Question about 3M S55i Projector
New lamp required - 3M S55i Projector
  • 2,237 Answers
You should be able to find one anywhere on line. but be sure to reset the lamp timer after you do replace it.
Posted on Jan 27, 2010
Lamp not working
The model of projector determines the correct lamp required. If a new lamp does not illuminate, there are 3 or 4 possibilities:
1. The Lamp Thermal Fuse is open (non-functional).
2. The Power Switch is non-functional.
3. The Lamp Socket is defective.
4. The new lamp is non-functional (burned out).
I hope this helps!!
Dec 27, 2013 | Office Equipment & Supplies
Tv doesn't turn on. red light is lit in front of tv where is says lamp.wHAT IS THE PROBLEM. iF LAMP IS THE PROBLEM WHAT WILL IT COST FOR REPLACEMENT FOR THE 50DL54J lamp
Yes I would say a new lamp is required.
Lamp prices vary dependant on location and your chosen dealer.
Look online for a new lamp, it should be a good price.
Don't forget to reset the lamp life meter.
Oct 17, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Picture is dark
The projection lamp require changing.The lamp picture is dim the lamp is close to the end of it life.Require a new lamp.
Sep 01, 2010 | Hitachi 42V710 42" Rear Projection HDTV
I have a rca d52w20 rear projection tv that has sound but no picture what may be the problem
When was the last time the tv projection lamp was change in this tv?The projection lamp in the tv now,if 1 1/2 or 2 years olds,tv on an in uesd like 4 or 5 hours a day?The projection lamp life is over.Require a new projection lamp.Hear alot of clicking too?The board call the Ballast board also require changing.This Ballast board help to ingnite the projection lamp.
Aug 21, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Ordering new lamp for Sony LDF-60xs955. Should I order just lamp or lamp in casing? Will direction to install it come with lamp?
It depends on the seller. The lamp in the housing allows you to just slide in a new lamp, really really easy. The bulb is a bit trickier but still very easy to change out. This one is a little harder, but if you buy it from like www.dlplampsource.com I believe they will send you directions. There are basically 2 wires you have to transfer over and you have to disassemble and reassemble the case to get it in there. Tools required = philips screwdriver and some pliers (medium side needlenose work best) ... Best of luck, if you need help, I can help you put the bulb in if required.
Jul 27, 2010 | Sony Televison & Video
Tv comes on for about two minutes then shuts down. The lights stay lit.
Any LED light indicators on the screen panel said "LAMP"stay lit or blinking?The projection lamp life is over,require a new lamp,if "LAMP" LED light lite or blinking?The projection lamp in the tv now,been in use for at leat 2 years and tv on about 4 to 5 hours a day?The Lamp life span is over,require a new lamp.
Jun 11, 2010 | Samsung SP 56 K 3 HV 56" Projection...
Replacing lamp
Lamp replacement procedure is written in user manual,check page-17
Click Sony Support to download free copy of user manual of KDF-60WF655 if required.
There are two thumb screws at lower corners if you see tv from rear, remove these screws and take out lower front panel, in center of that space, you will see lamp cover, remove it and unscrew old lamp, pull it out and put new lamp then put things back in reveres order.
Required lamp of KDF-60WF655 is available in Sony Accessories Store for $200 under part number XL-2200
Hope these info will help you.
Thanks.
May 13, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Just replaced vt700 lamp. projector still indicating faulty lamp. i also reset the lamp hrs by pressing help on remote. can any one help thanks
Try the old lamp again and reset again and see if that works. When you originally replaced the lamp did it give you a warning that replacement was required or did it just stop? I haven't worked on that model before but you may require a new Ballast (power supply ) that runs the lamp (technician job usually)
Dec 26, 2009 | NEC REPLACEMENT LAMP FOR VT700
I replaced the old lamp with new very carfuly and exact same way but now im getting a red light on in power and lamp and no light from lamp,is there a in fuse or something? what could be wrong?
Often a lamp reset procedure is required as well as changing the lamp over. not sure for the hitachi's (check Manual) over models often requires holding poweer button while plugging into power to reset the counter.
Dec 17, 2009 | Hitachi (DT00401) Projector Lamp for...
KDS 50A2000 red lamp light blinking 2 times
Did you use an original Sony lamp? If so, I would say that the problem lies with your lamp ballast, or lamp power supply. Also, keep in mind that, although rare, occasionally the lamp power supply will fail in such a way that it will take out the lamp and any other lamp that is put in. So if your new lamp is blown, it is likely the lamp power supply that is at fault and you will require a new lamp as well.
Dec 10, 2008 | Sony KDS-50A2000 50" HDTV
3M S55i Projector Logo
Top 3M Office Equipment & Supplies Experts
jasbo
jasbo
Are you a 3M Office Equipment and Supply Expert? Answer questions, earn points and help others
