMS THAT WHEN MY COUMPUTER IS COLD(JUST TURNED ON) T5082-eMachines. It (bilt in ATI) don't have enough power? to run the screen AOC- lcd monitor it worked fine at first. but when windo's started down loading all there up dates to fix Vista, it got a lot worse. I have wavey line's on screen can't read any thing for about 15min. OK I gess or hope I'v given you enough info. ? Thanks , James
i use nvs 280 for over two years. but for past two months, my system hangs. if i take out the card...
(More)
i use nvs 280 for over two years. but for past two months, my system hangs. if i take out the card and use the onboard graphics, system never hangs. whenever i reinstall the card. same thing happens.
When I play a saved session in my Trainz railroad simulator for a length of time I get a fatal error...
(More)
When I play a saved session in my Trainz railroad simulator for a length of time I get a fatal error box that closes the program and leaves 2 boxes, one with the fatal error message and stats, the other says open gl with either a blank box or part of the program running while it loses data. This happens on 2 different CPUs. 1: on Win 2000 pro and asus 9520x video; 2: Win XP with asus eah3450. Both CPUs have full memory ram for their Windows version. Thank you.
Apollo A9200SE-128MB+TV+DVI/A: VGA connected. At power up, good picture for 10 sec, then PC shuts...
(More)
Apollo A9200SE-128MB+TV+DVI/A: VGA connected. At power up, good picture for 10 sec, then PC shuts down "off mode in 5 sec". PC runs ok with other graphics cards. Thanks, George
