Samsung M8800 Pixon - Unlocked QuadBand Cell Phone - 8MP Camera, GPS, 3.2" Touchscreen - Interna Logo
Posted on Oct 07, 2009
How to get my samsung s5600 into idle mode
To use the samsung pc studio it asks to put phone in idle mode how do i do this. tried plugging phone in turned off syill says put in idle mode HEEEEEEEEEEEEELP
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 19, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
2684
Points
8
Turn your bluetooth off
3answers
I want to unlock samsung s 5600 how can i do that can you plz tell me
There are many ways to Unlock the PHONE from Network Lock,Unlock code is best to UNLOCK the PHONE from Network Lock,You need to specify the Network Lock and Country?you cannot get some Country Network lock unlocked using the Unlock code.You can get the code from here
www.wickedunlock.com and follow the instructions below and Unlock it step by step:
Samsung S5600 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Samsung S5600 mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung S5600 mobile phone, your phone may get hard locked and sometimes become unusable.
Method 1:
1 - Switch ON your Samsung S5600 with a NOT ACCEPTED SIM Card.
2 - Samsung S5600 will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung S5600 shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung S5600.
3 - Compose : #0111*CODE#.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung S5600 is locked to.
CODE: Its the unique Unlock Code for your Samsung S5600.
If method 2 does not work, you can try method 2 again but this time without any SIM card on your Samsung S5600.
Hi, i hv upgraded my samsung s5603 to s5600, s5600XEIG1, now problem is tat when i try to conect it to pc studio it says an unauthorised model conected comunication can not proceed. pls help me to get out...
Just upgrade the Samsung PC Studio also
The latest version of Samsung PC studio called (NPC)
Download the NPC (new PC) Studio from samsung website and install it on your PC and connect to
to your mobile.
Jun 02, 2011 • Cell Phones
1helpful
How do i install samsung gt-s5600 pc suite?
Download the PC Studio from Samsung Support
Click on Software & download the PC Studio file ~ 165.78MB
Hope it helps.
2answers
CANT CONNECT TO PC
1st Option
FIrst of all if you are trying to install the program from the CD that is provided with the samsung mobile then do not use it.
Uninstall the program from the laptop/PC if you already installed it.
Download the Latest version from here PC SUITE
Click on the Software tab and then "Download" against the PC Studio.
Download and then install and make sure you do not connect the mobile to the PC before installing the full software.
once installed select from the phone
Menu--Settings--Phone Settings--PC Connections--select pc suite --save.
and then connect the mobile with the Data cable.
or
2nd Option
Try this:(if you don't want to install the PC studio)
Menu--Settings--Phone Settings--PC Connections--select Mass Storage and Save.
Now try to connect it.A window will pop up and ask you to use the following for opening up and you select the folder option.
If you don't see a pop up then you see it in my computer as removable disk.
P.S. you will only be able to use your micro SD card content with the 2nd option.
Good Luck.
I cant get pictures of my samsung s5600 onto my laptop. ive installed everything that needs to be installed then i plug it in and 1. it doesnt show up in my computer then 2.the samsung new pc studio say my...
Have you got all the drivers installed? I this case your computer has to see your phone. Google for those, install and after that pic transfer will be easy. As an alternative use BlueTooth connection.
1helpful
Unable to connect my samsung star phone using pc studio mode...
is it tellin "pc studio is performin a time consumin operation. try again later"...... i'm havin the same problen
I could connect after tryin several days:(....
Memory card isnt recgognised!
If the card is inserted correctly and its not damaged, then the memory card should show up under media manager, you need to put the files onto the memory card not on the phone...
When you first insert the card into the phone, you need to format the card, some phones create specific folders for different things when they format, e,g images, Videos, etc. You may need to do this.
I cant remember if this phone had this option but try it anyway as if it works, it should be faster than using Samsung PC Studio...
Close Samsung PC Studio
Unplug USB out of the Phone and a couple of seconds later plug it back in, see if the phone asks you for Mass Storage mode... If it does select that, after a while the Memory Card should show up on your PC just like a USB memory stick you can drag and drop files to it and its faster than going through Samsung PC Studio :)
2answers
Help
transfer music from pc to A727
To transfer files using PC Studio, from a PC to the handset, follow the steps below:
  1. These instructions assume you currently have PC Studio. If you do not, please check the Samsung Accessories site to purchase the software.
  2. If the application is not yet installed, insert the CD into the drive on your PC and follow the on screen instructions to install PC Studio 3.0 (version 3.0.1)
    NOTE: DO NOT CONNECT USB CABLE DURING PC STUDIO INSTALLATION
  3. Confirm the handset's USB mode is set to PC Studio by following the steps below:
    • While in standby mode, press the left soft key for Menu
    • Select Settings (9)
    • Select Connectivity (6)
    • Choose Select USB Mode (4)
    • Highlight PC Studio, using the navigation keys
    • Press the left soft key to Save the USB Mode settings
  4. Launch PC Studio 3.0 (version 3.0.1), you will see "Not Connected" in the bottom right corner
  5. Plug the USB cable into both the handset & the PC, you will now see "SGH-a727 Connected" in the bottom right corner (See example below) a727%20connected.jpg
  6. Click on Transfer Files, you will now see the PC Studio Phone Explorer appear a727%20phone%20explorer.jpg
  7. Navigate to the location of the file(s) to transfer then highlight the desired file(s)
  8. Click on To Phone, on the Phone Explorer menu bar (See example above) to copy to the handset
  9. From the Search Folder screen, Navigate to the desired destination on the handset
  10. Click OK to copy the selected file to the handset's memory
PC Studio Checklist:
  1. Make sure your USB or Serial cable is compatible with your phone model. You can always check for the correct data cable by looking at the model number on samsungmobile.com in your phone's accessories section.
  2. If you are using a Bluetooth dongle or IrDA port as your connection, the necessary driver(s) should be provided with their data kit and should be correctly installed and set up prior to the installation of PC Studio.
Hints & Tips:
  • Remember to select file formats and file sizes supported by the phone when uploading files to the phone from the PC.
  • Remember to select the correct destination folder in the phone when uploading files to the phone from the PC (e.g. mp3/aac files-> music folder, jpeg/gif files-> downloaded images folder, 3gp/mpeg4 files-> downloaded videos folder...)
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
