Question about Tag Heuer WK1111BA0317 wristwatch
My watch stops and starts - for example I will wake up in the morning and the watch will be ticking but the time will be 6 hours behind the actual time
  • 38 Answers
From experience this generally happens when the battery is low, the tick will appear normal however the time does go round in sync with it. Replace battery would be my first point of call
Posted on Oct 07, 2009
Please stop telling people Rolex watches don't tick.
Yes, absolutely correct , all automatic watches tick and the fake Rolexes just tick a bit slower so it is more visible.
Oct 08, 2012 | Rolex Watches
I have model fs-2919 would like to know what the other dials are for i dont have the booklet thanks for your help
The three small dials on this watch are all part of a "stopwatch" system. The small dial at the 12 o'clock is for tenths of a second( each half circle completed is one second or 1 whole rotation equals 2 seconds.) the small dial at the 6 o'clock counts a full 60 seconds for each revolution, and the dial at the 9 o'clock counts minutes(one full circle equaling an hour.) when the stop watch is started the 12 o'clock and 6 o'clock dials will start at the same time. you will notice that every half turn on the top dial equals one "tick" on the bottom dial. After the first minute of timing the top dial will stop ticking as it is for more precise timing of things that take less than 1 minute. each full rotation of the bottom dial will then equate to one "tick" of the 9 o'clock dial. hence the three dials counting tenths of a second, seconds and minutes. the setting of these dials is fairly easy once you understand the purpose. on the side of the watch there are two buttons(one top and one bottom) with a setting wheel in the center. When in use the top button starts and stops the stopwatch and the bottom button resets the counters. To set the watch simply pull the center wheel away from the watch all the way(2 clicks) set your minute hand and hour hand and then tap the bottom button repeatedly until the small dials all line up straight up. once that is done push the center wheel button halfway into the watch or one click to set the date. then simply push the wheel the rest of the way in and voila!!! hope this answers some questions
Apr 05, 2011 | Fossil FS2919 Wrist Watch
Module 3070 - PAW1300 > AM / PM problem apparently. Everything works except day and date 12 hours behind. EX: In HNL (Honolulu) on Monday morning, September 6 watch gives correct time, but shows SUN...
Hi, Obviously you need to roll the time 12 hours ahead. If the watch doesn't receive the Atomic signal properly at first, go to page three of your manual, and try doing it manually following the detailed procedures there.
If you don't have the manual, get it here:
http://world.casio.com/wat/download/en/manual/
Take the four-digit (3070) module number from the back of the watch, enter it, and download a PDF of your watch setting-instructions/manual.
I hope this helps you. Thanks, Bill
Sep 07, 2010 | Casio Pathfinder Watch Green PAW1300 3V
Need a user manual for the time magazine free chronograph watch
I have NO ideal what kind of watch it is so I am giving general chronograph instructions. You will have to use as it applies to the watch you were given.
These instructions are provided for users who are not familiar with using a mechanical/analog chronograph. The instructions may be applied to any chronograph that has a seconds counter, 30 minute counter, and hour counter.
Please refer to the instructions of the appropriate model to determine the location of each counter on the dial. Note: some of the features described here may not be available on your particular model. Again, refer to the specifications to see if they apply to your model.
Using the chronographe functions:
How to read the chronographe:
For a chronographe that has a center seconds register, a 30 minute register and an hour register. Example 1: If the hour register is between the 1 and 2, but closer to the 1, and the minute register is at 20, and the seconds register is at 35, then the elapsed time is 1 hour 20 minutes and 35 seconds. Example 2: If the hour register is between the 1 and 2, but closer to the 2, and the minute register is at 20, and the seconds register is at 35, then the elapsed time is 1 hour 50 minutes and 35 seconds.
How to read the tachymetre:
If you are driving and want to determine the speed of the car using your tachymetre, start your chronograph when you pass a mile marker, stop your chronographe when you pass the next mile marker. Look at the center seconds hand and read the number on the Tachymetre scale, this number will indicate the miles per hour that the vehicle is travelling.
How to read the pulsometer:
Some watches have a pulsometer instead of a tachymetre. Use it as follows: Start the chronographe and begin counting the pulse. When you have counted 30 beats, stop the chronographe. The number on the pulsometer scale will indicate the pulse rate per minute.
How to read the telemeter:
Some watches have a telemeter instead of a tachymetre or pulsometer. Here is an example of one use for a telemeter: Start the chronographe when you see lighting. Stop the chronographe when you hear the thunder. Read the center seconds hand on the Telemetric scale and the number will indicate the distance separating the observer from the place where the lighting struck. This can give you a good indication of how far off a storm might be.
