Question about ZENITH/BATHWARE 2114S CHR Wire Corn Tub Caddy
My shower pole caddy is either too tall using the tension spring or too short without. How do I make the adjustment. The pole sits on the tub.
I had the same problem. The only solution is to cut the shorter rod to the desired size. After I cut it, it fits perfectly over the bathtub. Hope this helps!
Posted on Sep 20, 2010
  • 2 more comments
  • swingdance12 Feb 28, 2011
    What did you use to cut the rod?
  • MuruGun Feb 28, 2011
    I used a metal hand saw from Wal-mart. Depending on how thick the metal is, you will need to get the appropriate size. If you don't want the trouble, you could take the rods to Home Depot - they will cut it for you for a small fee.
    I already said this - a standard metal hand saw from Wal-mart. You can also get it at any hardware store like Home Depot.
I have the threshold shower tension rod, caddy and I can't get it together. Any assembly instructions somewhere?
Here are some resources that might help:
https://www.youtube.com/watch?v=6E8-veC9vvk
https://www.youtube.com/watch?v=dRDyf_NrFo8
Most tension rod caddies assemble in basically the same way, so while I don't find instructions for your model, these may be similar:
http://pdf.lowes.com/installationguides/030786414517_install.pdf
Nov 07, 2017 | Home
How do you adjust tension on the chain of a ryobi pole saw
Try Googling (Ryobi)(model)(manual) without parens to get instructions.
Sep 18, 2017 | Ryobi Garden
Bought the 4 shelf shower spring loaded shower caddy need instructions please
The first thing you can do is to drill the exact hole for the tox.After drilling,put the tox to the hole and hang the shower caddy and then you can put the screw.
Jul 17, 2011 | Home
I purchased a tension pole shower caddy and can't get the spring to work. How do I fix this?
You may need to twist the pole to unlock the spring,or there is a spacer missing inside the pole
Jan 12, 2011 | Home
At what height is the shower rough in body installed
I set my valve were it feels comfortable when i stand up in there tub or shower.Most people shower any way.. the one sitting in the tub can still reach it I usually set shower valves at 42 to 44 inches and the shower arm at 74-78. You want it I usually rough the tub and shower valve spout at 4" above the tub rim, shower valve 10" above the spout. This is for tub and shower combo.
Aug 08, 2010 | Delta & Single Handle Shower Faucet
Can''t get tension rod to have tension to make it fit in shower/bathtub area
There are basically two types that I have seen one is spring loaded (this has limited travel and once the spring has fully expanded that's it, the other is a two part rod that you take either side of the split and turn in opposite directions this loosens the rod so you can move it out. You hold the rod so both ends are touching either side and twist each section in opposite direction this tightens the ends against the wall the more you twist the tighter it gets. I hope this helps. Good Luck and have a great day. Jeff
Mar 28, 2010 | NRS Zenith 7601S Bathstyles Adjustable...
Cant ajust tensioner pully
You have a (spring loaded) tensioner. I usually use a rachet and whatever size socket the bolt requires and use a 2 foot hollow pole as a pull handle.. Put the socket and rachet on the bolt, slip the pole over the handle of the rachet and push the tensioner back which will give you the slack room you need to install the belt. Make sure you have the belt around all the other pulley's so it will be a easier to slip it on to your tensioner. This tensioner should adjust itself by spring action.
Jan 24, 2010 | 1993 Ford Explorer Limited
Adjustable (tension) shower curtain rod too long
Yes you can ! You only have to pull off the rubber end cap and cut it , file off ant burrs. Cut the SMALLER diameter end only, the other end contains the spring !
Nov 16, 2009 | Rocky Mountain Hardware Shower Curtain Rod...
How do I put together the pole caddy (4 shelf) with spring? did not come with instructions.
Put the poles together eith the spring section on the top. Otherwise, the weight of what you put on it will pull it down.
Jan 07, 2009 | ZENITH/BATHWARE 2114S CHR Wire Corn Tub...
ZENITH/BATHWARE 2114S CHR Wire Corn Tub Caddy Logo
809 people viewed this question
Top Zenith Home Experts
Donni Steen
Tom Chichester
Are you a Zenith Home Expert? Answer questions, earn points and help others
