Hi, door seems properly closed but when I turn on the wash the door light remains on, and of cause the wash does not proceed. What could be the problem.
    Genius:
  • Washing Mach... Master
  • 1,461 Answers
Could be faulty door interlock assuming of course nothing is broken on the door clip/ ******..
Posted on Oct 07, 2009
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
How do I reset the program. It will not start
on ur last wash did it spin ok or where the cloth a bit wetter than normal
Jan 25, 2015 | Candy Washing Machines
Defy autodry trouble shooting
Check the door latch. If that is faulty, the machine just remains in limbo until replaced. If you close the door and try and select a program and it wont proceed, normally means door latch is faulty.
Jul 03, 2014 | Washing Machines
My Whirlpool dishwasher washes but does not rinse or dry
Most likely the control panel is defective. Go to the repairclinic.com for further diagnostic help and parts.
Apr 25, 2017 | Dishwashers
I have the bottom freezer w/2 doors up top....light inside will not go off and has started to melt some of the plastic pieces. How do you remove the light bulbs so the darn thing doesn't burn...
There should be a light switch inside each compartment, depress them with the door open one at a time, locate the bad switch and disconnect it. You can remove the bulbs too. Most of the problems with bottom freezer are the door, they seem to not get closed properly and they get heavily frosted, once frosted they seem not to close correctly and cause the lights to remain on.
I would look for the problem with the door closing or the door switch failing.
Aug 28, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Flashing lights on Maytag dishwasher
Check whether the door is getting closed fully. Try pushing little hard. If the door close switch problem it may work.
Contact service for help if u can not proceed further with electrical circuits. Micro-controller board to be checked!
May 18, 2010 | Dishwashers
Interior lights remain on after doors are closed causing battery to drain overnight. When fuse is removed lights go of and battery stays charged.
Check to be sure interior lights are turn off when you are in the vehical.If so check the interior light switches on the doors for proper opperation.
Mar 13, 2010 | 1997 Jeep Grand Cherokee
WD440 - no lights coming on
Could be door interlock switch/ or mains switch.if you have multimeter you can check this beware of mains voltage hazard!!
Nov 11, 2009 | Washing Machines
Front load washer stops and starts and door lock light remains on
You probably have a bad door latch or door interlock. Both, if defective will cause the symptoms you describe. The door must remain closed and lock before a wash cycle will begin, and for it to complete properly.
Jul 10, 2007 | Frigidaire FWTBB30DS Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