The many uses of a chronographe:
A chronograph has many practical uses, from timing a plane flight, a car ride, or simply being curious. There are also some uses for the chronographe that may not be so obvious. For example, you can use the chronographe on your watch as a dual timezone indicator. This is done as follows: If it is currently 6 A.M. in your home location and it is 12 noon in London, start your chronograph at exactly 6 o'clock. The number of hours displayed on your chronographe hour register will then show you the current time in London. Of course, these are just some uses of a chronographe. There are hundreds of uses for chronographes.
Instructions: Astronic Chronograph Chronograph Chronometer Power Reserve Chronometer Astronic Chronometer World Time Chronometer Retro Alarm General Chronograph Common Q & A's
Aug 12, 2010 | Watches
I have a forestville wall clock with the pull down weights. when it chimes it is behind in time. example nine oclock chimes seven oclock, it is a made in germany clock but what year i do not know. there...
Stop the pendulum of the clock exactly at any even hour. Lets say at 6.00. While clock is steady and not working, pull off the minute and hour hands off the pinion, but do not brake them. You have to pull without any twisting action. This will leave pinions exactly in place they were when you stopped the clock. When it is done - push the hour hand back onto the pinion and make sure it is pointing at 4 (not 6, as it was when you stopped the clock). When hour hand is back in place and pointing at 4, push back minute hand as it was when you pulled it off - pointing at 12. Make sure hands will not catch when passing each other (you can bend them slightly if needed). Now swing pendulum to start the clock and adjust time (clockwise only). Never adjust time when clock is chiming. Rate me, plz.
Feb 02, 2010 | Watches
I have a Starter Brand Watch that did not come with a manual. I can't seem to get the chime to stop chiming on the hour.
Just bought a STARTER Sport Watch Model# STW14 @Walmart
TO CHANGE TIME:
1. Press and release MODE button quickly 3X in a row(top middle no.(Seconds will flash)& change Seconds by pressing START button 2. Press & release RESET button 1X quickly(Minutes will flash) & you change Minutes by pressing START button 3.Press & release RESET button 1X quickly(Hour will flash) & you change Hour by pressing START button. 4.Press & release RESET button 1X quickly(Date will flash) & you change Date by pressing START button.5.Press & release RESET button 1X quickly(Month will flash) & you change Month by pressing START button 6. Press & release RESET button 1X quickly(Day of week will flash) & you change Day by pressing START button 7. Press & release MODE button 1X quickly to return to Normal use
TO SET ALARM: 1. Press and release MODE button quickly 2X in a row(Hour will flash)& you change Hour by pressing START button 2.Press and release RESET button quickly 1X (Minutes will flash)& you change Minute by pressing START button 3. Press & release MODE button 1X quickly to return to Normal use
TO VIEW MONTH & DAY: 1. Press & Hold START button 2.Just Release START button to return to normal use.
TO USE STOP WATCH: 1. Press and Release MODE button quickly 1X 2. To START stop watch: Press START 1X quickly 3. To STOP Stop watch: Press Reset button 1X quickly 4. To RESET Stop watch: Press & Hold START button and press RESET button quickly @ the same time, 2X in a row 5.Press & Release MODE button 1X quickly to return to Normal use
Sep 12, 2009 | Bulova Watch
Rolex watch yacht master set time
Let me start by saying that I own this watch and LOVE it!
To set the time you need to pull the crown all the way out to the furthest position.
To set the date you need to have the crown in the position in between the "winding" position and the "time set" position. Basically, pull the crown out till you hear/feel 1 click to wind, 2 clicks (total) to set the date, and 3 (total) clicks to set the time. I always set the date first to 1 day behind the current date. I then move the crown out to set the time so that I can set the watch to either AM/PM depending on the actual time. For example, I set my Rolex today (the 5th of January at 3pm - just an example). I would first move the crown to the date setting function and move it to January 4. I would then move it out one more position to set the time. I would go around the watch until the date changed to the 5th and then go around from 12 to 12 to change from AM to PM. I would then move it to the 3 and then I'm all set. This is helpful because it will ensure that your date will correctly change when the day changes and not be 12 hours behind.
Jan 03, 2009 | Watches
Need instructions for Timex 1440 Sport watch
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to sesume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
Nov 22, 2008 | Timex 1440 Nylon watch
Restarting my Citizen Promaster Eco Divers 200 Watch
Since it's eco-drive you can just wear it for a few hours and it should self-wind. The problem is that when it sits still for more than a few days it winds down. It gets its power from the natural movement of your wrist as you walk around.
Once it starts ticking again you'll just have to set the time correctly.
Dec 18, 2007 | Citizen Eco-Drive BL006056H Wrist Watch
How do I change time on timex watch?
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
CHRONOGRAPH
Have fun! - Not a bad watch for the money! - - Silver Bullet
Mar 16, 2007 | Timex 5B841 Wristwatch
Tag Heuer WK1111BA0317 wristwatch Logo
995 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
