Question about IBM ThinkPad G41 Notebook
IBM G41 turns on but has no video output and gives a three beep sound? What could this mean?
    Problem Solver:
  • 5 Answers
This could be the problem of ur vga card which is on board(built in).to check it just press the keyboard at the space button hardly and then turn your machine on.
Posted on Oct 07, 2009
Boot problems
SOURCE:No boot No video on new built pc with a msi motherboard a55m-p33 amd, three beeps at start up.
Hello here is the homepage:
http://www.msi.com/product/mb/A55M-P33.html#/?div=Driver&os=Win8%2064
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
Tree beeps means you have a ram module failure, or not inserted correctly.
This mainboard uses DDR3 ram, up to 16 gb.
Try to start with only one module at the time.
Try also to check the manual:
http://www.msi.com/product/mb/A55M-P33.html#/?div=Manual
Jan 14, 2014 | MSI INTEL G41 INTEGRATED VGA-MATX 2DDR3...
I'm new at building PCs, but once I got all the hardware installed and turned it on, I could get no video output. I tried with the motherboard video and then with a PCI-E video card and neither would...
Sounds like something like your ram or processor are no good yet.
If it doesn't give any kind of beep, start over, with just ram and processor, and keyboard.
and oh, yea, monitor.
Please rate this answer.
Aug 04, 2011 | Biostar G41DVI Motherboard - G41 Express,...
MY IBM R50E, IT GIVES ME 4 BEEPS SOUND WHEN POWER ON, NO SCREEN DISPLAY ALSO.
How will you describe the beeping sound that you hear? it might just be a video card problem.
Jan 17, 2011 | IBM ThinkPad R50e Notebook
My Thinkpad G41 does not boot up, nothing comes up
Hello
Have you tried swapping out ram modules? This would probably be the cheapest. And, a faulty ram module gives a beep code. Try it, and let me know.
Kind regards
Andrea
Apr 21, 2010 | IBM ThinkPad G41 Notebook
IBM G41 turns on but has no video output and gives a three beep sound. Can this be fixed? Was there a defect on this mother board?
Try changing your RAM\Memory. This is often caused by a stick of RAM going bad. You will need to get a notebook stick of PC2700 (333MHz) DDR RAM. I suggest getting a stick that is at least 512MB. The maximum that your computers can take is 2GB (2 sticks X 1GB). If you're unsure your ability to do this then ask a local computer shop\tech to test your RAM by putting a different stick of RAM into your computer. There may be a charge for their services rendered. Often they won't charge you for testing your computer if you pay them for the RAM if\when they diagnose it as definitely being the RAM that is causing the problems. It's usually pretty easy to change the RAM yourself. It's usually located in a compartment that is accessible from the bottom of your laptop. The removable cover with the RAM under it is typically marked with the icon of a memory chip next to the cover. Typically laptops only have 2 RAM slots, one on top of the other. Just move the brackets holding it into place and the RAM should lift up. WARNING: be sure your computer is turned off when doing this and be sure that you're grounded as well. RAM is highly sensitive to static charge (The electrical poke you get from door knobs, light switches, and blankets). A simple static-poke can fry your RAM. If you can't find your RAM in a compartment on the bottom of your laptop, then it is likely under the keyboard. I'm pretty sure your RAM compartment is located on the bottom of your laptop.
Mar 22, 2010 | IBM ThinkPad G41 Notebook
When I start the system is not video display
There may be problem in Monitor or VGA Card. When you Turn on PC the Monitor light is green after 10 second if It will be orange . It means your monitor is alright . but problem in you VGA Card. When the PC turn on there is any beep. If no beep then your RAM is alright. Problem in VGA Card.
Mar 20, 2010 | Biostar G41-M7 Motherboard - Socket 775,...
IBM Wheelwriter 6 Series II beeps
Three beeps and the space lights blinking means the batteries are bad replace them and be sure the holder is clean.
DickyO
Feb 14, 2009 | IBM Office Equipment & Supplies
Blank screen ibm r40e
This is generally a memory problem. Remove the memory, and try them one chip at a time in each slot. If the memory isn't the issue, then try removing the battery and starting with the supply only. Both battery and memory can cause this, but the beep code is generally for the memory, no beeps with the battery. If both check good, then test the power supply with an ohm meter for the proper output. If these three check good, then the problem will lie within the motherboard, and you will need to take it in for a professional diagnosis in order to track down the exact problem area. You might also look on IBM's support site for the beep/sound error codes and any troubleshooting for the exact code you have.
Aug 12, 2008 | IBM ThinkPad R40 2722 Notebook
IBM ThinkPad G41 Notebook Logo
138 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
