Question about Sony VPL CS6 Multimedia Projector
The tilt foot is stuck out and won't retracked back using the buttons
  • 172 Answers
Because of tilt rod gear is broken so that its not workig it need to be replace
Posted on Mar 06, 2010
  • 4 Answers
I have the same problem one of the legs inside is stuck
Posted on Feb 18, 2013
Why doesn't walking mechanism work?
if the pressor foot anvil doesn't move up and down /back/forth , the machine might be in "DARNING " mode this is usually a small button in the bobbin area , but some machines have them on the back of cabinet as well
Feb 26, 2016 | Sewing Machines
Pin won't retrack
first thing to check is that a nail isn't jamming the pin. If not one of the seals is probably cracked
Make sure you use the correct angled nails, the wrong angle will jam in just a few shots
Feb 20, 2013 | Campbell Hausfeld Air Tools & Compressors
My bugaboo bee won't recline, the mechanism seems stuck, when I push the release to lie it back the mechanism gets stuck in the up position and nothing happens. The two white buttons on the side
Hi, When the stroller is open, make sure that both of the green indicators either side of the frame are visible. If not, put your foot on the brake and pull the handle firmly with both hands until the green appears. This will enable you to get access to the seat. If the seat doesn't move still, check at the bottom (where the small of babies back is) to see if the excess seat fabric has become stuck inside. This is usually the main reason for the seat recline not functioning. Hope this helps.
Feb 07, 2013 | Bugaboo Bee Stroller
Sunbeam stand mixer won't tilt back down
I'm in the middle of a bake sale. Not a good time to send back. Also, I think you meant a free Upgrade at no additional cost...
Dec 14, 2012 | Sunbeam 2346 Heritage MixMaster Series...
My vacuum was working fine just a minute ago, and i turned it off to finish laundry, and now when i go to use it again, the handle won't recline... is there something stuck??
Sorry to hear you're having problems with your DC17. The cleaner should recline easily into the vacuuming position when you place one foot on the cleaner head, and tilt the handle back. If it's not doing this, please get in touch with us free on 1866MYDYSON, or email askdysonUS@dyson.com. One of our experts will be happy to provide further assistance.
Kind regards,
Jack
Dyson Customer Service
Jul 23, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
The zoom lens don't retrack Display don't
Charlene, It seems that there some dust that has entered between the lens housing and the camera body. To remove it you must use the vacuum cleaner to pull out the dust from this place. And keep switching on and off the camera so that it tries to move the lens inwards/outwards. If this does not work then the movement mechanism of the lens may have got stuck and would require more serious efforts for which you may or may not have to tools and knowledge.
Nov 02, 2009 | Vivitar ViviCam 8400 Digital Camera
THE TEL PHOTO LENS WON'T RETRACKED
That happened to me. Camera is a few years old so the warantee was long gone, so I actually took it apart and cleaned inside it with electronic cleaner.
If you still have a warantee you could call customer service and speak to a technician.
If you know how to put things back together easily, you can try it. You could probably use Air in a Can to spray around the lense.
I sure hope this helps!
Oct 23, 2009 | Cameras
How do I open my Kenmore Whispertone 12.0 to get to the cord reel
The motor / cord compartment cover must be removed to access the cord reel. There are four screws that hold the cover to the chassis. Two of the screws are found under the cord-retractor-foot-pedal on the top back of the canister. To access these screws the pedal must be removed. To do this, press the pedal down and look (from the top) for the four plastic clips that attach/hold the pedal hinges to the cover. There are two at the end corners and two in the middle. Using a long, thin flat-head screw driver (or similar instrument) press each clip to unhook/popout the hinges. Note: the foot pedal spring will also come out when the pedal is removed.
The other two screws are found under the curved hinges of the vaccum bag compartment cover. To access these, lift the cover as if accessing the vacuum bag. Keep pulling the cover back until the hinges release from the motor cover. Don't worry, it is disigned to do this and will not break but it may require a little force. A long phillip-head screw driver will be needed to access and remove each screw. Good luck. - Gary
Mar 30, 2009 | Kenmore 23313 Whispertone Bagged Canister...
AL2340 will not prime. Motor runs but cannot get it to prime
I worked at a tool rental center when I was going to college and learned many useful tips / tricks about airless sprayers. Airless sprayers have two check valves/balls that can stick on their seats or stay open due to chips of paint on seat. Easy method to prime is to remove intake filter from machine, tilt the machine back far enough so that the pick-up tube is pointing up high enough to pour water in tube until full; hold in this position and turn on machine. If water is sucked in turn off machine and tilt machine into pail of water and restart to check for prime. If it still will not prime remove water from pickup tube and use air pressure into tube with bypass valve open. Air pressure will attempt to release the stuck lower check ball. If air pressure does not release stuck ball you may have to use physical pressure against ball. If lower check ball was stuck you can assume that the upper check ball is probably stuck also. An aid to loosen stickey valves is to pour solvent into pickup tube with machine tilted back as before leave overnite. Enjoy
Dec 09, 2008 | Campbell Hausfeld Airless Spray Guns &...
The tilt button is not working
Okay, we just figured this out ourselves.
There is a little hole on the neck of the mixer, where the mixer motor meets the neck. While pushing the tilt release button, stick a small screwdriver into the hole (it will not go far) and pry the latch upward. While holding the latch up and the tilt button, have someone pull up on the motor while holding down the base. It might take a little muscle, but after that, the motor will be able to tilt back and forth like it did before it got stuck. If you are the one holding the tilt button and latch, please wach your finger so they don't get pinched when the motor swings up.
Dec 17, 2007 | Sunbeam 2350 Heritage Series Mixer
Sony VPL CS6 Multimedia Projector Logo
331 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
