Question about Honeywell Programmable Thermostat Heater
Is it possible to change the thermostat L641a1005 without draining the water down. The thermostat seems to be secured with a large jubilee clip. This is fitted to a hot water cylinder in the airing cupboard. Barry
Yes this can be removed without draining anything. It only mounts on the surface of the hot cylinder tank.
Posted on Nov 16, 2009
Water leaks at top hose to radiator
Take hose off check jubilee clip or replace with jubilee clip check hose to see if perished change hose if needed,ends of hose should be flexible not hard and brittle Hope this helps.
Mar 23, 2013 | 2002 Cadillac Deville
How to replace the thermostat in a 04 lancer
the thermostat is on the rear of the cylinder head above the gear box and is connected with the upper radiator hose. Drain the radiator coolant by loosing on the low part of the radiator the plastic butterfly drain plug, and let the coolant in an empty bowl. Then by using a 12mm socket loose the bolts on the thermostat flange and remove it.When the thermostat housing removed you will see the old thermostat,pull it out and clean the old gasket Renew the thermostat and use a new gasket,put the flange back on and tight it, Fit the radiator hose and tight the jubilee clip. Then loose the 12mm bleeding bolt which is on the thermostat housing,start filling the radiator with a new coolant until the air comes out of the bleeder and close it. then start the engine and let it in idle with radiator without the cap. When temperature raised to some warm point put the radiator cap and leave it idle till fan starts.Then switch engine off and let it cool down and check the radiator coolant level and the expansion tank fill it to maximum level.
Nov 12, 2012 | 2004 Mitsubishi Lancer
Please, I want to Know, how ti change the rubber door seal? thank you.
Hello there
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some AEG machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the AEG door seal/gasket that locates on the drum makes fitting the new seal easier.
5 Your new AEG washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 Refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test your AEG machine for any leaks,
I
Jan 01, 2011 | AEG L66600 Front Load Washer
My sanibest is just humming. I am assuming that the motor is clogged with something disgusting. I have a toilet, sink, and bathtub going into the sanibest. Unit stopped working as soon as tub was draining...
Bail out as much as you can through the toilet bowl. Unfortunately this is a messy job regardless and you will still need newspaper on hand.
If you lower the water level below that of the rubber gasket connecting it to the toilet though, you will be able to undo the jubilee clip holding this and slide the unit away from the toilet, hopefully without spilling much waste water.
If you can dislodge the blockage from this angle, great. If not, you might also have to take the lid off by depressing the plastic clips on each side and accessing the chamber from the top.
Oct 17, 2010 | Saniflo Sanibest macerator with multiple...
How do you control the flow of water coming down the waterfall. Is there a way to decrease the flow of water?
hi you could put a jubilee clip on the hose and tighten it up so it stems the flow of water the tighter you do up the clip the more reduced the hose bore i do not know if you are american or not, so i do not know what the equivalent thing would be called there, we call them jubilee clips, just google it you will see what they are lol...hope this works for you
Jun 27, 2010 | Sta Rite StaRite Duraglas Pump 1 12 HP...
2003 883 sportster, how do you drain the engine oil reserve for oil change?
warm the bike up ,then if you look in between the rear wheel and the engine case on the left hand side of the bike (if you are sat on it ) on the underside you will see a black plate (part of the frame ) and it will have a black hose on it secured by a jubilee clip , remove the jubilee clip place a oil drain pan underneath it and pull the hose away from the frame and the engine oil will drain out .
hope this helps
kind regards
bert3100
Mar 18, 2009 | 1993 Harley Davidson XLH Sportster 883
Waste hose connection hotpoint wd440g
Have you checked the filter? This can be found at the large end of the pipe. It is secured with a large jubilee clip.
Thankyou for using Fixya.
Feb 12, 2009 | Hotpoint Ariston WD440G Front Load...
Jubilee clip
Hi.
The plastic serrated type can be undone by sliding one half sideways. Use pliars as they can be quite sharp.
Standard clips can be used as a replacement - it's just cheaper in manufacture.
Try not to damage the hose - as they can be an expence you don't need.
Hope this helps.
Jun 11, 2008 | Hotpoint Aquarius WD640 Front Load...
Cycle
Clean the drain filter ( It says its self cleaning but its not).
On my Hotpoint Aquarius WD440 the procedure is as folows:
1) Drain as best as possible, switch off electrics at socket
2) Remove the plastic panel at the back of the machine
3)Locate the large diameter short black flexi drain hose on the right hand side
4)Slacken the screw on the TOP jubilee clip (The one holding the hose to the drum ) until the rubber hose can slide off
5) The plastic filter is inside the end of the hose. Remove it, disassemble and clean it - then reassemble it remembering to re-insert the ball inside the filter
6) Put the filter back in the hose, there are 2 slots which will locate on two ribs on the drum
7) Refit the hose and re-tighten the jubilee clip.
Dec 26, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Heating & Cooling Logo
711 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
