Question about Bass Pro STC-DVIR5 Digital Camera
I can not change the settings on this camera the settings blink but they wont change whrn i push buttons to change it its a stealthcam stc-dvir5
Stealthcam model STC-G26NG-BULK
Google search your manufacturer make, model and word reset. You will find how to reset the phone, which will clear your password for you.
May 24, 2015 | Computers & Internet
How Do I Reset Date/Time on a Stealth Cam STC-U732IRNG?
SET TIME AND DATE:
1. Switch the camera to the ON position.
2. Press the [MENU] button to enter menu settings screen.
3. Press the [UP] or [DN] button until the word PIR blinking.
4. Press the [OK] button to confirm.
5. Press the [UP] or [DN] button to scroll through different setting modes
until the word TIME blinking.
6. Press the [OK] button to choose the Time settings.
7. Press the [UP] or [DN] button to adjust the Minute setting and press [OK]
to confirm and move to the Hour setting.
8. Repeat to set Hour and then press [OK] to confirm and move to Date.
9. Adjust the Month, Day and Year by using [UP] or [DN] button. Each time
you finish an adjustment you must press the [OK] button to confirm and
move to the next field for adjustment.
10.Once done, the word - dEL - will be blinking.
11. Press the [MENU] button to exit and start using.
Nov 16, 2014 | Cameras
Lost security code for stealthcam
check the owner manual--most have a default that will always work or Contact maker for assistance.
Nov 06, 2012 | Stealth Cam STEALTHCAM STCZ3IRTL CORE...
Stealthcamsecurity stc-slc2b free software
Are you aware you have this posted in the Car and Truck category? Please post the question in the proper category so the appropriate expert will see it.
Feb 09, 2012 | Cars & Trucks
On the read out of no of pictures it shows loc and can not get it cleared
I have a Stealth Cam Skout 7. The screen displays Loc or Lock. To fix this.. On the side of your SD card there should be a little rectangle that will slide back and forth. Slide it the opposite way to unlock it.
Sep 11, 2011 | Stealth Cam The Unit 8.0 Megapixel...
I don't khow ho to change stc possward
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
If you need more help post back! Thumbs and testimonial are welcome!
Jan 16, 2011 | Computers & Internet
Bass Pro STC-DVIR5 Digital Camera Logo
23 people viewed this question
Top Bass Pro Cameras Experts
Are you a Bass Pro Camera Expert? Answer questions, earn points and help others
