Question about KitchenAid KSM90 Ultra Power Series Stand Mixer
Kitchenaid mixer not mixing
Push speed selector to speed I want and speed slowly dies. move lever to different speeds and all speeds slowly die
    Problem Solver:
  • 9 Answers
Remove the back cover, and try tightening the two (on top) adjustment screws.  that might help but no guarantees!
Posted on Jan 27, 2008
Why wont my classic kitchenaid mixer switch off
Good Morning,
There is a spring inside your mixer attached to the speed control switch and speed control arm, the spring can sometimes get caught on the slide bar that is just below it inside the mixer. The other reason is that the speed control switch plate in the rear of the machine (that the spring attaches to) vibrates the three speed adjustment screws out or in and the spring will pull the speed switch (control arm that you use to control mixing speed when using the mixer) back to the stir position after you try to turn the mixer off.
If it is a spring problem you will have to do a full tear down to get at the spring and either free it or replace it. If it is a problem with the adjustment screws on the speed plate, that can be handled at the rear of the machine and is twice as easy to get at but sometimes much more frustrating to adjust. There are "YouTube" videos on the internet that will walk you through the process of adjusting your speed control plate just Google "adjusting speed on kitchenaid mixer" I hope this helps. please let us know if it does and if you have other questions just post them here and we will "FixYa"
Sep 11, 2014 | KitchenAid K45SS Classic Stand Mixer
Why won't our kitchenaid stand mixer run?
He rdnowak:
I am sure #10 in the highest speed, but are you saying it will only run at #10? if so I would start by removing the cover again. Hopefully no parts are missing. Make sure the selector switch is moving things on the board if possible. I mean if you can move it with you finger you should be able to move it with the selector lever. Sorry for the trouble but I have never taken mine apart I just clean the out side. I do no this. Sometimes I must take something apart and reassemble them several times before getting them to work the way they are supposed to.
Best of luck
'RR
May 15, 2014 | KitchenAid Pro 600 Stand Mixer KP26M1X-...
KitchenAid Speeds are offset
Ideally you need to fix what's bent and that normally would involve splitting the cases to get at and repair or change the speed control lever. If you don't want to do that then removing the back cover and altering the adjustments and maybe bending the switch contacts may make it operate at both ends of the speed control.
Oct 04, 2017 | KitchenAid KSM150PS Artisan Series Stand...
Mixer has lost all speeds, only works when moving the lever back and forth. The mixer is about 9 years old.
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
Adjust the mixer speeds:
Remove the screw holding the End Cover and locate the three screws from the Control Plate.
All three (2 top left and right, and 1 bottom) must be adjusted.
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Aug 14, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Hi, the speed lever won't move. I have checked that the bowl is securely placed and adjusted the height of the beaters? Can you tell me what else might be the problem. I have only had the appliance...
The Speed Control lever is linked to the Speed Link mechanism, which in turn moves the
Speed Control Assembly to allow the motor to operate at different speeds.
Get a Repair Part List from Kitchenaid.com for your particular model to see how it works.
As you select different speed setting, the Speed Link simply moves forward or backward,
thus pushing the Speed Control Assembly back and forth.
If you cannot move the Speed Control lever, means that the Speed Link is somehow bent
or out of place. Remove the Motor Housing and the End Cover and check it out.
Jul 01, 2011 | KitchenAid Artisan KSM150PSSM Stand Mixer
My kitchenaid mixer speed control is locked in the off position and wont move. It was working 2 min earlier when it was turned off from a prior mix.
You can try moving the lever slightly up or down while moving it forward to see if this will free it it or make a difference. Otherwise, the spring inside may have snapped or the speedlink cam may have came loose or broke. Either one will require the top end assembly to be removed to replace these parts.
Dec 21, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Kitchenaid artisan mixer does not turn the blade at low speeds
If it is the worm gear then the planetary will stop turning when there is a load on the paddle but the motor will continue to run at the speed you set it at. I'd be checking the carbon brushes, checking that the field assembly has not loosened up a bit and then I would see if the speed control plate adjustment screws are loose. I'd then reset the speed and see if it stays as it should be.
Sep 24, 2017 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid ksm50pob no stir speed all other speeds seem ok
I don't know if it will work for you but move the speed lever from front to back a few times as fast as you can. This will polish the contacts. This is like the old fashioned TV tuners. People used to turn them slowly and then complain when they needed serviced every 6 months. Spinning the tuner knob kept the tuners working flawlessly for years.
Jan 08, 2009 | KitchenAid KSM50PR Professional Series...
Speed of mixer
does the motor still run or does it slowly start to get less loud? or is the beater assembly that dosnt work? two different issues. if the motor runs but dosnt beat then its the planitary gears that are ground out and need replacing. if the motor slowly dies out then you need to replace the motor.
Dec 24, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid KSM90 Ultra Power Series Stand Mixer Logo
241 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
