Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Problem for Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright...
How is the V-belt tension adjusted (Hoover Model
By jlhpgh on Oct 07, 2009
How is the V-belt tension adjusted (Hoover Model U6439-900)or how do I know if the tension is correct? There seems to be a lot of "play" in the belt and I'm wondering if that is the reason the brush roll only turns as the wheels turn, regardless of the carpet height setting. And yes, the brush roll is set for carpet, not hard floor. Or is the cause of the problem something other than the V-belt? A new flat belt was installed when the machine was professionally serviced so I assume (?) that was adjusted correctly.
Solution #1
posted on Oct 07, 2009
Somewhat Helpful)
rkintz
Rank: Wiz  Vacuums  Expert
Rating: 82%, 61 votes
The V-Belt is not adjustable. There are two ways the belt has no tension: (1) when the handle is upright, a mechanical lever takes the drive tension off the belt, and (2) the brush roll lever setting you described. The upper handle would have to be in the floor cleaning position to check the belt, not in the storage position.
Was this helpful?
Yes
No
Popular Solutions for Hoover U6437-900 / U6439-900
Questions and Unsolved Problems for Hoover U6437-900 / U6439-900
Do you recommend Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum?
Answer
Answer
the light on my hoover wind tunnel self propelled bag vacuum cleaner is stuck on the red light and... (More)
Answer
how do you change the belt on a hoover wind tunnel vacumn/ not self propelled?
Answer
The red light is always on even when the vac is off the floor
Answer
Adjusting the height and brush control do not work. Belts are good. Is there a site where I can see... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Vacuums Experts
Top Vacuum Repairmen
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
