Question about Nikon D40x Digital Camera
I think I have all the setting right for the highest mg shot, 10, with Fine setting. But instead of 10, I got around 4+. Can't figure out. Anything I can check, like a weird button or setting I have on but don't know?Thanks. Michael
    Brigadier General:
  • 11,967 Answers
Are you saying that you set the camera to take 10 mp pictures but their final size is only around 4? That's normal...the megapixel rating in the camera refers to the capabilities of the sensor but the size of the actual picture will be different depending on the complexity of the subject matter.
Posted on Oct 07, 2009
I can't figure out how to set the resolution at the highest setting on my camera
Depending on your camera and model, it may vary. On most cameras, if you got to menu, "Camera Settings" and then anything along the lines of "Image Quality," you should be prompted with 3-4 options such as Super Fine, Fine, and Normal.
Mar 06, 2011 | Cameras
97 s-10 runs fine when it's cold but when hot it starts to back fire when i give gas
Could be anything, its one of those thigns that are hard to figure out sometimes. Could be a EGR valve not working properly, could be MAF or MAP sensor, failing O2 sensor(s) as well. or simply a vacume leak around the throttle body or at a vacume line.
start with the simple, look for broken or cracked vacume lines or obvious leaks.
What motor is in this s-10? 2.5 4 cyl? 2.8 V6?
im thinking if it was a fuel supply problem you would notice the issue at fast idle when cold as well.
also. how does it idle when it warms up?
Nov 18, 2009 | 1998 Chevrolet C1500
Linking photoshop and canon MP700 for best quality photos
If your pictures are shot at the highest setting on your camera, you should not have to do anything in Photoshop.
When you go to print make sure the print setting on the printer are set to the highest level.
Nov 09, 2009 | Adobe Computers & Internet
I cant figure out how to set the self timer on this camera
If you press the left < button on the camera before you take a picture you will have the option to set the self-timer. The options that you can choose are: 1. Single shot; 2. Continuous shot; 3. Self-timer (10 sec) / Remote control; 4. Self-timer (2 sec); 5. Self-timer (10 sec): Continuous (2 - 10 shots).
Hope this helps!
Please rate!!
Cheers
Oct 01, 2009 | Canon EOS Rebel XSi Digital Camera
I can't figure out how to set the 10 second timer for my Canon A410..HELP!!!!
With the camera in the shooting mode:
1. Press the Func/Set button
2. Use the up or down arrows to select the Drive mode (normally a single square)
3. Use the left or right arrows to select the clock/10 icon (10 sec delay)
4. Press the Func/Set button again
To cancel, follow the same instructions but select the single shot mode (single square) at step 3
Aug 28, 2009 | Canon PowerShot A410 Digital Camera
Grind settings
The factory setting should be 8. The higher numbers are finer. The + and - knob is the doser amount, the amount of coffee in a shot dose. Average is 7 gm, the middle. The highest is 14, I think. Generally, the highest dose shouldn't be used consistently because it can cause stress on the brew group. Just brew two shots.
Apr 17, 2009 | Saeco Vienna De Luxe Espresso Machine
Lack of mb in photos
If you have your camera set to take the highest resolution pictures(8 MegaPixel), but save in jpg format, then 3 - 4 MB is a normal size for the image file. There is nothing wrong with your camera.
If you have your camera set to save in RAW format, the image files will not be compressed and MUCH bigger. However you will need software that will be able to manipulate images in RAW format.
Jan 07, 2009 | Sony Cyber-Shot DSC-F828 Digital Camera
CARD FULL with 3 pictures
Have you tryed eraseing / formating it in the 740?
Make sure the camara uses the card instead of internal memory
it might be that its saveing the images into the cameras internal memory witch is probably just about 3-4 shots.
Mar 09, 2008 | Olympus Stylus 740 Digital Camera
New JVC Everio MG 130
Hi, to set the time or date, first press the MENU button (beside the DIRECT DVD button). Nudge the joystick to the left to select which settings you want to edit. Then go up until you reach the general options. Nudge the joystick right. Move the joystick up until you see "CLOCK ADJUST". Here you can set the correct time. The light is really easy to access. In the shooting mode (where you are seeing live video from the lense), nudge the joystick down. The light should come on. Nudge it down again to put it on Auto. It will turn on/off depending on the lighting. Nudge it down a third time to turn it off. Hope this helps!
Eric
Jan 03, 2008 | JVC Everio GZ-MG130 Camcorder
Nikon D40x Digital Camera Logo
22 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
