Question about Kenmore 64902 Electric Dryer
Stops during cycle
I think I have a timer problem. dryer will only turn on in one cycle..but will turn back off a fter a minute or sometimes longer. i move the timer knob a little and push start and it will work again. it advances fine when it stays on...but i have to move timer knob quite often to get it to continue working.
  • avalon2003 Dec 27, 2007
    If I hold The timer knob. it works fine, let go and it stops. Some time it stays on thru the cycle.
  • Anonymous Jun 02, 2008
    340 6501 A Model...dryer stopping after about 2 minutes. We have checked dryer hose and vents, taken off back and cleaned everything
  • 833 Answers
Maybe. Will the unit restart in the same position or do you have to move it? If it will work in the same position and all you're doing is waiting for a bit of cooldown...it could be a defective high limit switch that is resetting. If it will restart only after you move the timer, then change out the timer. This is a bit of a mystery since timers generally don't have 'dead spots'...they are designed differently than that.
Posted on Dec 24, 2007
Washer stops during normal wash cycle for a minute or more, and then continues. Would replacing the timer fix it?
If it actually goes on and finishes the cycle and that really bothers you replace it. If not leave it alone and allow a little more time to complete its cycle. The lid switch only keeps the spin cycle from going with the top open.
May 23, 2014 | Whirlpool Washing Machines
Whirlpool dryer shuts off at the end of cycle, but timer continues to tick. It ticks through the next cycle and stops ticking at that cycles off?
follow this steps and fix it. God bless you
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is faulty replace it If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace it.
Oct 01, 2013 | Whirlpool Dryers
I have a whirlpool dryer, model number lgt6634dq0. The timmer does not stop after the drying cycle has ended. My guest it might be the timer. After the dryer has finished it's cycle I can hear the timer...
HI. The timer will be the culprit here. The timer motor is damaged, and the cogs seem to be worn, as well. I recommend replacing this failed timer mechanism. Once replaced, the unit will operate correctly.
Dec 03, 2009 | Whirlpool Dryers
Agitator no longer moving
sounds like you may have burned out the lid switch. if it is not working the timer thinks the lid is not closed and will not advance.
Oct 04, 2009 | KitchenAid KAWS850L Top Load Washer
Dryer will not turn off aafter it's 40 minute cycle.it will start over with 1 hour 22 minute cycle
You should check your thermostats, they can cause this problem.
Look for the air tube that goes from the blower to the drum, this is where the thermostats are normally located and the heating coil is normally located there also.
Hope this helps
Sep 30, 2009 | Maytag Dryers
Washer model LAT9824AAE will stop during the wash cycle but timer still runs thru cycle. Sometimes fills and then will not agitate if you fiddle with the timer knob pushing side to side it will run is it...
Timer is definately faulty. the cam is plastic and eventually wears. This in turn creates excessive movement internally which stops the contacts from activating correctly. Replace it.
Sep 15, 2009 | Washing Machines
Dryer starts drying and thinks clothes are dry, but they aren't
Check the timer, and the sensor. Sounds like it is having a problem with the timer or sensor no noticing that the clothes are still wet. Please rate if satisfied. Thank you
Feb 12, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer takes MUCH longer to dry clothes than it should
Is the hose crunched down at all in the back
(vent hose)
Feb 09, 2009 | Fisher and Paykel Dryers
Electric dryer intermittently doesn't heat
If your dryer has a timer with quick connects which easily plug into it then you can possibly fix this problem. Yank both connects off the timer and remove the timer. Take the 2 motor screws off and remove the plate carefully. Clean the contacts on each leaf switch with a file. Put it back and retry. Sounds difficult but it isn't. Remember only the timer with the 2 quick connects.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 21, 2008 | Dryers
Kenmore 64902 Electric Dryer Logo
127 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
