Question about Air Tools & Compressors
The staples are not going through the bamboo flooring all the time. they seem to bunch up every other staple. stapling into the plywood subflooring and have the compressor at 90 psi
  • 79 Answers
Your anvil slide is worn. They bunch up because of too much play in the slide area for the anvil. THis should be cured with rebuild of the head.
Posted on Jan 15, 2010
Stanley Tr250 bends 5/16" staples just going into plywood, penetrates one side or both only 2/3 way in for simple upholstry, any adjustments?
use the shorter staple
increase the punch pressure when the trigger is released ( there is an adjustment on the side for that purpose )
Dec 10, 2016 | Stanley Tools & Hardware - Others
Trying stable leather
quite likely you have the wrong staples for the task ..I bought an electric stapler just for heavy jobs .and it drives all I have tried to the bottom every time .
Nov 12, 2015 | Staples Tools & Hardware - Others
Does the bamboo flooring installation process differ from laminate flooring installations?
Bamboo flooring comes in three styles, solid, engineered, and click lock. The click lock and engineered are virtually designed just like laminate flooring, the only difference is the installation. Engineered has to be either nailed, stapled or glued down (depending on the subfloor, whether it is concrete or wood). The click lock is a floating floor and is installed the exact same as laminate flooring. Whether its on wood, or concrete it doesn't get nailed or glued at all.
Sep 28, 2015 | Building Materials
What staples does a black and decker electric stapler 9700 take and where can I buy them?
Hi Stephen,
Of course the manual states to use their staples for best results.
However it does at least state it is designed for a wide variety.
Most hardware stores have a range of staples to choose from.
Home Depot, Harbor Freight, Lowes etc. Try a chisel point this may help penetrate the wood deep enough. All staples are not made the same. So again trial and error may be the quickest route. Fortunately you can purchase small boxes for your testing.
The manual for this stapler is here:
(Page 2 talks about the staples to use.)
Black Decker 9701 Instruction Manual Page 2
Good luck and hope this helps!
Jan 04, 2015 | Arrow Tools & Hardware - Others
How many different methods of installation are there for bamboo floors?
There are four main ways to install bamboo floor. You can install it by nailing, by stapling down, by gluing-down and by floating.
Feb 06, 2013 | Building Materials
I rented a Bostitch Floor Nailer from Home Depot, and the nails wont set into the maple flooring. Iv used three different compressors(all set to 90psi) and 4 different Bostitch Nail Guns. Im going out of...
Ive had the same problem where it was putting divits you could see from the staples, we ended up changing out the flooring completely. Only thing besides trying diff psi's to get it perfect and different length staples/different heads on staples(nails) , maybe try staple gun. Keep trying every woods different, odd that it started half way through job.. odd.
Jul 15, 2011 | Stanley Bostitch MIIIFN Flooring Nailers
I can not get the staples to go all the way into plywood
Try using both hands on the stapler. One on the handle with the other forcing down with your palm directly in line with the direction of the exiting staple. Some times this will allow the staple penetrate better. Make sure the stapler is square and firm on the work surface. Good luck!
Mar 05, 2011 | Stanley Proto Stanley TR150HL SharpShooter...
Staples not going in deepenough
Several things to check:
Air pressure. (Use manufacturer's recommended)
Nice smooth swing of the mallet.
Hose length NOT too long.(friction of air in hose can reduce the flow)
Proper amount of lube oil used.
Correct sole plate for the thickness of wood.
I found that driving 2 inch staples through bamboo would not work. I had to use 1.5 inch ones. This was into 3/4 T&G plywood. If you have OSB instead of plywood, I suspect you MIGHT have trouble, period! OSB is pretty hard.
Oct 20, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
Question regarding Bostitch MIIIFN or MIIIFS
Read the warranty for Woven Strand Bamboo floors. I think you find this is the wrong tool. You`ll probably find that you need an 18ga 1/4" crown, so it don`t split!
Thanks,
Jeff
May 02, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
I AM HAVING TROUBLE OUT OF MY BOSTITCH MIIIFS FLOOR NAILER
D Farley,
I repair these nailers all the time. Anytime the nail or staple is bending you have 2 causes. Either the stapler has a broken blade, the magazine is loose on the foot gate, or you are shooting into plywood over concrete. that is allowing the staple to hit the cement subfloor. Use 11 /2" staples on 3/4" wood floor over 3/4" plywood when over concrete.
Dec 16, 2008 | Stanley Bostitch MIIIFN Flooring Nailers
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
