Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Panasonic pt-50LC13 when i push the power on it clicks like its going to come on but it dose nothing the lamp looks good but the power is flashing looks like yellow every 2 seconds what should i do???
We just replaced new bulb and screen was on for about an hour. Turned off TV and tried to turn on later, but now no screen. Do you know what has happened or what I can do?
Posted on Dec 25, 2007
Panasonic pt-50lc13 won't show picture. Blinks green when turned on can hear lamp clicking then goes off to red blinking for a few miniutes then shuts down to just red . Can u help me out please?
sound like your lamp is bad ...Panasonic TY-LA1000 Lamp Replacement...Ballast Repair Kit for Panasonic PT-50LC13 some time the ballast go bad as well to hear bouth part number one lamp and 2 ballast I hope this help you..
Nov 19, 2013 | Televison & Video
Panasonic PT-50LC13 reset hour meter
on the tv itself push the volume down button and at the same time using the remote control press the pip button. I just did this on my tv - had the same problem. it worked perfectly. Jeanne
Jun 21, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Lamp power supply board on Panasonic PT-50LC13 mulfunction.
You can purchase the lamp supply thru " The cost is $100.00, there is a $250.00 core charge on that module, so when you return the old they refund the 250. Initial investment will be 350.23 then take the 250. off that. That will be the end cost.
Part # LSEB3087A
Apr 16, 2009 | Panasonic PT-50LC13 50" Rear Projection...
PT-50LC13 Lamp issue
i hope the lamp was panasonic or bought in a good place (average cost of this lamp is 250 dllrs)
if the lamp is trustfully. i would put attention in the back side when you listen the arcing that the lamp at least try flashing.
This moment of the repair where you are is critical because you arrive to conclusions according to the process you already did and suspect that what it is already done is fine (but is really true that lamp works plus is really true that the arcing is because the arcing devise arcs or is only the primary of the transformers in the ballast who holds 300 volts in the primary (really good voltage to make arcing sound too)
Now the error code is going to be 50 % good or not: i mean or gives you the error of the ballast and lamp or any voltage is missed in the power supply ( i don't have the error codes chart for you with me) because i would like to go far and the problem was in the same place where i started/
Apr 08, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Reset Time Problem on Panasonic TV (PT-50LC13)
Power on the set, listen for afaint buzzing sound as the set tries to fire up. If you do not here it then your lamp driver, or ballast is most likely faulty. Also make sure you have the door and all covers back in place and secure. And make sure you insatlled an orginal panasonic lamp because some generic will not work.
Jan 06, 2009 | Panasonic PT-50LC13 50" Rear Projection...
This model is notorious for a ballast kit needing repair if lamp doesn't fix. Need professional help, probably $300 ish
Jan 17, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic pt-50lc13 shutting off
i'm on my 3rd bulb in 5 yrs. i hate this tv. this time my bulb light didn't come on. instead the power light flashed green fast then went to red flashing after. i took out the bulb and it's blown!
Nov 19, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
78 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
