Question about RCA P52926 52" Rear Projection Television
My tv seems to have a "white fog" to the picture and it doesnt seem "crisp" it almost seems like the colours arent right also it seems muted
  • 647 Answers
It sounds like the coolant to one or more of the picture tubes has become discolored - this can be determined by removing the chassis and viewing the tubes directly (when the TV is on) - Get an estimate
Posted on Oct 07, 2009
Color Alignment
the most common problem when the tv felt is the shadows all over the screen (maybe the tv didnt show it imm but looks like now is there the problem)
second:there is a circuit in the tv that works when the tv turns on every day. prevents the tv showing shadows on the screen.
the answer is this: if that system that prevents shadowing is working then the CRT is broken and say bye to the TV. But if the expert tech can make sure the D' gauss system is not working and can repair it then you get tv back.
Apr 08, 2009 | Philips Magnavox TP3285C 32" TV
Tv beginning to flash green with horizontal white lines
From your description it sounds like a bad picture tube. The lines are called retrace lines. There is a small chance that a component on the small board that connects to the neck of the tube may be bad. Without model number information it is very difficult so say further. Some picture tubes can be re-jeuvenated with the appropriate machine ( at a TV repar shop)
If you feel adventurous and are careful you might try GENTLY tapping the neck of the tube and see if picture improves/goes out. If the tapping does change the picture it is definitely the tube
Mar 12, 2009 | Loewe ARC332 32" TV
Television picture fault
sounds like an issue with the tube but you probably wont be able to fix it on your own, i would take it by an tv repair shop, they will determine if its repairable
Aug 06, 2008 | Sony Televison & Video
Volume up then pic gone
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Jan 08, 2008 | LG 32LC2R 32 in. HD-Ready LCD Television
Picture is not crisp
Did you purchase new? Convergence may be off, try the menu and look for a convergence adjustment.
Jul 08, 2007 | Mitsubishi WT-42313 42" Rear Projection...
Try # 2... Green Fog
The green gun in your picture tube is set a little too high. If you are experienced in removing the back cover of TV's,etc., you may try to find the drive and/or bias controls either on the circuit board that plugs on to the neck of the picture tube or mounted on the main circuit board of your TV. These controls are usually labeled. If you can find them, locate the green bias or drive control and back it down a little while watching the picture through a mirror. A slight adjustment may correct your problem.tJIS IS CALLED GRAY SCALE ADJUSTMENT. BE CAREFUL THERE ARE SOME HIGH VOLTAGE CIRCUITS NEARBY. WORK WITH ONE HAND AND USE AN INSULATED TOOL TO MAKE ADJUSTMENTS I hope this may help you.AGAIN BE CAREFUL!! Stargazer
Feb 26, 2007 | Toshiba 32HFX71 32" TV
RCA P52926 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
