Question about Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher
I have a Firdgedaire Electrolux model GLD4355RFB1 DISHWASHER AND an Error message is appearing with flashing lights. The dishwasher will not run. How to I get back up and running? Is it a major issue?
  • 530 Answers
What is the code?
Posted on May 17, 2010
How do i fix electrolux dishwasher when error code 1 is flashing
Hello friend, thanks for your post!
I see your Electrolux dishwasher is displaying an "E1" error code. "E1" stands for a leak detected which means your dishwasher base has detected a leak. If you can't see a leak you may want to perform a reset on your dishwasher you can do that by disconnecting the power from your appliance for roughly ten minutes.
If that does not correct the issue you may want to seek assistance from a technician. They would need to come out to diagnosis and repair your dishwasher. I hope this information has been helpful. -Matt
Oct 03, 2014 | Electrolux Dishwashers
E4 always appears on the display of my electrolux ewt604s, what is the quickest solution to fix the problem?
http://www.electrolux.co.nz/Support/Manuals/?modeld=ewt604s
No easy answer.Electrolux does not recognise your model number or list error e4. I can only wish you good luck. and a few links that may help. Phone numbers and address at web address above.
If it won't open, copy and paste to your browser bar.
Electrolux Dishwasher Parts Accessories
electrolux dishwasher troubleshooting YouTube
Sep 13, 2014 | Dishwashers
Electrolux dishwasher won't run through a cycle?
So it would be desirable to write the ERROR appeared in
Dado
Aug 02, 2014 | Electrolux 24 " White Built-In Dishwasher...
Electrolux dishwasher not completing wash cycle and all lights flashing on door control panel and the 'wash pump' error light behind the lower kick space panel was flashing.
Good Morning friend, thanks for your post!
After researching the issue you are having with your Electrolux dishwasher it is possible that resetting your appliance may help. I would disconnect power from your dishwasher by unplugging it or flipping the household breaker for roughly ten minutes. If this does not resolve your issue I would recommend seeking assistance from a professional to properly diagnose and repair your dishwasher. -T
Jan 23, 2014 | Electrolux Dishwashers
Hi, our ariston dishwasher has stopped before the cycle finished and the water has not drained out. There are 2 flashing lights - the brush emblem and the spray ' on a tilt' emblem (the 2 on the...
Error messages.
The dishwasher is equipped with a
safety system which is able to
detect any operating anomalies.
These anomalies are signalled by
the rapid flashing of one of the
wash cycle indicator lights M.
If the indicator light for the soak
cycle flashes (see wash cycle table),
cancel the wash cycle by following
the instructions indicated in the
"Modifying a wash cycle in
progress" paragraph on page 4.
Now check whether there is any
water in the mains supply and that
the tap is turned on; if the error
message persists, then call for
technical assistance, indicating
which message appeared.
If the indicator light for any wash
cycle apart from the soak cycle
flashes rapidly, turn the appliance
off and call for technical
assistance, indicating which
message appeared.
Troubleshooting
You have checked
everything, but the
dishwasher still doesn't
work and the problem
persists?
Call an authorised service centre
near you and remember to mention:
? the type of malfunction
? the model mark (Mod?.) and the
serial number (S/N?.) indicated on
the rating plate located on the inner
door, to one side.
Jan 14, 2018 | Hotpoint-Ariston LI 640 24 in Builtin...
I have an electrolux dishwasher model #=EIDW6105gS0. All lights are flashing on the console and will not let me select any of the modes...will not run at all. Is there any way to reset? I have tried...
Sorry for the delay in replying to you, but there has been a technical fault and we have not been able to answer your question.
The 6105G does not have a numeric display, so all of the LEDs flash when a fault is detected, but this does not indicate which fault has been detected. Resetting the dishwasher should clear the error message, but if there is a fault, the flashing LEDs will return after resetting the washer and further investigation will be needed to determine the cause of the fault.
You should be able to reset the dishwasher by entering the engineering test mode and then cancelling it:
1. Switch off the main power to the dishwasher or reset the breaker.
2. Switch the power on again.
3. Press SANITIZE and DELAY START simultaneously.
4. Press the START/CANCEL button to exit
5. Reset the power again.
Please try the above, then let me know if you the error persists and you need further assistance. You can reply to me by clicking on "Add a Comment" below your question.
Regards,
BElectric
Apr 06, 2011 | Electrolux Frigidaire Professional Series...
All the light on my new, Electrolux dishwasher are
Remove the kickplate at the bottom of your dishwasher and see what error you are getting. Likely a leak error.Dishwasher likely has leaked into drip pan underneath. Unfortunately, you need to remove dishwasher and flip onto back and remove 3 phillips screws that hold drip pan in place. Install "leak kit" to correct leak problem with this model of dishwasher. Part number is 154769101
Jan 25, 2010 | Electrolux 24 in. EDW5500DSS Stainless...
HO message flashing
My service guy told me this was due to the water coming into the dishwasher not being hot enough. He suggested I run the hot water in my kitchen sink prior to running the dishwasher. That seemed to resolve my issue.
Dec 28, 2009 | Electrolux Frigidaire Professional Series...
Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
532 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
