Question about Hitachi 18V Lithium Ion Cordless Hammer Drill DV18DL
My battery charger is not working. it looks like a faulty transistor of some sort the number on the part that is clearly broken / cracked is no. c5353 can i replace this part? and where do i get it from? another question, i am thinking of buying a cheap 120vac charger ($35 ebay) and removing the tranformer and replacing it with the one from my 240v batterycharger has anyone done this? will it work?
Battery and or charger won't work. Charged a full 18 hrs. Help
Possible suspects are:
1. A severely drained battery.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
Nov 27, 2015 | Motorcycles
Battery is not working well
Step 1:
which operating system ? and type of laptop ?
If your laptop charger seems broken, it's most likely because the battery will not charge. You plug in the cord, the lights come on, but the charging light doesn't change or blinks repeatedly. When you remove the power cord, the laptop shuts off instantly due to the depleted battery. There's more than one cause for this, and it's not always a broken charger.
Check the connection between the charger and the laptop. It should fit firmly in the DC jack without wiggling. If it is loose, use electrical tape to hold it in place so the charger can receive power. This is a temporary fix, however, because a faulty connection can create sparks and cause a fire or injury. A loose connection will just get worse over time, so have it sent to a DC jack specialist as soon as possible. Turn off the laptop and flip it upside down. Locate the latch that secures the battery and slide open. The battery should pop out; give it a tug if it doesn't. Apply a small amount of rubbing alcohol (Methylated Spirits)to the tip of a cotton swab and use it to clean the battery's connectors. Dirt can build up and interfere with the connection, giving the appearance of a broken charger. Let the alcohol dry completely and re-insert the battery. Slide the latch to secure it and plug in the power cord to test it. See if the laptop powers on with the charger only and battery removed. If it does, the battery is the likely culprit and should be replaced. If the charger is truly broken, the only thing to do is to replace it or the power cord attached to it. Look on the bottom and write down the part number. Call the laptop manufacturer for a replacement charger or search for the part number on eBay. If you purchase from anyone other than the original manufacturer, ask for genuine parts to reduce the possibility of problems. Troubleshoot Mag Safe adaptors
http://support.apple.com/kb/ts1713
Feb 20, 2013 | Computers & Internet
Wont power on
Step 1:
Feb 19, 2013 | Computers & Internet
Studio 1737 wont recognize charger
Step 1:
Feb 15, 2013 | Dell Studio Computers & Internet
Charging port doesnt work
Feb 09, 2013 | Samsung " 17.3"" Laptop - 4GB Memory -...
Musical fidelity amp x-a2, one channel intermittent crackling / fading out, any ideas?! Tried swapping source and speakers... Many thanks -chris
hi,
This problem will occur when any one of the driver transistor is become faulty. You have to replace all the driver transistor of the same channel which make cracking sound . It is very difficult to tell which one is faulty. Because if you check the transistors with multimeter it will be ok. Replace all the driver transistor in that channel with same part number marked on it. The driver transistors will look like this,
ajin_g_6.jpg ok
May 20, 2011 | Car Audio & Video
I own a Bajaj Kristal scooteret since jan 08. Perennial starting trouble. Company authorised service centres have never paid any serious attn to my persistant pleas to sort out the design issues with their...
Hi Jaivijai1, in order to check out any main system electrical circuit, you have to start with a fully charged battery 12.5 volts or better, and be able to pass a load test if necessary.
1. Check battery terminals for damage or corrosion, check battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with ohm meter if necessary.
2. Check the voltage drop at the battery when you hit the starter button, anything below 9 volts you might have a faulty battery.
3. Check voltage at the battery with the bike running at 3,600 RPM should be 14.3 to 14.7 volts. If you are not getting these numbers you might have a faulty voltage regulator.
4. Make sure voltage regulator is grounded and functioning properly, watch video below on how to test a voltage regulator.
5. Unplug the connector to the alternator and hook your multimeter leads to the alternator (pin/socket selection does not matter) set the multimeter to AC volts, at an idle the meter should read 16 to 20 volts AC. at 2,000 RPM 32 to 40 AC volts, 3,000 RPM 48 to 60 AC volts. If you are not getting these numbers you may have a faulty rotor, follow step 6
6. Set the multimeter to OHM'S, connect one lead to the alternator (any pin/socket) and the other to ground, meter should read infinity. Connect both leads to the alternator meter should read 0.1 to 0.2 OHM'S. If you are not getting these numbers you have a bad stator.
7. Check all wiring in the charging circuit for worn or chaffed spots and all wiring connectors in the circuit for corroded, broken, or loose pins/sockets, which is the # 1 offender.
For more information about your issue please visit the websites below. Good luck and have a nice day.
Bajaj Wave DTS 2006 service manual DOWNLOAD FREE FULLMANUALS COM
Mar 10, 2011 | 2006 Bajaj Wave
There is a hissing noise in back of tv and picture goes on and off zenith d36d51
Hissing noise and picture on and off means faulty flyback transformer, it has a small crack and voltage is leaking out, replace the flyback, if tv still not working replace horizontal output transistor (broken flyback could blow the transistor).
Aug 09, 2009 | Zenith D36D51 36" TV
No Power Up
The battery charger inside the UPS is faulty so check the transistors including the rectifier on the heat sink. Replace the faulty ones and your UPS will be good. I strongly suggest that you check all the transistors on the PC board just to make sure that the whole board is ok after replacing the transistors
Mar 25, 2009 | Powerware 9120 UPS System
Hitachi 18V Lithium Ion Cordless Hammer Drill DV18DL Logo
137 people viewed this question
Top Hitachi Drills Experts
John Trevino
Are you a Hitachi Drill Expert? Answer questions, earn points and help others
