Question about NEC PlasmaSync 50MP1 50 in. Television
Red then green blinking lights.
My set won't come on and all I have is the red-green blinking lights. This happened a few years ago and the service tec tried for several hours to run down the problem untill he finaly talked to a nec guy who told him of a "secret, unpublished code" to reset the unit. He pressed 2 or 3 of the function control buttons (vol. up---vol. down---proceede...) and the unit reset and worked great. Now it has happend again and I don't remember which of the 6 buttons he pushed to reset it. Anyone ever hear what buttons do the trick
Push power on at button (no need to hold button)and press proceed button for 2 secounds at the same time you turn on power and it should reset.
Posted on Jan 31, 2008
Push and hold the "input select /exit" button on the set at the same time you turn on power
the hotline could you have said it !
Posted on Apr 30, 2008
Monitor won't turn on after a few hours of being shut off
If it EVER works, then the problem is not a failed part, but a weak part. The most likely component type to give you such problems are capacitors. But very few repair techs know how to find such problems, and even fewer have the equipment needed to find the bad one(s) in-circuit. The failure mode is high ESR (ESR means Equivalent Series Resistance). The lower the ESR, the better. Capacitors with high ESR cannot stabilize circuits which demand high pulse currents, such as in switch mode power supplies.
Apr 24, 2017 | Generic Computers & Internet
My uniden phone message light won't stop blinking. Have deleted all messages. How do I get the annoying light to stop??
click on menu button
move down to answering set up keep going down to global set up
click menu and down to VMWI press menu
' move down to yes press menu and end
it starts from NBN installation
It will continually reappear so when you get the process correct copy it down
Oct 01, 2017 | Lands Phones
Optoma HD66 replaced lamp, LAMP WARNING light keeps flashing, still won't turn on?
i just had the same problem i took the top of the projector off and cleaned the color wheel and sensor seemed to have fixed the problem that is for now. seems to happen to me once a year on the dot but last time it was warranty. good luck hope it helps.
Mar 17, 2012 | Optoma Office Equipment & Supplies
1 have a 6 year-old Mitsubishi model WS-48511 series 1080 rear projection TV that now won't turn on. A few days ago we shut the TV off, and now when i plug it in the blinking green power light...
This is called the blinking green light of death-----only one of two things can cause this problem.
First: remove front speaker grill (IT PULLS OFF) AND remove inspection plate behind it; look for the two bundles of wires coming down and to the right from the front keyboard of the set.
Unplug both plugs you find (different and marked so you cannot mix them up-----the idea is to take the front keyboard out of circuit-----set will still function with remote as receiver is behind front screen)
Try (after 70 seconds) to turn on with remote
If it comes on---defective reset button on front keyboard----use set only with remote or remove and remove actual reset switch---it is located behind and part of frame for screen----entire front screen would have to be removed to get at it.
Second: if disconnection of the front keyboard does not help, the DM unit is bad.
As you look from back of set it is large metal box at extreme left side.
The blinking light is the unit trying to "Boot" up-----these have a problem where caps and a few other parts in that unit fail-----kits on the net are available----Mitsubishi no longer sells or services these units but PTS Electronics does repair them.
Let me know if you have questions and try disconnection of the front keyboard FIRST.
REGARDS, SD TECH
Jan 20, 2012 | Mitsubishi WS-55613 55" Rear Projection...
Tv is 10yrs old. Started with color only red and blue, standby blinking, now nothing. Had something like this long time ago is this worth fixing?
propably green not working. due to age its hard decision its worth or not to repair, but i recommend to sell for a few bucks to a hobby-freak and buy a new one...
Nov 13, 2011 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sharp lc-22sv6u won,t power on. no green light.
Sound like the TV is in protection mode. This happens when a part goes bad inside. the TV turns OFF to protect the other parts from being damaged.
Most commonly it's a power supply related issue. A bad capacitor or transformer on the power supply board is to blame.
For a do-it-yourself fixer with electronic experience, a Service Manual is the best for trouble shooting the problem down to the bad part. Normally, you can find it over the internet for less than $20.
Jul 31, 2009 | Sharp Aquos LC-22SV6U 22 in. LCD EDTV
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Jan 28, 2009 | Televison & Video
Fujitsu asu24cl blinking lights
This machine is a looser. Mine has same blink codes. Its been serviced every year since it was installed 3-4 years ago.. Since the elctric work was half the cost of installing it, maybe Ill put in a differnt brand!
Aug 11, 2008 | Fujitsu 24C1 Air Conditioner
NEC PlasmaSync 50MP1 50 in. Television Logo
639 people viewed this question
Top NEC Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
