Question about Panasonic KX-TA824PK Phone
I have installed an 8 port slt card and cannot get the extensions to dial out. Can receive incomming but not make internal or external calls
  • Panasonic Master
  • 2,460 Answers
If you installed the 208 or 308 extension card, you also added 2 or 3 extra C.O. lines. When you dial "9" you are accessing lines that don't exist (the new highest lines).
Go into system programming and choose option 3.3 or program 400 and disable the additional lines.
Carl
Posted on Oct 09, 2009
When a call comes in and I transfer to my boss' extension, incoming calls do not come through, caller states phone keeps on ringing. Also on that same extension calls do not transfer to voice mail.
  • Begin the transfer. With the caller on the line, press the "Transfer" key. The caller will automatically be placed on hold and you will hear a dial tone.
  • Connect the caller to the other party. Dial the extension of the party you wish to reach. When you hear the extension ring or after you've announced the caller, complete the transfer by pressing "Transfer" a second time. If the person does not wish to receive the call, press "Release" to disconnect from the dialed extension. Press the key beside the flashing arrow on the LCD indicator where the various lines are displayed to return to the caller.
  • Cancel an incomplete transfer. If you make an error when dialing and need to retrieve the caller, simply press the key beside the flashing arrow on the LCD indicator.
  • Park an incoming call. Parking a call at a designated extension allows the recipient to answer the call from any phone in the facility. With the caller on the line, press the "Park" key twice. If your system designates a particular extension for parked calls, the caller will be held at that extension. Otherwise, the caller is held at your extension. To specify an extension for a parked call, press "Park," dial the desired extension and press "Park" a second time. Replace the handset.
  • Retrieve a parked call. On any system phone, press "Park" and dial the extension on which the call is parked. You will be connected to the caller.
Aug 18, 2016 | Nortel Norstar M7310 Telephone
After power outage incoming calls cause all lines to light up
If this is happening on the entire system, then make sure you have the number of lines programmed correctly. If this is correct you may have a bad processor card. If this is a happening on an extension only, then the port/card may be damaged I would temporarily move the extension to another port on a different card and see if the trouble follows. If it does you have an issue with the phone not the port/card.
May 07, 2014 | Avaya Corded Phone avaparp18d
We have a new KXTES824 which we are setting up here with a mix of KXT7730 and SLT phones. We've done this before without incident but have an odd problem. We have a single phone connected (PT) and...
One of the ports is shorted or you have the DISA turned on. Start by dialing each extension 101-1xx on the 824 and make sure that none of them are tripping the ring. You'll probably find that one of the ports is bad, the wiring is bad, or there is a programming issue. IIRC the U.K. system is not delivered with DISA, but you may have installed or turned on that feature.
Carl
Feb 03, 2011 | Panasonic Lands Phones
I want to set all incoming call go to Ext number 800. How to do setting on it?
if you don't have the programming software (and i assume you don't) it will be a very annoying process, *i hope nothing gets messed up that you don't know how to fix while trying this* and i hope you have a display phone
1) press "PROG"
2) " * # " then the installers password if you have it handy (if not stop here and call a serviceman)
3) press "450"
4) "ENTER"
5) choose your time mode (1-DAY, 2-LUNCH, 3-BREAK, 4-NIGHT)
6) enter the slot # in your system that your CO card is installed in
7) enter the port on that card that you want to redirect
8) press "CLEAR"
9) dial the extension # you want to send the call to ( 800 )
10) press "ENTER"
11) press "NEXT" and repeat till you get all the ports going to your new location
12) lift handset and hang up
Jan 04, 2011 | Panasonic KX-T7630 Corded Phone
Incoming calls: When we receive an incoming call,
Extension call forwarding is controlled by a timer, and they put these things in the manual. If your CF after 2 rings is from a call to a specific extension, from that extension, dial *713 and a 2 digit number from 00-99 seconds on the intercom. Start with 18.
If your call forwarding is from intercept, then you have a system programming issue and need to look in the installer's manual or check with your system programmer.
Carl
Dec 01, 2010 | Panasonic KX-T7633 Corded Phone
How do I send a call to internal voice mail?
Use feature 986 (transfer to VM) then enter in the co-workers extension number. That will bypass the extension and send the caller directly to his voicemail.
Jun 29, 2010 | NorStar M7324 Telephone
M7208n phone - mute ringer for external calls
Incoming line ring settings are in the config menu under:
2nd option - Line access
enter extension number
2nd option - Ringing
Ringing then can be toggled on or off for each line assigned to that extension.
Mark
Jul 15, 2009 | Nortel Meridian M7208 Corded Phone
Turn off Ringer For External Calls Only
If you use strata emanager it would depend on how your system was set up. One way is to go to Advanced configuration tab Station tab, multiple call group tab, click on the group number (far right), then member tab and select extention and ringing option. Another way is to go again from the advance configuration tab, then assignment tab select the extention number on the right select key assignment tab, and on the incoming extention line double click it nd select no ring.
Jun 11, 2009 | Toshiba DKT3020SD Corded Phone
Samsung prostar 816 plus system ringing problem
sounds like your having a couple of problems at the same time. the lines only ringing at station 1 is the default setting of the system my guess is that the time and date are also way off if thats the case.
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
press #when finished.
next, the problem with the cordless not working has to do with the port programming, in default it assigns all ports as multiline sets.
To assign a SLT(single line telephone) port to the system while still in program mode dial #38 the screen should say slt dial type and then 16 0's.
0 = keyset 1=slt set
enter in all 16 digits followed by the # i.e.if your cordless is on port 7 it would look like 0000001000000000 #
lastly the phone that can no lnger recieve calls sounds like the do not disturb or DND has been pressed to stop the alarm from ringing. press the mute/dnd button (light should be off). to cancel an alarm press the ALM/SD button twice and then the hold button.
hope that helps out.
Mar 05, 2009 | Samsung Prostar 816 Phone
Transfer
Do you mean send the call to another phone?
Make sure the line is not on hold (push the caller's line) then push Cnf/Trn, dial the extension you want the call to go to, then hang up.
The person you're sending to will receive that call on their speakerphone button and it will ring in a different tone.
Jan 13, 2009 | Toshiba DKT-2010H Corded Phone
Panasonic KX-TA824PK Phone Logo
215 people viewed this question
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
