Question about Dishwashers
I have a Hoover dishwasher D820 model,water is now leaking as soon as the machine is switched on. I have examined inlet pipe and renewed washer, no other cracks are in the outlet pipe. All connections are tight. Any suggestions please.
  • 38 Answers
With hoover it should have a water pump prior to the start of the outlet pipe. Id remove this and check for blockage, as anything in there that wont allow the motor to turn will force the water out somewhere else once its under pressure.
Posted on Oct 07, 2009
Dear gents, I face problem in hoover HDW1400 dishwasher machine Error E1 kindly need your support to solve this issue
The E1 error most likely means that the dishwasher identified a slow fill issue. First, make sure that the inlet water connection is not leaking and that the water valve is open. Make sure that the incoming water is as hot as possible from your water heater. (Wash some items by hand first.) Next check the inlet valve and those connections. Check the voltage across the valve to make sure that it can open. (If the valve failed in the closed position, there will be no water in the dishwasher when you open it in the middle of the cycle.)
Next check the float valve to ensure that it is rising and falling properly. If the float is blocked in up position, the washer will assume that it didn't properly fill and stop operating. Check the switch as well to ensure that the signal for the float position is properly being provided to the CCU.
I hope this helps. Unfortunately, I can't find the HDW1400 model number to assist you in obtaining any replacement parts. Please check the model number. If the model number given inside the door of the dishwasher is different than that given above, please add a comment with the full model number of your dishwasher. If your unit is under warranty, contact Hoover directly.
Jun 15, 2015 | Hoover Dishwashers
Hoover Dishwasher HD95M leaks on start up from bottom right front corner. Leaks when initially being fed from water feed.
Water leaking can be poor plumbing or fault in the inlet hose connection. You are the first observer and so your view on the leak area is important as the leak can be from the hose, from the inlet, the hose or the washer unit.
Based on this the water leak can be plugged, tighten the hose clips, check the inlet filter or check the washer's feed line.
Feb 09, 2011 | Hoover HD95M Free-standing Dishwasher
HOOVER HOD6615 DISHWASHER CONTINUAL BEEPING AFTER INITIAL RINSE & REFUSES TO PROCEED TO WASH CYCLE WHATS THE PROBLEM?
This could be a safety trigger due to bottom water leak. A anti flood device (polystireen float and micro switch) that switches washer in shut off mode and does not continue until the water leak (pipe or hose clamp) that causes the float to trigger the device. Check the bottom of the washer for traces of water and rectify any leak before the washer will continue.
Jun 01, 2010 | Hoover 24 in. HD83M Free-standing...
All the lights come on but the machine does not wash
The problem could be 1) The inlet solinoid in line with the main water inlet faulty this acts as an electrical tap controling the inlet water. 2) The triggering of the anti flood system (polysireene float and micro switch at the base of washer) due to water leak / spill (this device causes the washer to stop until the leak is cleared.3) Water pressure to low.
Jun 01, 2010 | Baumatic 23 in. BDW5 Built-in Dishwasher
Water wants to drain and keeps trying
Sounds like anti flood system has triggered (polystireen float and micro switch) that puts the washer in pump out mode only and shuts the inlet water off. You need to look at the bottom of the washer and check that water leak / spill is not causing the float to activate. Clear the water and fix leak (pipe or pipe clamp) and this should fix the problem.
May 18, 2010 | Bosch 23 in. SHU 8805 Built-in Dishwasher
My dishwasher is not filling with water i have tried the water tap and checked the hose pipe it has been working no problem for about 3 years does that mean its wear and tear of the machine ? or could it...
This does sound like a problem with the "anti-flood" device that does detect water (leak / spill) at the base of the washer. This device is a protection device that consists of a polystirene float and a micro swithch. Once a water leak or spill is detected it automatically puts the washer in pump out mode and switches the inlet water off. You need to determine if a leak exists that has caused the float to trigger the micro switch and clear the water / leak. This should put the washer back to normal.
Apr 12, 2010 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Dishwasher leaks at start
Is the washer not "over filling" due to the water fill vacume pipe and micro switch that shuts off the water once the correct level blocked or restricted due to fatty residue? This could also be one of the washer pipes clogged up and increasing the pressure in the fill tank.
Jan 20, 2010 | Dishwashers
Aeg dischwaher model oko favorite
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Nov 15, 2008 | AEG 18 in. Favorit 64800 Free-standing...
Drain pump keeps running AEG oko favorit
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
Issue with Water Pressure
blocked dispenser box Regards Advisor
Aug 22, 2007 | Hoover Nextra HNT 2135 Top Load Washer
Dishwashers Logo
130 people viewed this question
Top Dishwashers Experts
Owen Barnes
